www.Moto-Madness.com
Author Topic: Major Manufacturer Wiring Colors  (Read 9827 times)
Offline Sonreir
  • Moderator
  • Oregon
« on: Mar 26, 2014, 11:34:42 »
Honda
Black+12V when ignition switch turned to the ON position
Black/WhitePower from kill switch to coils for vintage machines or switched ground for EI bikes
BlueHigh beam and left ignition coil for twins or cylinders one and four for inline fours
Blue/RedSwitched ground wire for the oil pressure light
BrownTail light and parking light
Brown/WhiteGauge backlights
GrayTurn signal main
GreenGround
Green/YellowBrake light
Light BlueRight turn signal
Light GreenSwitched ground wire for Horn
Light Green/RedSwitched ground wire for the neutral light
OrangeLeft turn signal
PinkAC voltage wire for single phase permanent magnet alternators
RedUnswitched voltage from battery (goes to ignition switch)
Red/WhiteDC voltage from rectifier to battery
WhiteLow beam as well as partial circuit AC voltage wire for single phase permanent magnet alternators and also used to carry voltage to the exciter on EM alternators (inline fours)
YellowPartial AC voltage wire as well as right ignition coil for twins or cylinder two and three coil on the inline fours
Yellow/RedSwitched ground wire for starter solenoid
Yamaha
BlackGround
Black/RedOil pressure
Blue+12V when ignition is on (primarily for running lights)
Blue/WhiteGround wire side of the solenoid
Brown+12V when ignition is on (primarily for brakes and turn signal relay)
Brown/WhiteTurn signal main
Dark BrownLeft turn signal
Light GreenLight failure indicator
GrayIgnition coil trigger wire (coil one for non-360° twins and triples and coil two on inline fours)
GreenRight turn signal and high beam
Green/WhiteMagnetic pickup for flasher canceller
Green/YellowFrom brake switch to brake light (some models)
OrangeIgnition coil trigger wire (for singles and 360° twins, coil three on triples, and coil one on inline fours)
PinkSwitched ground wire for the horn
RedConstant +12V from battery and from rectifier to battery
Red/WhitePower to kill switch and from kill switch to coils and solenoid
Red/YellowPower for signal canceller as well as the dimmer relay (some models)
WhiteAC from alternator to rectifier
YellowMultiple uses depending on model.  Will always be for low beam, but can also include ignition coil trigger wire for coil two on the triples, brake light (but not brake switch), AC relay trigger wire for reserve lighting unit and starter safety relay
Suzuki
Coming Soon...
Kawasaki
Coming Soon...
« Last Edit: Mar 27, 2014, 12:23:03 by Sonreir »
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline coalnation
  • Live long and prosper.
    • Barrier Islands Blasting
Re: Major Manufacturer Wiring Colors
« Reply #1 on: Mar 26, 2014, 11:47:09 »
Thank you!
"Now if you'll excuse me, I'm going to go on an overnight drunk, and in 10 days I'm going to set out to find the shark that ate my friend and destroy it. Anyone who wants to tag along is more than welcome. "
-Steve Zissou
Offline coalnation
« Reply #2 on: Mar 28, 2014, 09:26:45 »
This has already helped a lot.  Thanks again.
-Steve Zissou
Offline pterodactyl
« Reply #3 on: Mar 30, 2014, 12:38:42 »
That's most cool of you!
Will
08 Ducati GT1000
81 Honda GL500 pterodactyls are pterrifying sold
83 Yamaha xs650
98 Ducati M900S
99 Ducati ST4
Offline Tijmen
    • Currently working on a GN125
« Reply #4 on: Mar 30, 2014, 17:09:00 »
Here's a start for the Suzuki table, colors according to the Haynes manual for the GS,GN,GZ&DR125 1982 through 2005 . Pink is only used on some bikes, always goes to the CDI but not always from the same source. Neutral switch on the GZ's and from the Magneto on the DR's.
Suzuki
BlackLeft hand turn signal, and wiring from all turn signals to plugs.
Black/WhiteTo battery negative terminal
White/BlackBrake light switch
BlueNeutral indicator switch and alternator to igniter
Blue/BlackNeutral indicator light
GrayTacho and Speedo illumination
GreenSidestand switch and Horn
YellowBrake light and high beam
Yellow/GreenStarter switch and clutch switch
Yellow/WhiteLighting switch to dimmer switch
Sky Blue/Light BlueTurn signal main
Light GreenRight hand turn signal
OrangePower from ignition switch
Orange/BlackPower to kill switch
Orange/WhiteKill switch to coil and igniter
PinkTo CDI from neutral switch, magneto
RedEverything attached to the positive battery terminal, i.e. unswitched voltage from battery to ignition switch, DC Voltage from Reg/Rec to battery and battery to starter relay.
WhiteIgniter to coil
Ugh, the BCC on this site hates me.
I hope it's useful!
« Last Edit: Mar 30, 2014, 17:14:12 by Tijmen »
Offline Sherwood
« Reply #5 on: Apr 03, 2014, 23:55:24 »
good info
i think on the Hondas wired for Headlight Always On:
yellow/red is the power to the starter solenoid (black wire on solenoid is grounded to frame)
blue/white is power to the headlight (cuts out when button pushed and transferred to yellow/red)
« Last Edit: Apr 03, 2014, 23:57:08 by Sherwood »
Offline Sonreir
  • Moderator
  • Oregon
« Reply #6 on: Apr 04, 2014, 01:28:45 »
good info
Black wire is not ground.  Black wire is 12V when the ignition switch is on.
Blue/white is for front right running light for those bikes with running light / turn signal combos.
For always on bikes, it's the black/yellow wire that feeds the headlight switch.
« Last Edit: Apr 04, 2014, 01:31:08 by Sonreir »
Offline Sherwood
« Reply #7 on: Apr 04, 2014, 22:54:29 »
OK thanks
that's how it is on my CB200T at least
must be unique to that bike, maybe a few others too
I was able to run replacement switches from a CM185T (I did have to swap the plug for bullet connectors, but same wiring setup)
Offline Sonreir
  • Moderator
  • Oregon
« Reply #8 on: Apr 05, 2014, 14:04:10 »
OK thanks
I stand corrected.
Just checked the CM185 diagram and it all matches up with what you said.  Not sure what those guys were thinking... maybe they had some extra parts in the warehouse when they made the CMs.  :P
Offline Rock_Star
« Reply #9 on: Apr 13, 2014, 17:21:22 »
for hondas what gauge wires?
