der_nanno said:Sparck, why would you do that? The relay has already been proven to work and even with the relay taken out of the equation (bridging it) the same fault occured as such this is a good mod to give the relay proper ground, but it will not solve the problem.
I don't think the issue is with the flasher relay, I think the issue might be with the canceller.
Automatic cancellers generally work on one of two ways (which is why I suggested both). They either complete the ground on the third wire of the flasher relay or the break the ground on the third wire. By disconnecting the yellow/green wire on the relay, we can check for both of these things.
