1980 Honda CM400T Hardtail, First bike build
dcdownard87
Hey guys bought this bike for $300 and it is my first bike,but wanted to customize it. So I decided to build a hard tail out of it
Re: First bike build. Honda cm400 hardtail
The bike idled a little rough, so i cleaned the carbs and still the same thing. I tested the compression and both cylinders were about 100psi and i think spec is 150psi. So I found out the head gasket needed replaced. so I tore the bike down to the bare frame and started to get to work on it.
Started to experiment with some ride heights and different handlebars that I had aquired.
I had one thing in mind to try buy in the end didnt like how it turned out.
So didnt like how it was looking. I chopped it all off and it is a hard tail. I ended up streching it about 6in.
This is where sits right now. Its going to get sandblasted and powdered coated this week while Im away for work.
Nice work so far. Looks like you know how to do it correctly. My first bike was a CM400 too.
Cheers
Maritime
Yeah im a bigger guy 5'11" about 230lbs, plus I have always liked the looks of hardtails.
I quite like my little cm400... Interested to see where you go with this one. Good luck
