I have the Emgo Key switch going into my CB550. I search online and apparently these tend to fail without a relay.
Can someone pls assist in wiring the key switch > relay > munit?
Emgo Key switch wires:
- red: power?
- black: ignition?
- brown:
- brown/white:
Relay wiring:
- Key switch red wire —> fuse —> battery.
- Key switch black wire —> #86 on relay.
- #85 relay —> ground (frame).
- Battery —> fuse —> #30 on relay.
- # 87 relay —> munit ‘lock’ input.
Is the above correct?
Thanks,
- red: power?
- black: ignition?
- brown:
- brown/white:
Relay wiring:
Thanks,
