1977 CB750 Deviant Hell Ride
you did awesome on that bracket
it does look like a dual piston honda gl650 or cb650 or even a 82 cb900 custom bracket would be just what you needed
the fork lower looks "about ": the same
Hey again, this may be a request way out of left field but any chance you igh be able to take a few pictures of the underside of your tank? I don't know if you remember but I am the guy who is also trying to fit a 500 tank on a 77 cb750 and I just want to get a bit of a better understanding of where to start "massaging" the tank haha. Love where your build is headed btw.
Cheers!
Andrew
Yeah, baby. 4 into 1 is my jam.
Test fit for action.
Went to an awesome pick and pull near my parents and pulled a cargo light from an '89 Ford Ranger pickup. Polished up the lens a bit with toothpaste, trimmed about a quarter inch off its profile and now I have. a tail light. My intention is to put two yellow LEDs for turn signals and one red in the center for a brake/running light...
Also picked up an SR500 fender from MrE. It works nicely as a fender, mud guard doomaflotchee here.
I got the SR fender roughed out for the oil bag and the seat base.
Welded a couple of mounting tabs to the fender and a tab on the frame from a VT fender. I never throw shit away, even random tabs I cut off of things.
Got the fender mounted a bit up in the frame and somewhat hidden away.
Now that the fender is shaped, time to smooth it back out...
Cheers!
Andrew
Those three spots and spread the lip a bit at the seat.
No problem.
Here is a front fender I'm considering. This is either SR or XS... I think. There are a couple of creases at the front that need smoothed if I choose to use it. I'm thinking it may be a little long, though...
Tail light time...
Got the LEDs in- 2 amber 1 red.
Cut the locking flange off the stock light base and holed it to fit the red bulb.
Shaped a piece of plexi to fit behind the lens face and to hold the turn signals.
Mounted in the housing with a cork gasket.
And remounted on the bike.
I need a battery. Just realized all the ones I have here are dead. Harness needs installed too.
Awesome... reminds me of my 87 ranger ;D where are the lights from? I have some that are neat like that but wicked harsh if pointed at yer iye :eek:
They're from Oznium. http://www.oznium.com/led-bolt They work really well as turn signals. I wouldn't say they are harsh, but plenty bright to be seen by cages. They should get diffused a bit by the housing. I suppose I could go with that tinted look that's all the rage around these parts. ;D I used a 16mm set with lenses on my CB360 for rear turn signals. These lack those domed lenses, but they're still waterproof.
deviant said:
They're are from Oznium. http://www.oznium.com/led-bolt They work really well as turn signals. I wouldn't say they are harsh, but plenty bright to be seen by cages. They should get diffused a bit by the housing. I suppose I could go with that tinted look that's all the rage around these parts. ;D I used a 16mm set with lenses on my CB360 for rear turn signals. These lack those domed lenses, but they're still waterproof.
Gonna have to give em a try, thanks for the link. the smoky look is a good idea for sure if it works with paint and style... or mask it and do red/amber (color mixed with clear paint), it works like a charm and if you paint a black pinstripe to break them up it really pops.
So I have a decision to make. Do I decide that the single front disc and rear disc is enough braking power, or do I go with the dual disc front end setup? With the SR caliper now mounted, I have a complete front end- front and rear discs mounted on the right side. I'll need to get the necessary digs to go dual.
It would require about a 4mm shim on the bolts. Strangely, the dual disc wheel is narrower. I'll need to add a shim on the axle as well. The single disc is from a KZ650 and the dual disc is from a GPZ550.
