NEED A RETAINER BALL CB350 clutch
Pat383ram
Active Member
Noticed this guy is missing in my clutch set up! Anybody have one? Thanks!!
go on a site like CMSL https://www.cmsnl.com/ search your ike, then search the fiche for the part number. then plunk that part number and maybe your bike model into the googler...
when searching for a specific part. Always search by part number.
But truthfully, if you are just looking for ONE ball bearing for that part. Find the size, then go to a machine shop or mechanic shop supply store. Or even a fastener store.
I am not looking for a ball bearing... it's 3 ball bearings in a flat meta disk. The original image of the part in my first post is from the link you just posted...they don't have this part in stock.
Z1000J has a similar thing in the clutch release mechanism, you can still get them from Kawasaki, I can measure my old one if you want.
Sent from my SM-T560 using Tapatalk
If nobody here has one, check over at hondatwins.net. Someone there will definitely have what you need.
To julian.allard66: I think you are right, but I have no way to compare it to the correct part even if you did measure it, as they don't have measurements on line of my part and I don't have one to measure...
To VonYinzer: Thanks I reposted there!
Here's the whole deal. I know it's not just the one part you need, but for a discontinued part it might be the way you have to go. I did it for my 360. I had to buy the whole actuator assembly. Just an FYI- the same part number matches the 360 too.
http://www.ebay.com/itm/71-HONDA-CB350-CB-350-HM146B-ENGINE-CRANKCASE-SIDE-SPROCKET-CLUTCH-COVER-OEM-/272761468497?hash=item3f81d9b651:g:eek:MkAAOSwt5hYZyAt&vxp=mtr
