www.Moto-Madness.com
Author Topic: 75' KZ400 Tracker/Enduro: Near Completion  (Read 6808 times)
Offline AimlessMoto
  • Blood, sweat and beers.
Re: 75' KZ400: 2017 Updates!
« Reply #40 on: May 17, 2017, 21:13:12 »
Annndddd..... done!
Offline Maritime
« Reply #41 on: May 17, 2017, 22:35:16 »
Nice job, looks great
Offline cyglide
« Reply #42 on: May 19, 2017, 10:49:55 »
Nice! I may have missed it, but what handlebars did you use?
Offline AimlessMoto
« Reply #43 on: May 19, 2017, 14:38:55 »
Just standard 7/8 super-bike bars. Parts-Unlimited specials through Bike Bandit.
Offline AimlessMoto
« Reply #44 on: May 21, 2017, 13:55:25 »
So, took it for a maiden in its new form, and i absolutely love it. One problem... it left me stranded 45 mins into the ride. I got a jump from a local, and was able to get home by keeping the revvs up above 6k the whole way.
Got it into the garage and did a quick recon. Battery at 10v, r/r showing good resistance on all 3 poles, then started it and checked each leg of the stator.  1 was at 50a, one at 55a, and one at 0. Checked with a beeper and its not grounded... just open.
So I checked the donor bikes stator (luckilly it was off and I could bench test), and all 3 legs are good... no ground outs, and all show 0.9-1.0 ohms resistance between all legs + and -.
Looks like Im moving forward with a stator swap.
Offline Maritime
« Reply #45 on: May 22, 2017, 11:55:48 »
Sucks it tanked but good you have a spare to swap in
Offline AimlessMoto
« Reply #46 on: May 24, 2017, 22:07:34 »
Found out the problem wasnt really a problem... it was a parts issue. I left the stator for the kick-start engine in when i installed the starter from the other bike. Turns out they are different part numbers... and the kick-start stator isn't 3 phase.
Swapped the stator in about 20 minutes. Fired it up with 11.6v on the battery and it quickly jumped to 13.7v with a steady throttle at 3k rpm. The old stator would barely keep above 12v when running.
Test ride tomorrow!
Offline AimlessMoto
« Reply #47 on: May 28, 2017, 15:23:03 »
Woohoo! Got the new stator in and its charging perfectly!
After the bike warmed up (this has been a constant problem) the idle went wonky. I tore into the carbs again... balanced them, did everything in the book... until I found the answer.
I installed the butterflies backwards and they werent sealing. Didnt even notice they were tapered on the edges. Flipped them around... re-timed, did the valves, checked the points, gapped the plugs, balanced the carbs again... and we have a runner! Let it idle for a good 10 minutes... kept blipping every minute or so..  rock-steady idle! Even with my pods and custom pipes, shes a runner! Now to put some miles down!
All the extra tinkering led me to build an actual bike bench... shop is coming together.
« Last Edit: May 30, 2017, 08:17:53 by AimlessMoto »
Offline Luugo86
  • '73 CB350, '78 XS650 Cafe Killer
    • ToadStool Cycle Co.
« Reply #48 on: May 28, 2017, 17:06:38 »
wish the photos werent upside down... thats a sharp lookin bike man
Live to Die, Die to Live
Offline AimlessMoto
« Reply #49 on: May 30, 2017, 08:14:25 »
Hahaha, didnt even notice that... let me fix...
« Last Edit: May 30, 2017, 08:19:14 by AimlessMoto »
