www.Moto-Madness.com
Author Topic: Cool new items  (Read 17581 times)
Offline Finnigan
Re: Cool new items
« Reply #40 on: Feb 25, 2014, 13:58:13 »
Order placed
Offline Withers
Re: Cool new items
« Reply #41 on: Feb 25, 2014, 15:36:47 »
You guys are killing it with these products. Just got my license plate bracket in and I'm already thinking about the possibilities with that oil can.
Also, I can't tell if this was intentional or not, but the description for the license plate holders is pretty funny
Quote
Provides a clean and titty look by mounting license plate close to strut.
« Last Edit: Feb 25, 2014, 15:48:00 by Withers »
Jason
Offline coyote13
Re: Cool new items
« Reply #42 on: Feb 25, 2014, 23:08:40 »
God dang, that thing is sexual.
Half the fun's in the get there...
Offline SpeedBump
  • CognitoMoto.com
    • https://www.cognitomoto.com
Cool new items
« Reply #43 on: Mar 05, 2014, 11:04:49 »
Now offering Sun and Excel rims, spokes and lacing.
http://bit.ly/1cbEIrA
www.CognitoMoto.com
Offline nightpoison
Re: Cool new items
« Reply #44 on: Mar 06, 2014, 16:30:28 »
hey, on your site the oil can says its only going to be available in limited qty? will you only be making a small #, or will this be an ongoing product?
Offline SpeedBump
  • CognitoMoto.com
Cool new items
« Reply #45 on: Mar 06, 2014, 20:18:35 »
It will hopefully be on going. I only run a small quantity to keep cost in inventory down.
www.CognitoMoto.com
Offline VTNick7
  • '76 CB550F
Re: Cool new items
« Reply #46 on: Mar 08, 2014, 13:25:22 »
Those gold aluminum rims are so damn sexy.... If only I had room in my budget :/
Offline SpeedBump
  • CognitoMoto.com
Cool new items
« Reply #47 on: Mar 10, 2014, 17:41:38 »
To run the fatter rear tires you'll want to pick up one if these 3/8" offset drive sprockets. We needed them to finished our builds so designed some up and manufactured them.
http://bit.ly/1irMnkS
Works for CB750, CB550, and many other CB's. Made from chromoly steel then hardened for longevity.
www.CognitoMoto.com
Offline SpeedBump
  • CognitoMoto.com
Cool new items
« Reply #48 on: Mar 14, 2014, 15:03:57 »
3/8" (9.5mm) Rear Offset Sprocket and Spacer Combo for CB750 and CB550
Sprocket and spacer are made from 7075-T6 certified Aero Space grade aluminum. Spacer provides 3/8" (9.5mm) of offset for the rear sprocket and designed to work with your factory sprockets as well. This will generally allow for wider rear tires (up to 160 wide tire). Sprocket is made to OEM specs but made from lightweight aluminum instead of steel. Combo is designed to match our front CB offset sprockets.
3/8 (9.5mm) Offset Spacer
Provides 3/8" (9.5mm) offset
Made From 7075-T6 Certified Aero Space grade Aluminum
OEM tooth configurations
Lightweight
For 530 Chain
http://bit.ly/LeV6eZ
www.CognitoMoto.com
« Last Edit: Mar 14, 2014, 15:06:33 by SpeedBump »
Offline englishwheeler
    • Meyerbuilt Metalworks
Re: Cool new items
« Reply #49 on: Mar 17, 2014, 22:21:27 »
Nice parts man!
Cliff
Cliff
