www.Moto-Madness.com
Author Topic: GS650E First build  (Read 4673 times)
Offline japstar
Re: GS650E First build
« Reply #20 on: Jul 12, 2016, 16:38:05 »
I encoutered slightly corroded jets in my bike. (green like corrosion on brass parts).
I used jet reamers to clean out those holes. Do that by reaming the holes till you stop finding green residue on your reamers, than you've hit the stock size. Make sure your carb cleaner squirts out of all corresponding holes when spraying down a passage. (clean spray, not dripping)
GPZ550 cafe racer http://www.dotheton.com/forum/index.php?topic=69514.0
It ain't about showing up on a bike that the loan officer at your bank, or your parent's inheritance bought for you. It's about skinning your knuckles, straining your back, developing some blisters on your hands, breathing varsol and paint fumes,taking measurements and making mistakes.
It's about standing back, after the dust settles, and being able to say when people ask, "I BUILT it!"
Offline schwartzy1024
  • Schwartzy
« Reply #21 on: Jul 12, 2016, 17:10:24 »
Thanks for the help guys. I quickly learned a ton from forums, my clymer manual and other various places to correct a few issues. I found I wasn't getting gas into the carbs so I started there. My petcock wasn't opening from the vacuum on the carb so I corrected that issue and had plenty of fuel in the carbs. I could get the bike to start with starter fluid and determined that the pod filters were giving WAY to much air (I know, POD filters are discouraged, lesson learned)  The air/fuel mixture was VERY lean, so I upped my pilot and main jet a good bit. I moved the main jet from 97.5 to 110 and I could get the engine to rev all the way with little hesitation. I upped my pilot jet from 42.5 to 47.5 due to a starting issue.  Both have resolved most of my issues. I found that under load, the bike didn't want to pull through the high end of the RPM range, so I just got slightly larger main jets 115. Hopefully this corrects that issue.  While out on my second ride, the battery drained completely and I have to work through a charging issue now :(  I just want to ride the damn thing and not worry hahaha. So close.
Don't reinvent the wheel, find ways to make it roll faster!
Offline Jonny_C
« Reply #22 on: Jul 12, 2016, 17:36:34 »
Looking good!  Thanks for the larger picture.  The tank looks pretty good for just a wrap.  Although painting them yourself isn't very hard if you ever want to go that route.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #23 on: Jul 12, 2016, 22:13:13 »
Yup these bikes are known for their shoddy charging systems. Here is a link that will help: http://www.thegsresources.com/statorpapers1.php
Aftermarket stators are available as well for a reasonable price, as well as used on eBay for cheap (but you get what you pay for). I'll be doing the stator on my GS this week.
  • Schwartzy
« Reply #24 on: Jul 12, 2016, 22:27:04 »
I got the stator issue figured out. I think there was a slight issue with the ground and where I had the positive connected. I hooked up a 30amp fuse and hooked it directly to the battery, seems to be charging (checked with the volt meter).  Just tried to go for a ride but I am still fighting the fuel issue.  I have taken the carbs off a number of times and played with jetting. I think I have the main and pilot jets figured out but the bike wants to cut out around mid throttle. I don't think there is an adjustment on the needle, so how could I go about "shimming" that?  I need to pull them off (yet again) and do a double take.  I'm open to ideas!
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #25 on: Jul 12, 2016, 22:35:02 »
So you ended up connecting the hot wire from the R/R through a fuse and to the (+) on battery? Did you ground the R/R to the batt as well?
  • Schwartzy
« Reply #26 on: Jul 12, 2016, 22:37:27 »
More or less. I have a "main" ground spot on the frame where the motor and 2 other items all ground together.
Offline AlphaDogCustoms
  • Science is true whether you believe in it or not.
    • Alpha Dog Customs
« Reply #27 on: Jul 13, 2016, 13:29:59 »
You will NEVER get the jetting right until you throw away those shitty Emgo pods. They partially block important openings in the mouth of the carbs. Not only that, they are metal mesh, and fine dust goes right through them.
Get the correct K&N pods and save yourself some drama.
...every dump I take is original too, and it doesn't smell any better because of it's originality.
Alpha Dog Custom Cycles
Painting
Powdercoating
Custom Fabrication
Repairs
I'm so old, I even know what ignition points are.
Offline hillsy
« Reply #28 on: Jul 13, 2016, 22:01:52 »
Why did you cut the frame above the rear engine mounts?
Offline bobdizzle
« Reply #29 on: Jul 14, 2016, 00:21:41 »
Hi, new here, working on a gs1000. Your bike looks great!
I'm wondering if you have any pictures of what you did with all the electronics in the rear triangle and any advice on moving those under the seat?
I was thinking I could pretty much just flip that panel up to lay under the seat. I'd appreciate any advice!
Thanks
Sent from my SM-G920T using DO THE TON mobile app
