crazypj
Split personality, I fake being smart
It shouldn't be rich if float height is correct. Either shut off valve isn't sealing or float level is too low.
I pretty much always set float level +1mm when airbox is remved.
You should need about 10% larger main jet , pilot jet will be fine as original filter was virtually zero restriction at low engine speeds.
You will probably have to drop needle rather than raise it
I found some pictures of back light fitted but 'lost' them again :
