www.Moto-Madness.com
Author Topic: Cool new items  (Read 17255 times)
Offline Finnigan
Re: Cool new items
« Reply #20 on: Dec 09, 2013, 17:03:43 »
Any chance you're making a 750 oil tank that fits behind the carbs like in your build?
Offline SpeedBump
  • CognitoMoto.com
    • https://www.cognitomoto.com
Cool new items
« Reply #21 on: Dec 09, 2013, 17:14:31 »
It's in the works as well but I'm struggling with how to make it mount clean and simple.
www.CognitoMoto.com
Offline SpeedBump
  • CognitoMoto.com
Cool new items
« Reply #22 on: Dec 11, 2013, 15:38:52 »
http://bit.ly/1coXZ3r
This is a Black Projected Sparto Replica Tail Light. This puppy has an aluminum housing then it's powder coated for durability. Comes with required bulb and also lights up your license plate. Rubber sheet on the bottom seals and protects mating surfaces.
Follow the link below to check her out on the website.
www.CognitoMoto.com
Offline SpeedBump
  • CognitoMoto.com
Cool new items
« Reply #23 on: Dec 12, 2013, 15:51:32 »
Rear brake switch made easy. Clamp one end on the frame and the other end to your rearset or linkage. Has screw connections for adding wire leads. The added versatility allows you to hide the switch and clean things up. Only $7.20
http://bit.ly/1jTJewg
www.CognitoMoto.com
Offline SpeedBump
  • CognitoMoto.com
Cool new items
« Reply #24 on: Dec 13, 2013, 10:54:27 »
Universal rearset linkage. These come 12" in length so you can cut to your desired length. Aluminum tubing with zinc plated rod ends and nuts. Rod ends have nylon races.
http://bit.ly/Jf6B5f
www.CognitoMoto.com
Offline SpeedBump
  • CognitoMoto.com
Cool new items
« Reply #25 on: Dec 18, 2013, 14:41:22 »
We are now offering 17" x 3.5" 40 hole rims! Now you can run modern tires (120/70/17) on your Cognito Moto laced hub for GSXR conversion.
For the rear we are offering 17" x 4.5" 40 hole rims for running modern tires (150/70/17 and 160/70/17) on the rear. These will lace to a stock 40 hole hub and match the 17" front rim
They come in bare steel, chrome and gloss black powder coating.
This is what we used on our builds.
http://bit.ly/1cbEIrA
www.CognitoMoto.com
Offline SpeedBump
  • CognitoMoto.com
Cool new items
« Reply #26 on: Dec 20, 2013, 12:58:36 »
Here is pretty cool little light. It's a reproduction of the Aris Triangular chopper light. Metal housing and uses a 55w single filament bulb. 5" x 5" x 5" and only 3" deep. Bottom mounting elongated the need for fork ears and cleans the front end up a bit. Looks different and pretty straight forward.
http://bit.ly/J2bi2t
www.CognitoMoto.com
Offline SpeedBump
  • CognitoMoto.com
Cool new items
« Reply #27 on: Jan 30, 2014, 14:12:18 »
We have gold and black 530 chains, 120 links now in stock.
$54.99 & $47.99
http://bit.ly/1ffeMbY
www.CognitoMoto.com
Offline iGreek
Re: Cool new items
« Reply #28 on: Jan 30, 2014, 16:43:41 »
I really dig that license plate bracket. Might throw in order in soon.
Offline SpeedBump
  • CognitoMoto.com
Cool new items
« Reply #29 on: Feb 04, 2014, 11:53:51 »
‪Cognito Moto‬ design top trees are now in stock! CNC'd from billet aluminum give your front end a modern look. Unique clamping design allowed us to remove any slots in the face of the top clamp. We offer powder coating on these as well.
http://bit.ly/LeV6eZ
‪CB350F‬ 72-74
‪‎CB350K‬ 71-74
‪‎CB360‬ 74-76
‪CB400F‬ 75-77
‪‎CB450‬‪
CB500T‬‪‎
CB500F‬‪
‎CB550F‬/K
‪CB750‬ 75-78
‪CB750K‬ 69-76
CB750K 77-78
CB750 79-82
‪GSXR‬-600 fork conversion
GSXR-750 fork conversion
GSXR-1000 fork conversion
www.CognitoMoto.com
« Last Edit: Feb 04, 2014, 12:03:28 by SpeedBump »
