Author Topic: "La Pastinaca" CB450 498cc Big Bore Engine Built By DWMS Racing!  (Read 67459 times)
Offline joeyputt
  • The green flag sets me free
    • dwmsracing
Today I installed the three guide pins, new stud seals, a new copper head gasket, a new front cam chain guide roller assembly, a new rear cam chain guide roller, and the cylinder head on the engine and torqued all of the head nuts.
I spent most of yesterday afternoon doing the final sanding on the cam bearing housings so today after I installed the cylinder head I polished them some more and am now ready to install the cams, rockers, and rocker shafts.
« Last Edit: Aug 16, 2011, 04:06:13 by joeyputt »
Joe - Owner/Operator of DWMS Racing World Class Engine & Motorcycle Building www.dwmsracing.com
Cylinder Head Porting Sale! http://www.dotheton.com/forum/index.php?topic=56203.msg637024#new
Facebook https://www.facebook.com/joe.dwmsracing
Offline joeyputt
    • dwmsracing
Re: "La Pastinaca" CB450 New photos! Cams and rockers installed
« Reply #141 on: Aug 17, 2011, 12:30:20 »
I did a lot of work on the cylinder head yesterday.
Here is a photo of the new cam bearing housings after I polished them.
I installed the rockers that we had welded and resurfaced, the rocker shafts, seals, and the lash caps, the red on the rockers, shafts, etc. is assembly lube.
I installed the top cam chain guide roller and prepared the cam bearing housings by assembling all of the tachometer drive parts in the right front housing, adding new seals to the tachometer drive and the ignition base, and deburring all of the cam bearing faces.
After we had all of the cam bearing housings ready we installed the camshafts to measure the end play with the new cam bearing housings, removed them to adjust the end play and reinstalled them.
I also installed the intake manifolds, the kickstarter plug in the clutch cover, and a few other small parts. She is getting close to being ready to run!
« Last Edit: Aug 17, 2011, 12:33:44 by joeyputt »
Offline One80Auto
« Reply #142 on: Aug 17, 2011, 20:28:33 »
I am an expert DTT lurker but had to comment.  This is really nice build up to watch.  It looks amazing and I'm sure the photos don't do it justice.  Joe, what's the best way to get ahold of you for some questions...a pm here or your DWMS website?
Offline joeyputt
    • dwmsracing
« Reply #143 on: Aug 18, 2011, 00:17:21 »
Brother One80Auto thank you for the compliment, they always mean more to me than I could ever put into words! I am here on dotheton almost every day so you are more than welcome to pm me here or contact me through the DWMS site, however you feel the most comfortable. I also took a look at your CB750 and it looks awesome man!
Today I set all of the cam timing and installed the cam chain, adjusted all of the rockers to their proper lash, and checked all of the clearances. I also disassembled, cleaned, painted, reassembled, and installed the cam chain tensioner and adjusted it. This afternoon I blasted the front and rear cam covers, sealed them, and installed the intake side cover.
Offline Useful Idiot
« Reply #144 on: Aug 18, 2011, 14:01:02 »
We def need more motor build threads. This one's amazing.
Joey, you gotta link(s) for polishing? I'm about ready to start rebuilding my CB500T motor and I want to polish my cam bearing housing, etc. If I could get mine half as clean as yours, I'd be stoked.
Thanks
That's not an oil leak. The motor's just sweating from all the horsepower.
Offline joeyputt
    • dwmsracing
« Reply #145 on: Aug 19, 2011, 01:15:21 »
Thanks
Brother I am very happy that you are enjoying this thread and thank you for the compliment, I really appreciate it! I do not know of any polishing threads but I am sure there are a lot of them out there, I can send you a pm with more detailed information about polishing if you like or feel free to pm or email me if you have specific questions and I will be more than happy to help you any way that I can.
Offline joeyputt
    • dwmsracing
« Reply #146 on: Aug 19, 2011, 01:55:10 »
Here are a couple photos of the rear side of the engine, the first photo shows how the engine looked when I received it from Brother Habanero52 and the second photo shows how she looked as I started working on her today.
This afternoon I installed the carburetors and a few other parts. There was not enough clearance between the choke levers and the rear cam cover as well as both of the Mikuni carburetors having left side choke levers. I was able to adjust the choke lever assembly on the left carburetor to achieve the necessary clearance, on the right carburetor I turned the choke levers bracket and modified and shortened the choke lever so that it is now on the right side of the carburetor for easier access. I will take and add new photos of the engine with the carburetors tomorrow.
« Last Edit: Aug 19, 2011, 02:00:18 by joeyputt »
Offline ponycarman
« Reply #147 on: Aug 19, 2011, 02:01:23 »
What a transformation! It looks increadable!
1980 Honda cm400t (first bike)
Offline joeyputt
    • dwmsracing
« Reply #148 on: Aug 19, 2011, 15:50:36 »
Thank you Brother!
Offline JustinLonghorn
« Reply #149 on: Aug 19, 2011, 15:54:00 »
Yep, I am a fan, sir.
Into The Sunset, CB750 build
TT500 the Animal
