Should cost $50 or so per hole ($200) to have the cylinders bored and honed - make sure you have the kit on hand before you do it - a GOOD machine shop will measure each piston and bore the cylinder to match that specific piston. There are slight differences from one piston to the next.
Sure, this isn't critical, but it's a sign the shop knows what they're doing. Most auto machine shops can't bore cylinders that small either - find a shop that does motorcycles. And have your valve seats ground etc. at the same time, guides checked, new valve stem seals...
