It's funny you say that...some of my buddies say leave it and others say paint it...I have a black tank , side covers and headlight bucket. It all comes down to time. I need to get it running and rideable before we go on a weekend trip in May. If I can, I will repaint it and if not, it will be blue for a little while longer
Carbs, airbox, and battery tray are secure. I am running the carbs from my '74 which were jetted for velocity stacks and 4-1 exhaust so they will have to come back off and be re-jetted for the stock airbox and 4-2 pipes
JsJamboree (Jordan) worked is solder magic and shortened the clutch cable to perfection. Then he and Tifun (Keith) are argued about the proper way to check connections and wiring until we ultimately called it a night and unplugged everything.
My mufflers and battery will be in tomorrow and still have a few small bits to order.
I still need to get a spiltter and dual brake lined for my CB750 super sport brake setup for the front. For now i will run a single side setup utilizing my stock MC.
Nice. I've had luck bracing fiberglass fenders with a strip of 0.125" steel either riveted or epoxied to the backside of fenders, depending on what look you're going for
Made progress last night, even though it looks more disassembled.
Completed wiring and had to swap starter solenoids for a good one. Pulled the front end off for rebuild. Tires got mounted today. Hope to have it running by the weekend
