alex2445
Well, it wasn't so much as the PO fucked everything up, but that he lied to me. We thought that why the engine wouldn't move was because he fucked up the cam timing after he put the head back on and now the piston was against a valve. That would've been a blessing. No, it wouldn't move because the connecting rod is broken and the crank shaft is jammed against the connecting rod. I'm sure you're all thinking "well you should've known it was seized up when you bought it". Well we didn't because he loosened the bolts on the clutch so that it would slip enough to allow the bike to move. Lesson learned, don't buy a bike that even has a hint of being a POS. I don't know what's going to happen next, I called him and he didn't pick up so I left a message. Most likely he won't give me my money back. So I get to rebuild the engine. Enjoy the pictures.
