Finnigan
Over 1,000 Posts
1971 cb450 total engine rebuild, 3rd overbore (70 to 71.5mm), would love to run velocity stacks, hone, external oil lines, and stock carbs.
One shop says they can't flow check but they will polish and port for 300$
Another shop says they CAN flow check and port but will cost 400-450$
Thinking out loud here: I'll be up to 464ish cc's from 444, and the stock cb450 head is identical to the cb500t down to the diameter of the valves so it can obviously support at least that much displacement.
Has anyone had this done? Is it worth putting the money down (I don't mind if the engine will perform better) or should I just do the best I can myself?
BTW the valves were already vacuum checked and are perfect so I don't think I'll even bother having them lapped.
