www.Moto-Madness.com
Author Topic: Starting troubles  (Read 1185 times)
Offline Xs7501978
Re: Starting troubles
« Reply #10 on: Sep 11, 2017, 12:14:18 »
Haha okay so maybe that should be added to my to do list
Though the circled section doesn't look too good, either.
Offline datadavid
« Reply #11 on: Sep 11, 2017, 13:28:02 »
Your middle cylinder looks like there has been water in it. Plug isnt supposed to look like that. And your battery is NOT supposed to have 17 volts.
Offline Xs7501978
« Reply #12 on: Sep 11, 2017, 13:35:53 »
It has had water in it? Like through the carbs into the engine? Is it going to die? And it starts around 13 and then slowly goes goes up until it reaches around 16.6 when I plug my multimeter up to it
Offline Sonreir
  • Moderator
  • Oregon
« Reply #13 on: Sep 11, 2017, 13:38:26 »
15V is about the maximum safe voltage. Looks like it might be time for a new regulator.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline Xs7501978
« Reply #14 on: Sep 11, 2017, 13:45:28 »
Okay but it that going to be the prob with the starting issue?
Offline Sonreir
  • Moderator
  • Oregon
« Reply #15 on: Sep 11, 2017, 13:55:56 »
No. It would be unrelated.
Offline Xs7501978
Starting troubles
« Reply #16 on: Sep 11, 2017, 14:19:18 »
Okay I should still get one anyways, I'll order one. What tests do I need to do for the starting issue? I'm thinking it just doesn't have enough power sometimes, like I just tried with a battery charger set on low and that boost helped it start right away....
« Last Edit: Sep 11, 2017, 14:25:56 by Xs7501978 »
Offline Xs7501978
Starting troubles
« Reply #17 on: Sep 11, 2017, 15:28:39 »
Here's some videos
This is still with the 16 voltage battery
This is with a jumper just to show it does start and what it sounds like normally.
Offline Xs7501978
« Reply #18 on: Sep 11, 2017, 21:28:43 »
had the same issues with my XS 750 which was converted to your later transistor ignition.
1)check your battery voltage, if its under 12v you will not get proper spark.
2)thenI would check spark on all cylinders.
Do you have fat nice spark on all 3 cylinders?
3)if there is no spark on some of the cylinders I would cut a bit off the ignition cables (1cm) and then put them back into the spark ignition coil.
swap around ignition coils,check the plugs on the coils.
My issues were a combination of bad connections in the loom and a bad ignition box.
1 battery is has to many volts as I've been told...
2 I have spark, just not big and fat on 2 of them...
3  so you wanted me to cut 1cm off of the end under the tank? And then move the connections around, to test if one is bad?
Offline datadavid
« Reply #19 on: Sep 13, 2017, 04:57:57 »
Start by cutting off the end by the plug cap, they are usually worst. And replace that rusty apark plug..
