Re: Nixon - '72 CL450
Made some progress taking the engine apart last night. My cam chain breaker came in (props to
SportingForLess for super fast shipping) and I was able to get the cam chain apart so I could get the head off. BTW, when they tell you to tie the chain off with wire so it doesn't fall in the engine, don't use electrical wire. Mine broke, but luckily I hadn't pushed the link pin out all the way and it got caught on something before falling down into the deep dark engine case. I grabbed some wire hangers and they worked great.
Got the head off and the pistons and cylinders look OK. I had low compression so I think some new rings and a good honing will do the trick. I'll have to get them measure though to make sure. However, I am considering getting the big bore kit. I'm going to get a price on the cylinder boring and decide then. What's a typical price for that?
The valves look like they have a lot of weird brown colored crud on them. Not carbon, lighter. They are going to need a good cleaning. I could see the one that I bent was not closing all the way. Definitely going to need to be replaced. Next step is to get it out and check the valve guide.
I did find another problem though. I noticed the pin for the cam chain roller that is visible seemed loose. I could actually take it out very easily. Seemed like it wasn't going all the way through the bracket on the other side. After looking up the part online, I realized that the pin shouldn't be removable and that end is supposed to be deformed like a rivet. It looks like that deformed part has popped off. Guess I'm in the market for a new roller. :
[edit] Bought.....Ebay to the rescue [/edit] [edit]Damn! Bought the wrong one. [/edit]
How did this thing not explode when I took it up to redline?
