valvesprung
Over 1,000 Posts
Where did you get the tank pads, and what type of paint did you use on the frame/engine/etc?
valvesprung said:Where did you get the tank pads, and what type of paint did you use on the frame/engine/etc?
Got the tank pads from www.steadfastcycles.com they are from a 1968 Triumph. As to the engine, frame and so on... nothing expensive... the paint is Duplicolor high heat ceramic flat black. Works very well after good prep is done. Why paint the whole bike with the same paint? It was hard to get the same matching finish with other brands. I just wanted the entire flat black look. About the tank i just got it replaced with the one you see now because the original had way too much rust inside to clean /seal and also it was a great deal i couldn't let go. I kind'a like the glossy tank with the flat black look, but i'll probably paint it in the near future. Hope I have covered everything, regards....
