7mm ???crazypj said:It will be generic spec probably on page facing the torque lists, 7mm bolt
its been a long time since i have handled seen a cb/cl 33mm clamping upper yoke... but the 33 for the sl350 uses 8mm as do all the honda 35 yokes of that eracrazypj said:Yep, it's a 7mm diameter bolt.
Chain adjusters also use 7mm bolts on most Honda's over 125cc
I often modify top yoke with a 6mm insert to use 6mm bolts on light weight (race modified) CB350's
Every few grams removed from bike makes a difference for us old fat bastards ;D
