1981 cm400t neutral switch
mada1594
Hello guys I am wiring up my cm400t but for the life of me I can't figure out where the neutral switch is. I looked thru my manual and can't find it. Can anyone help me thanks!
maybe on top of the crank case under the carb. Can you take a photo of the Crank case both sides and post it in reply? might be able to spot it.
Yup. That's the one. It sits right in the middle of the top engine case, right under the carbs.
Is that it?
Sonreir said:
Check the wire colors. Light green/red is neutral. Blue/red is oil.
Yupp that was the mistake I red the wiring diagram wrong the oil and neutral switch wires were harnessed together so I thought it was all one unit but now I see one is the oil and the other is neutral. Thank you for the help! :)
