stillatwork
Active Member
Hello All,
Just snagged a CB450, 1971 I believe, but early 70's, with those real sick Keihin CV carbs...having difficulty getting her to fire so I'll type out my troubleshooting list follows below:
1. New oil, plugs, battery.
2. Valves. Didn't get to check all the clearances, just the ones on the exhaust side of the engine (rusty screws didn't drill out to get to). However, I'm seeing them move in the front. One of the tappets in the back the tappet with the screw was actually off. What's the deal with that by the way, you just adjust that screw to adjust the cap, there is no locknut like say a 550?
3. Cleaned carbs. However when I'm starting her up I'm getting tons of like just low pressure in general, pressure screws don't really seem to be working (Raising/Lowering pressure) and from the top of the carbs I can like what looks like foam coming out.
I think the compression is good, I get putting, but I should probably get a test in there right? With WOT, what # should I get? Also does anyone have a good way to tune these fucking carburetors from scratch because they're a pain in the ass. IT seems like there's just tons of gunk in the engine? Should I put seafoam in her and just let it sit/any advice on that?
Thanks in advanced
Thanks in advanced
