www.Moto-Madness.com
Author Topic: Wiring Lengths - How important are they?  (Read 691 times)
Offline black350
« on: Aug 01, 2017, 12:04:43 »
How critical is the length of a wiring run? How much does the resistance of wiring come into play in this application?
I'm making a harness from scratch and I plan on only giving enough length to meet my components and a few extra inches on some runs to make changes later on if necessary.
My electronics box is small and the run from the battery + to the fuse (cb350) is only about 3 inches total. Would this be too short of a run? I was thinking I could snake the wiring around the box to give it a little more space but I'd like to be sure. Is there a way to calculate how long a run should be or should it be fine if not taken to extremes?
Offline SONIC.
Re: Wiring Lengths - How important are they?
« Reply #1 on: Aug 01, 2017, 12:07:26 »
On a motorcycle it doesn't make an appreciable difference. Use the correct wire gauge for the load, and minimize lengths on high load items (headlight) and you'll be fine.
There's no such thing as too short of a wiring run!
Offline irk miller
« Reply #2 on: Aug 01, 2017, 15:23:27 »
There is if it's feeding to one of the handlebar controls and disconnects connectors when you turn the handlebars.   ;)
In most cases, voltage drop doesn't become a real issue for at least 50ft.  For a 3amp circuit, the voltage drop on an 5ft length of 18ga copper AWG is only about 1.5% which is like 1/5th of a volt.
Offline SONIC.
« Reply #3 on: Aug 01, 2017, 16:44:24 »
I know someone would have something to say about that ha!
Very good point
« Reply #4 on: Sep 12, 2017, 12:58:14 »
I leave mine 5-6 inches longer and fold a section under my tank, it's like 3 2 inch sections stacked per wire (I use all black wires cause I know what there for) that way if I move something or put something else I have a tiny bit of wiggle room and it doesn't effect the look of the harness. I don't wrap my wires I just use all black wires solder and black shrink wrap then zip tie it with black zip ties.
Offline canyoncarver
  • 'hacking is learning'
« Reply #5 on: Sep 12, 2017, 13:19:28 »
You use all black wires?  I pity the next owner of that handiwork.
YZF750/1000R The Fly
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
65 Norton, My damn Shovelhead chop, and an 86' FXR
more YZF750R's, the KZ's, a Zephyr750...and the unfinished 75' CB550 cafe.
« Reply #6 on: Sep 12, 2017, 13:23:43 »
Yup! Haha that's what everyone says. But they will learn!
« Reply #7 on: Sep 12, 2017, 13:27:38 »
But why?  The same wire in different colors is cheap!
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
« Reply #8 on: Sep 12, 2017, 13:31:34 »
I have other colors. Cause I hate wrapping it in tape it gets nasty
Offline Sonreir
  • Moderator
  • Oregon
« Reply #9 on: Sep 12, 2017, 14:28:58 »
Aside from tape, other options exist. ;)
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
