NBraun
Have a 79 gs750. The bike ran fine a year ago, but then was put to the side and forgotten about. Started back up on the project and decided to get it running again. Went through the carbs and replaced gaskets and cleaned jets. All the float heights are set right. Well #2 carb leaks a bunch out of the overflow. Got the bike running and it will idle. I can rev it up, but its "slow" to rev up, and will backfire quite a bit. I pulled the head and went through it, so i'm wondering if maybe the cams are a tooth off or something. I also checked the plugs and #2 plug is black while all others are pretty clean. Any thoughts on it?
