www.Moto-Madness.com
Author Topic: Cool new items  (Read 17743 times)
Offline SpeedBump
  • CognitoMoto.com
    • https://www.cognitomoto.com
Cool new items
« Reply #10 on: Dec 04, 2013, 12:35:01 »
This is an inspection tag plate just find a tapped hole on your motorcycle to mount it too. Saves your fork from being destroyed by the inspection sticker. Made from 6061 aluminum and anodize black.
http://bit.ly/18CCpNr
www.CognitoMoto.com
Offline SpeedBump
  • CognitoMoto.com
Cool new items
« Reply #11 on: Dec 06, 2013, 09:57:16 »
Snapped a couple pictures of these guys yesterday. Steel construction and very solid. Comes with red lenses as well.
http://bit.ly/1ceKJ1i
www.CognitoMoto.com
Offline SpeedBump
  • CognitoMoto.com
Cool new items
« Reply #12 on: Dec 06, 2013, 15:46:15 »
Need to replace your grime covered factory rear brake switch? This also has the side mounted wire leads to fit in tighter spots. Includes spring and standard metric connections.
http://bit.ly/1gd4nla
www.CognitoMoto.com
Offline cwchan
Re: Cool new items
« Reply #13 on: Dec 08, 2013, 15:18:32 »
Hi,
Will you offer that offset rear brake stay bar found on your cb550?  Additionally, your rear sprocket spacer.
Examining my own cb550 the 4 bolt pins for the rear sprocket don't appear to be long enough if i added a spacer.  Did you use longer bolt pins?
Offline SpeedBump
  • CognitoMoto.com
Cool new items
« Reply #14 on: Dec 09, 2013, 14:23:14 »
Hi,
The rear stay bar is the stock bar. It was just bent to clear the tire. The 4 studs where removed and replaced with longer bolts. I do have the spacer and will add it to the site shortly.
www.CognitoMoto.com
Offline SpeedBump
  • CognitoMoto.com
Cool new items
« Reply #15 on: Dec 09, 2013, 14:34:40 »
What do you guys think about this cowl oil tank? We may have to create two different version to fit the various cowls . Holds 3 quarts plus extra. Will come with new lines to run from the engine to can.
www.CognitoMoto.com
Offline SONIC.
Re: Cool new items
« Reply #16 on: Dec 09, 2013, 14:49:14 »
Is that just the oil tank or is it a tank and a seat?
Its very cool
Offline SpeedBump
  • CognitoMoto.com
Cool new items
« Reply #17 on: Dec 09, 2013, 14:50:14 »
Its very cool
This would be an oil tank only. So you can use what ever seat you have already.
www.CognitoMoto.com
Offline SONIC.
Re: Cool new items
« Reply #18 on: Dec 09, 2013, 15:50:56 »
The only problem I see is the seats have dramatically different shapes, so it might be tough to optimize the shape of the tank.
Offline SpeedBump
  • CognitoMoto.com
Cool new items
« Reply #19 on: Dec 09, 2013, 16:57:00 »
I'm going to have 2 versions. One will be taller and shorter and one longer and shorter. Hopefully I can gather up some cowls and go based on that. If anyone wants to send a seat for test I'm offering good deals
www.CognitoMoto.com
