www.Moto-Madness.com
Author Topic: 1979 Honda CB400T II Hawk Scrambler: Woodward Designs  (Read 4446 times)
Offline silverstonepgt
  • The Beerfish
The bike as it sits now, with a new black headlight bucket with mesh guard, new black superbike bars, oxblood Biltwell grips, a borrowed garage sale seat, and small gp style hand controls from Dime City Cycles. Fork lowers to be painted black, fork gaiters are bunched up on the front tire waiting to be installed, and the headers are at an exhaust shop getting 14" straight pipe extensions w/ 13" baffles that will feed into two Emgo shorty mufflers:
The bike after the motor swap:
The bike last year on the tail of the dragon:
A little backstory: my brother and I have had several projects over the years, and the current CB400 I'm working with is a bastardized conglomerate consisting of a 1980 Hawk electric-start-only engine and various bits attached to a 1979 frame/tank/forks/wheels that was originally bought as a spare parts bike we wanted the kick/electric motor from.
We've also worked with a couple Kawasaki KZ550s over the years. Here's some random pics:
« Last Edit: Jul 13, 2016, 13:08:17 by silverstonepgt »
1980 Honda CB400TII Hawk fighter
1983 Kawasaki KZ550LTD bobber
  • The Beerfish
« Reply #1 on: Jul 13, 2016, 12:57:45 »
As it sits now:
« Last Edit: Jul 13, 2016, 13:04:23 by silverstonepgt »
  • The Beerfish
« Reply #2 on: Jul 16, 2016, 01:41:48 »
A bit more work done. Got the throttle tube trimmed down, master cylinder installed (needs replacing with something smaller though), found the correct diameter clutch lever adjustment collar, and slipped the baffles in the pipe extensions, drilled mounting holes, and mocked everything up before finalizing fit/wrapping the pipes tomorrow.
« Last Edit: Jul 16, 2016, 07:47:58 by silverstonepgt »
  • The Beerfish
« Reply #3 on: Jul 16, 2016, 07:33:02 »
Also, to deal with the Hawk's ugly stamped frame I took a bunch of measurements and then bought a seat off of a newer Hinckley Triumph - this should fit well and cover some of the frame.
I'm going to try and modify the bike to fit the seat rather than the other way around, then any triumph seat should bolt on.
Here's the one headed my way courtesy of eBay:
Also ordering this master cylinder because mines pretty ugly:
« Last Edit: Jul 16, 2016, 07:52:58 by silverstonepgt »
  • The Beerfish
Re: 1979 Honda CB400T II Hawk Scrambler: Woodward Designs
« Reply #4 on: Jul 18, 2016, 01:58:45 »
Some more work done today - cut down the wiring harness a bit, blew a few fuses, mounted this temporary seat to be able to ride this week, wired the taillight, mounted the plate, etc.:
  • The Beerfish
« Reply #5 on: Jul 19, 2016, 01:47:58 »
Wired the clutch safety circuit closed (just gotta be careful not to start it in gear) in order to avoid relying on the finicky neutral safety switch.
Also redid an old botched wiring job, and now it starts immediately, runs well, and is on the road!
  • The Beerfish
« Reply #6 on: Jul 20, 2016, 16:52:11 »
My Triumph Bonneville T-100 seat came earlier than expected, so here's how it fits the profile of the CB400T with no modifications (just sitting on the frame rails):
Next step is to investigate mounting the seat by only modding the bike. (I'd like any Bonneville seat to essentially bolt right on).
« Last Edit: Jul 20, 2016, 16:57:33 by silverstonepgt »
Offline Redbird
  • Dolor est Magister Optimus
« Reply #7 on: Jul 22, 2016, 11:27:04 »
Scrambler?
When you are Dead, you don't know that you are Dead. It is difficult only for Others.
It is the same when you are Stupid.
  • The Beerfish
« Reply #8 on: Jul 23, 2016, 00:31:58 »
Scrambler?
Well, tires are a clear next step, and I'd like to weld clevis mounts to the frame to be able to run taller Progressive shocks. After that, figuring out fenders.
It's a work in progress, with the caveat that I want it rideable in between mods because it's summer.
Any thoughts on what else to call it?
FWIW, I never knew what "style" to call the last one either:
Offline NoRiders
« Reply #9 on: Jul 23, 2016, 05:45:56 »
Good to see you riding it while you modify it. Tyres will make a mahoosive difference to the overall look as will another shorter/smaller seat. Not cheap items but along with the tank can define the style of any bike.
Guards could look a bit like mine, cheap used swap meet items....
Urban or street scrambler might work?
