new use for a belt sander
dracken1
Active Member
although we start our manx and norley frames at the headstock, the shape of the tube on both frames makes it easier to then end at the headstock, this always caused probs getting the notching correct on the upper frame tube to headstock.
untill someone noticed that the roller on the belt sander was the same diameter as our headstocks so a bit of modification and lathe work later . we ended up with what you see in the vid. now it notches at the correct angle and if its a little long it is easy to remove a little more.
machine notch a Norley frame tube
