Haven't posted in a while.
I rolled Sophie out the garage today. She hasn't had a good year. With breaking my foot last year in july, and being off my feet, she was barely run at all. (My foot tried to wrap around the footpeg of the 750, turns out it doesn't bend that way).
First thing is check the oil. Wow! overfilled...that can't be right.....Oops, sometime, for some reason, I left the petcock on reserve....odd, O know better.....So change the oil quick.
After checekling tires and a good walk around, she starts right up in a usual cold start. Couple of ignition off kicks to get oil flowing, then choke on full, 2 kicks, then ignition on....first to kicks a cough or too, then the third kick and she is back to life....
Let her warm up a minite or two. Took her for a quick, 1/2 mile run, and she ran perfectly....You have to love the Pamco Ignition....She fely perfectly timed and ready to go.....No hiccups on the first short run....
So she is ready to ride.
I want to keep her operational again this year, so fixups are planned that allow riding.
Since I helped Sonreir somewhat in testing his R/R, I have excessive wire on the R/R top make it easy to replace frequently. The excess wire and connections are likmely to get loose easily, so shorten and make permanent the wiring.
The Tach was restored over a year ago, so now to clean the Speedo.
Some other little touchups and fixups, but no major work....I like riding her....
Pics will follow after a good bath and cleanup.
Will be taking more pics and updating as we go...
