1977 CB750 Deviant Hell Ride
Tune-A-Fish said:
I got a pack of these: to try and it worked as this has, lots of dirt so i will do seals soon also.
M8 ,dont blow yer seal !!
They work well if you follow instructions used em all the time on my crosser even used em on my cb350f saved a lot of hassle theres a knack to it but worth the couple $$ :p :p
deviant said:
This diode trick didn't work. In fact, it made the Dyna seem as though it wasn't there at all. A little research may reveal why, but it runs like a champ now with a new Dyna and new Dyna coils, so I hardly give a fuck anymore.
I noticed a random spark when turning the kill off and realized i had wired it from the key and direct to battery somehow causing a misfire when switched ?? after tracing it and removing the from battery connection it would not duplicate
They're gate diodes, and I thought the stripe should be on the coil side. I may have wired them backwards, which doesn't make lot of sense to me, but whatever. I like a bike that runs well, and it's definitely way better than when I first got it going.
Sweet little petcock to adapt the Yammi tank.
JustinLonghorn said:
I've got to tell you man, I am a serious fan of this here motorbike.
Thanks, homey. Means a lot.
Putting it through the paces and tweaking it here and there. I wasn't happy with any of the off-the-shelf hardware, so I machined up a couple of bushes to hold the seat...
john83 said:
Did you ever get it to charging better?
I did. Apparently a bunch of reg/recs out of China were wired for the DOHC 750s. So, a little rewiring and it's been golden since.
Huh! Wonder if I was having a similar issue with the 550. What did you have to change?
I went with this reg/rec: http://www.ebay.com/itm/331288984721?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Notice no white wire on the reg/rec. White from the stator goes straight to the power buss. Yellows from the stator go to yellows on the reg/rec. Red to hot side of the battery and the kill switch. Green to ground.
What is a "power buss"?
Basically a bit of metal with studs that acts as a single power (or ground) source.
