It's not going to be an electrical issue, unless the CDI is really acting bizarre and messing up the timing when RPM rises, but that's really really unlikely. I have a 1978 SR500 with the stock CDI and the timing is still spot on.
I'd be guessing at the CV diaphragm, as it controls the slide going up and down. I don't claim to fully understand them, which is why I ditched the pair on my BMW R75 and replaced them with mechanical carbs. But most people keep the CV carbs, so I guess if they work, they're good.
What happens if you raise the slide with your finger? Lift it a bit as you open the throttle. Think you still need the butterfly valve to open, so you need to twist the throttle and help the slide go up. If that works, my guess is the diaphragm might be leaking. I think you can test that with liquid (assume gasoline?)
