Tintin said:Ah.. well, you see I'm using these fancy chrome valves that are compression fittings.
I know sweating on valves would be the 'right' thing to do, but these are really nice and frankly, the more often I handle a torch, the more often I burn something.
On that topic, I will likely want to sweat off one or two of the end caps from the capped 1/2 copper. Two of the roughed in pipes are a little short, so I don't want to cut them shorter.
Aside from scraps of wood etc, what is the best thing to use as a shield for the torch so I don't burn all the paint off my beadboard?
http://www.dahlvalve.com/Finishing_Valve_021907_R.pdf
If you're going to try and unsweat the caps, after you've shutoff the water and bled the pressure off, drill a 3/8"s hole in the end of the cap to get all the water out of the pipe, and THEN try to sweat the cap off. Funny enough, toothpaste actually works okay at blocking heat. Then use some good sand cloth to get that pipe perfectly clean of solder. Those ferrules on the compression valves need good round pipe to seal properly.
