I don't know where to post this so it is here.
first I am a newbie.
I bought a 1970 cl350. before tagging I decided to "work" on it.
I started by taking off generator and clutch covers. I cleaned up the stator and flywheel. then I checked out the clutch cable workings. did not pay enough attention. as I was replacing the stator and cover I found a weird piece stuck to the flywheel. a 3 bearing round with 1 flat side. i know now what it is. I rushed to my online manual and discovered it went to the clutch. while putting it back together I found a steel ball laying on the floor. started to pitch it but decided to keep it for some reason. put the clutch together and remounted it and found I had no clutch tension. back to the manual. found out where it went. redone it and now have a clutch.
the problem is while cleaning up I found another steel ball. took the clutch back off to make sure but that ball was still there. where does this other ball go? I can't find it in the manual anywhere I took something off.
any ideas where it might go?
help!!!
I have taken the stator cover, the clutch cover, the forks apart to reseal them, and finally the oil filter cover off.
help!!!
