turbocharged cb550 bobber
mswans said:
Im understanding now that my pilot is so lean, I had to have the idle screw cranked up to the midrange to get it to "idle". It did sound fairly smooth, but just falls on its face and dies if i turn the idle screw any lower than 1500 or so.
Yep.
Need to make sure the pilot circuit including the bleed circuit is clean.
Sorry im not going back that far but what carb are you running?
Dont believe the latest internet hype. If your plugs look pig rich then they are pig rich at least at one point in the rpm range.
At that throttle position you are likely idling on the approx equivelent of a 100+ pilot. Obviously that is somewhat of a cursory guess but thatll blacken your plugs in a hurry
Need to get cxman in here he's a bona fide expert in fueling more than one cylinder per carb. It seems simpler but personally i can tune multiple carbs per cylinder much easier than vice versa. My holley/460 relationship is proof of that. Can't tune that thing for nothin ;D
is it a new tm40 pumper or
old style tm 40 no pump?
do you know your idle vacuum reading?
what slide does it have i bet it has a 2 or 2.5 and it needs 3 maybe even a 3.5 due to the turbo or it will run to rich from vacuum draw
what needle does it have
what jet needle
do you have air correct jet installed
what jet needle
Hey, thanks for chiming in
No pump on this carb.
Cheap boost gauge reads roughly 10-12, not sure how accurate that is.
Slide is a 2.0
Needle reads 9zly2-58
Not sure what needle jet I have, it is pressed in. How do I determine this?
Also, what air jet are you referring too?
mswans said:
Slide is a 2.0
Ok you already have instructions from the man on that, gonna want to start looking for a 3.0 or 3.5
Good info. Things are going to get better now because you are helping people help you. Not to patronize you in particular but other members need to have this pointed out sometimes imo.
Press it out. Now that we know what needle you have, once we know what needle jet you have somebody might have more input regarding what you might need for your particular setup.
The air jets/bleeds are part of the fuel circuits and are located at the mouth of the carb. When the engine draws vacuum, air helps push the fuel through the main and pilot jets. There will be a bleed for each. Some are replaceable and some are not. Please post a closeup of the intake side of your carb for clarification.
in th e air intake bell at the 6 oclock hole the brass you see inside it is the sir correct jet remove it for base tuning
we will add one back as a final tweak if needed
get a q-0 needle jet and a q2
start with the q0
get a 6dh3 needle and a 6dh4 and start with the 6dh3
with it one lift up so second from the top
3.0 slide
get a 27.5 and 35 and 37.5 start fat with the 37.5
set pilot fuel screw at 1.5 turns to start
throw a 200 main in to start
verify ignition both points and timing and advance mech
if you are running stock ignition you will need to limit max advance
Im searching all over, and not finding a source for slides for this carburetor. is the 3.0 a dimension? Could I have a 2.0 slide modified? I do have a spare. I have a few machinist friends that do work for beer if needed.
I was not seeing any removable air jets or bleeds. I have pressed the needle jet out, and did not see any markings. I will take a closer look at this tomorrow. I will also get more detailed pics of everything on this carb.
The 3.0 is the size and shape of the cutaway.
Somebody else can answer the machining ? but im thinking not worth it at all plus the slides are coated. Find a 3.0
Do everything cxman just said.
show a picture of the carb and the jets before you order anything
if its a knock off carb i am going to have to bow out
they dont react the same as the mikuni
also i am going to have to make a call in the morning the
tm40 that you have looks like it only has one slide to be had now
as it phased out and been replaced by the new pumper
pm me at lunch time and i will let you knwo what i find out and if i can find a diff slide or plan
mswans said:
probably idling between 1500 and 2000. Whats making this thing idle off the main and how can I fix it? Drop the needle lower?
The idle speed is what's making it idle from the main. There will be an idle adjust screw that raises and lowers the slide height. Turn the screw so that the slides lower into the carb more. Possible that the motor won't run at this setting, but that's where you want to be. Get the bike idling at around 800-1200 RPM and you know you're in the pilot jet range.
Have you considered a cable set up for the back brake? Would really clean up the look. Awesome project.
heres a few pics of what I've got.
and a few more:
https://www.youtube.com/watch?v=UkLiAaB0auw
heres a video of what I can get for an idle right now. idles between 1000-1200 or so, any lower than this and it will die. It dies on its own at the end of the video. pilot is a tiny 12.5 and fuel screw is 4 turns out (too far, I know). Very eager for suggestions as to where to go from here
that is a proprietary snow mobile carb not a tm 40 standard mikuni
and i am not even sure that you can get a range of parts for it to tune it to your spec
or tat the float bowl volume will suffice for your app as you are running gravity feed not a pump
Well that's bad news, I was under the impression a tm40 was a tm40. Have any suggestions for a carb with more tunability that would work well here?
does that even have the accelerator pump it looks like its been deleted
i cant see it here compare yours to this just in case i am wrong
https://jetsrus.com/carburetor/carb_mikuni_TM36-TM40-HS40_pumper_carb_exploded_view_parts.html
No accelerator pump on this carb. Would a cv carb be a better choice? One with an accelerator pump?
