www.townmoto.com
www.Moto-Madness.com
Author Topic: '71 T500  (Read 2889 times)
Offline Hurco550
  • life is short, smile while you still have teeth
Re: '71 T500
« Reply #30 on: May 25, 2017, 12:41:17 »
Great stuff in that post Hurco550. Have an HF about 10 minutes from here, so off I go.
Interested in your statement above about "upon inspection." How do I inspect them to know whether mine are also weak/stuck? Can get the banjo seals at Earl's on Gasoline Alley, so will likely follow your lead on replacing those too.
Thanks man. I simply watched the oil lines after i fired it up and saw air going back from the banjo fittings on the case (aka the wrong way)
An easy test to see if the check valves are stuck would be to block one end of the banjo fittings where it bolts to the case and pump oil back towards the pump from the other fitting. Oil should not go past the union where the check valve is. If it does, continue to flush the lines with alcohol till they are goop free and start to seat again. Continue testing til the desired results are achieved.
I bought those seals through, mc-master carr. If you can get them locally I guarantee that they will be cheaper lol
Once it is time to fire it up, it is a good idea to run some pre mix in the tank until everthing is thoroughly purged out in the auto lube system. It will be a bit rich with oil, but to much oil is the lesser of two evils than not enough.
Also, remember that the oil pump doesn't move fluid very rapidly, especially at idle, so don't panic if you don't see whatever little air bubbles you have left moving through the system in a hurry.
there is a procedure to 'calibrate" your pump to the throttle opening as well. There should be a threaded cap over the slide tube on one carb. upon removal, you open the cap to view the slide. you open the slide til you can see a mark on the slide and at that position the arm on the oil pump should be lined up at a mark on the pump itself..
Keep er' Between The Ditches!!!
1973 Ironhead Hardtail: http://www.dotheton.com/forum/index.php?topic=68135.msg788081#msg788081
"much ingenuity with a little money is more profitable and amusing than much money without ingenuity" - Arnold Bennett
Offline Hurco550
Re: '71 T500
« Reply #31 on: May 25, 2017, 12:46:27 »
I understand it is getting difficult to find the crankseals. Did you have any trouble getting it rebuilt?
seals aren't hard to find for these really, this is just an ebay set for the whole motor, but individuals can be had as well from numerous parts houses
http://www.ebay.com/itm/Suzuki-T500-Oil-Seal-Kit-Engine-Titan-1968-1969-1970-1971-1972-1973-1974-1975-/382073965595?hash=item58f5620c1b:g:gpEAAOSw5VFWHauO&vxp=mtr
Offline oldrookie
Re: '71 T500
« Reply #32 on: May 25, 2017, 13:43:06 »
Thank you. Again, great information. Appreciate your willingness to help a newb.
Offline Hurco550
Re: '71 T500
« Reply #33 on: May 25, 2017, 13:46:28 »
Hey no worries man, glad I can be of help. That's what makes this forum great, people helping each other. And I also really wanna see this thing back on the road =)
Offline oldrookie
Re: '71 T500
« Reply #34 on: May 25, 2017, 18:09:50 »
I hope you are a patient man.  ;D
Offline Hurco550
Re: '71 T500
« Reply #35 on: May 25, 2017, 18:20:18 »
Ive got all the time in the world my friend =)
Offline johnu
Re: '71 T500
« Reply #36 on: May 26, 2017, 16:35:04 »
I sent my crank to Bill Bune to do the strip and seal install.  i had trouble getting one of the seals but i can remember which one.
Online Sonreir
  • Moderator
  • Oregon
Re: '71 T500
« Reply #37 on: May 26, 2017, 16:40:56 »
What was the cost on that, if you don't mind me asking?
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline Hurco550
Re: '71 T500
« Reply #38 on: May 26, 2017, 17:59:12 »
Bill bune has a great reputation for sure. I've never heard much bad about his work
Sent from my SM-G900V using Tapatalk
Offline johnu
Re: '71 T500
« Reply #39 on: May 30, 2017, 10:56:28 »
If I remember right it was $165
