www.Moto-Madness.com
Author Topic: Quick DOHC Carb Question  (Read 655 times)
Offline 88SS
« on: Jul 12, 2017, 22:31:34 »
80 model cb750f super sport, keihin carbs.
Quick question: (there seems to be debate within my group of friends)
The top puck, with the slide needle,..... is the slide needle supposed to be loose, where you can wiggle it? Or tight, where it doesn't move?
They are of the non-adjustable variety. Meaning there's no clip.
I say they are supposed to tight. What's the proper way?
Offline hillsy
Re: Quick DOHC Carb Question
« Reply #1 on: Jul 12, 2017, 23:38:00 »
They have to have some movement or else they will gouge the seat / themselves out with operation - so, they shouldn't be "tight". There should be a spring either holding the needle down in the slide or up against the retainer. Either way, there should be allowance for some lateral movement.
Offline 88SS
« Reply #2 on: Jul 13, 2017, 17:34:36 »
Interesting. A spring between the top of the needle and the threaded bushing that holds it down? The retainer in the puck, right? I've got 3 carb banks and none of them have a spring in there. There is a spring under the cap, and on top of the puck. Is there usually another spring?
The needles on my running bike are loose, but I'm having idle issues. That's the reason I've been asking around. I know it's likely an air leak issue. I'm just trying to eliminate all possibilities before I break the bank apart. I'm just being lazy lol
I've had people tell me both ways however
Offline cxman
« Reply #3 on: Jul 13, 2017, 20:57:50 »
the needle should be loose as you describe
no there is not supposed to be a spring pushing on the needle
its on the top of the slide under the cap
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Offline 88SS
« Reply #4 on: Jul 14, 2017, 00:41:46 »
Ok. Good. That's the way they are.
I've probably got an air leak somewhere. It's the only logical explanation at this point. I can't find it on the boots, and I don't think it's there. I'm thinking it's probably in the rails. That or air shutoffs.
One more question... there's a nipple on the bottom of the stock airbox, with no hose on it. What does that go to? Just a moisture drain? The hose on top is attached and runs to a collector box, but nothing is attached to the bottom nipple
Offline hillsy
« Reply #5 on: Jul 14, 2017, 01:01:15 »
Yes the bottom nipple is a drain. If it is open then it should have a hose on it with a one way end so unfiltered air cant enter.
Offline 88SS
« Reply #6 on: Jul 14, 2017, 17:32:36 »
Gotcha. Thanks a lot for the info.
Offline 88SS
« Reply #7 on: Aug 06, 2017, 23:03:18 »
Thought I would give you guys an update. I finally bit the bullet and broke the carb bank apart. The idle problem was %100 the air cutoffs. They were completely corroded, to the point I had to pry them out with a screwdriver.
I got everything back together, and was finally able to get a good sync. She runs like a scalded dog. I feel pretty good about it
