Re: CB550 Cafe
Thanks Terry
Well I know most of you know what it takes to work on and build these bikes, but here are some photos of the t-nuts that took around 2 hours to completely make (surface cut the stock, cut the stock into 4 parts, square each block, center drill, drill, then tap the holes).
I also got the rear brake turned and had new shoes put on them and I had the front rotor turned. I also drilled and did a little polish job ( not finished) on the rear hub cover.
Sorry for the phone photos,
Thanks Terry
