Which front sprocket offset will I need
75hondacb400
Active Member
Hi guys
I have a cb400f 75, running a Vfr nc30 rear swing arm, I have attached some photos but please ask some questions?
Looks to me like you're about 15mm off. Is there room to shim the swingarm to adjust that distance? Not sure who makes offset sprockets to fit a 400f. I know they make them for CB750s, (CycleX sells them), but the biggest offset is 10mm. If the splines match you're golden. Measure from the center of the counter sprocket to the center of the chain.
talk to devin at cognito moto he has done some custom offset ones for me he may be able to help
Re: Which front sprocket offset will I need
PBI offers offset sprockets also. Look through their standard sprocket charts and part number to determine which bikes have the same countershaft dimensions and go from there.
Sent from my SAMSUNG-SM-G920A using DO THE TON mobile app
