www.Moto-Madness.com
Author Topic: xs650 Sumotrack  (Read 19655 times)
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #60 on: Sep 15, 2017, 15:14:12 »
2 more braces and the frame is basically done.
Xs650
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #61 on: Sep 30, 2017, 19:40:43 »
Small update.  Wheels picked up, rear caliper needs maybe 1/32" trimmed off a corner to clear the spokes right at the hub, front everything clears by plenty.   Rear wheel is kz750 hub laced to a 17x4.25 rim, front is the modified cb550 hub laced to a 17x3.5 rim.
  Seat tube is being modified for a recessed LED integrated strip light.
  Next big things are finish the headlight/number plate, start wiring, and exhaust.
Xs650
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #62 on: Oct 13, 2017, 22:19:19 »
Slight update, been busy at work, and weather has been bad but bends are ordered for the exhaust.  Going to be 1.5" out of the heads, then step up to 1 5/8" go under the engine merge into 1 2" and out the right side.  There will be a bung welded in right after the merge for a wideband O2 sensor.
Xs650
Offline jerrett
Re: xs650 Sumotrack
« Reply #63 on: Oct 20, 2017, 09:47:57 »
Great work so far. Can you post some more pics of how you are modifying the rear hoop to take the led strip? I'm thinking about doing the same thing. Thanks
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #64 on: Oct 24, 2017, 21:04:15 »
Yeah, I actually cut a few parts for the tail light at work today.  Could have done it at home, but a waterjet can do in 3 minutes what would take me much longer with an angle grinder.  I'll probably get out there to work on the bike tomorrow and will get some pics then.
Xs650
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #65 on: Oct 25, 2017, 20:38:46 »
Ok, to do the recessed LED tail light I did a few things.  1 I measured the light, 2. I figured out the center of the tail and how much height would be added by the sheetmetal.  3. I took this info and marked out where to cut on the hoop, 4. I then cut 3 pieces and turned them into 1 to install in the hole I cut.  Then I welded it in place and started in with a flap disc to smooth it all out.  I still need to cap the ends to stop water from having a way into the tube.
Xs650
Offline Luugo86
  • '73 CB350, '78 XS650 Cafe Killer
    • ToadStool Cycle Co.
Re: xs650 Sumotrack
« Reply #66 on: Oct 25, 2017, 22:27:37 »
looks good man.. Did you just use an angle grinder to do the cutting? Seems like that would be a pain in the ass to cut lol
Live to Die, Die to Live
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #67 on: Oct 25, 2017, 22:38:45 »
On the hoop yes, angle grinder with a cut off wheel and flap disk to clean up.  Not that bad to do, but it helps to mark it out well and cut inside your lines.  Then grind/sand to the line.  Cutting the pieces that went in the slot, I was lazy and used the waterjet at work.
Xs650
Offline CrabsAndCylinders
Re: xs650 Sumotrack
« Reply #68 on: Oct 25, 2017, 22:56:35 »
Very nice!
Lighter, Quicker, Faster.
Offline jerrett
Re: xs650 Sumotrack
« Reply #69 on: Oct 26, 2017, 08:42:34 »
Thanks Rat_ranger. Love that install. So clean...
