o1marc said:Totally up to you. But don't look for the factory to replace them if the original issues raises it's ugly head 35 years after the bulletin.
o1marc said:It isn't 10 minutes in the oven, it's 10 minutes at PMT (part metal temp). Even the heat treat cycles at 350 are not for as short of spans as 10 minutes.
my only comment on coating Comstars is if you want the ribs to stay polished and coating the rest it can get pricey with all the masking needed. If the whole wheel is one solid color then it is much cheaper than breaking down a spoke wheel and coating it.Bert Jan said:Hehe, PC it is.
o1marc said:my only comment on coating Comstars is if you want the ribs to stay polished and coating the rest it can get pricey with all the masking needed. If the whole wheel is one solid color then it is much cheaper than breaking down a spoke wheel and coating it.
Rich Ard said:I got the impression you were putting parts ib the oven for 10 minutes to pc. This thread is getting tough to follow
o1marc said:I hate black, no black on any of my bikes.
The cure times for powder are started when the part reaches 400*. That's why you should never go by Eastwoods directions that say to cure for 20 minutes after flow out. A thin piece of sheet metal will reach 400 in a matter of minutes while a thick forged 26" car wheel may not reach temp for 45-60 minutes. The powder will flow at around 250, if you pull that thick mass wheel 20 minutes later I can guarantee it will be undercured.Rich Ard said:I got the impression you were putting parts ib the oven for 10 minutes to pc. This thread is getting tough to follow
o1marc said:Your decision makes no sense at all. PC can't make the rivits go bad. I didn't mean that the heat will pronounce the issue, I'm thinking that is what PJ is thinking. I think it makes no difference at all.
Bert Jan said:Huh? Goddamn language problem.. i'm lost. Powdercoat comstars YES OR NO?
o1marc said:Bert, you're starting to not make sense. Who is Tim? and 'Won't give me the pleasure" of what?
I'm just killing time right now while my Winston Cup race is under rain delay.
Then I would make the same challenge to you, show me documentation that backs your claim that powder coating a Comstar was detrimental to it's use. I haven't ever coated one but I know it has been done many times.crazypj said:The wheels were not designed to be at 400 degrees at any time.
The expansion rates of various pieces may be similar but very doubtful if it it the same all over due to varying section/width/thickness
They were probably cold formed and it's very doubtful they were stress relieved after assembly
Personally, I won't do ANYTHING for a customer I wouldn't use myself
If you haven't powder coated Comstars and then used them for a reasonable time, your opinion is totally invalid (I would say minimum of 3~4,000miles under varying conditions)
I've done couple of thousand miles on my 378cc conversions,(plus at least dozen high rpm dyno runs) using carb mods I invented so I have no problems offering service to others, it isn't just an opinion thing 'may' be OK
Personally, I would say No
crazypj said:Your completely missing the point.
It isn't the powder coat that's a potential problem, it's the heating and cooling, as I said much earlier
I know people have coated them, but people do dumb shit all the time and a massive majority don't care about safety as long as things 'look cool' :
I've been a government registered motorcycle safety inspector at various times and seen literally ten's of thousands of bikes, mostly OK but because of the numbers I've seen things that may only happen 'one in a million'
I've never 'lost' a customer because of bike fault and I've always been willing to teach people a basic safety inspection.
Your a proponent for PC, that's fine, it's what you do, but, your not a metallurgist or engineer, neither am I, but, I have seen Comstars fail, and, as I've already pointed out, the ones I've seen haven't been a sudden catastrophic failure but loosening of various parts (although I'm pretty sure if the various wobbles were ignored things could get serious real quick)
I have a couple of Comstars, but, I'm not prepared to do destruction testing on them
BTW, how do you go about smoothing out a frame for PC?
I know body filler doesn't work although there may now be some high temp fillers?
I used braze once but it took a hell of a long time to do and added a bunch of weight
PC isn't very good for a true high end 'custom finish'
Just because something CAN be done doesn't mean it SHOULD be done, after all, you could cut your head off, but, I wouldn't recommend that either
Here's a quick article
http://hooniverse.com/2011/05/10/two-wheel-tuesday-the-curse-of-the-comstars/
"Honda’s official stance on Comstars has always been that they should never be disassembled: they can only be riveted properly at the factory, and are not field-repairable. The truth is that many of the rivets that hold Comstars together have become, decades on, corroded, loose, and borderline unsafe. A number of riders have racked up many miles after drilling out the rivets and replacing them with slightly oversized, high-grade aircraft bolts and locknuts."
I've seen them repaired, aesthetically there really isn't any way to make a nut and bolt look good, although I did manage to find a full set of the 'Honda' plastic spoke covers for one guy so his late model 'reverse spoke' wheels got the real early end cap covers
It's not like they are unfixable, but, do you do it before PC or after if there is a problem?
In my opinion, having spoke flanges made and converting to a decent rim size is still best option
You would do the same prep for powder as you would for paint, the only difference is the type of filler used. we have powder primers for specific purposes(Zinc, outgassing primer,etc). Casting marks,separation lines and weld spatter are prepped just as you would for paint if that is the finish product you desire. Paint won't hide them any better than powder will without the prep. The painters will do all the casting marks,separation lines and weld spatter prep and then body fill, prime, under coat and paint for $3k-$5K instead of less than half that price if you want the same in powder. You can use any color powder for primer if you are just using it to fill scratches and whatever. Use the off the wall color you have sitting on the shelf you will probably never use again instead of the more expensive colors you may be using as top coat. Bottom line is the processes for a quality job on both is all in the prep. The price difference comes from the materials needed to finish the job, paint requiring more stages of much more expensive environmentally unfriendly products to complete what you can do with one coat of powder The powder finish can be sanded smooth and buffed just like paint for a mirror finish.crazypj said:Hi Marc,
Didn't know about the new fillers, the problem I've found with PC on motorcycle frames is the prep needed to get frame completely smoothed out. (friend used to build high end custom Harley clones)
The finish is fine but the extra prep when you had to go over every weld with brass filler then grind it back down, add some more, smoth it off made PC custom frames a real PITA and adds a LOT to final cost
If you only see the 'production' builds with PC you would probably never notice, but, when you put the two bikes side by side, the difference is glaringly obvious (comparing a 'real' custom with an OCC bike, $50,000 cheaper than OCC and way better finish : )
I see a lot of builds on here where people have had parts PC, but, they didn't bother to remove casting marks, separation lines, weld spatter, etc. PC doesn't 'hide' things the way a coat of body filler, primer, undercoat and colour will
It isn't real PC but owners not knowing what PC can and can't do, I'm sure things have improved a lot in the last 6~7 yrs
BTW, a statement based on fact IS evidence
