Author Topic: Xs750 not starting after changing handle bars  (Read 5573 times)
Offline jxcktheripper
Re: Xs750 not starting after changing handle bars
« Reply #20 on: Mar 28, 2014, 14:37:33 »
Don't do thaaaaaaaat, it's easy. You've already done most of the hard work. All you have to do is disconnect some cables and reroute them, slide the right controls off a bit and sand where they contact the bars.
Besides, shops are too expensive
yeaa that's true.. Lol imma give it another go and I'll let you guys know how it turns out! Thanks mate!
« Reply #21 on: Mar 28, 2014, 14:38:32 »
found a pic, not sure you can see it but the cables are the ones from the apehanges the GL comes standard with and  I put the Euro superbike bars on.,
oh shit! That makes a lot more sense! LOL thanks mate!
Offline Maritime
« Reply #22 on: Mar 28, 2014, 14:53:35 »
you can see how the clutch cable routes harder to see the 2 throttle cables but they do the same thing out past the headlight bucket then back into the frame to the carbs.
Offline Maritime
« Reply #23 on: Mar 28, 2014, 14:55:18 »
Also, when you get them routed, fire up the bike and make sure when you turn the bars lock to lock the engine doesn't rev up or the clutch leaver doesn't move as that means the cables are binding.  Bad news in a turn to have your clutch slip or throttle rev up on you.
« Reply #24 on: Mar 28, 2014, 14:56:18 »
yeaaah I feel like that would work, I'm just afraid of detaching things and not being able to properly put them back
« Reply #25 on: Mar 28, 2014, 14:58:13 »
Okay, will do! And yeah that'd be bad news lol
Offline Maritime
« Reply #26 on: Mar 28, 2014, 15:00:30 »
Got to learn sometime, cables do not last forever and knowing how to change them out is a good thing.  Get a manual too if you don't have one already.  Pretty easy to remove the cable from the bar control and clutch lever end, you can probably leave it alone at the carbs and clutch and just arc it out and back smoothly to the controls.
« Reply #27 on: Mar 28, 2014, 15:02:15 »
Very wise words my friend lol I really appreciate the help! I'll try that.
