crackerman
Started to work on my 80 kz750 t. First thing on the agenda is to fix the starter clutch issue and clean the engine. I plan on PC some of the piece of the engine and painting the rest. I'd like to get the engine squared and running before moving on to the other stuff. Just picked up a junk 81' KZ750 4, that I want to use the 18' rear tire. Not sure it's going to work, as I'm hoping the entire rear swing arm just bolts up. Plans are to add the 18" disc wheel to the rear and blackout the wheels, loop the rear frame, add a fender to the rear, modify the seat, build a completely new wiring harness from scratch, mini speedo, Renthal bars, and smaller headlight. Going to be a slow build. Here's some pics.
Before the breakdown:
Starter clutch out. Springs were broken and you can see the hairline crack in this piece:
Wanted to lighten her up. Nice and light now.
