Pete12
Hi Ryan, yes we are talking about oxy welding tip sizes. If you are looking to buy a setup, take a trip down to your local welding supply company and have a look at what they have. For welding 1mm body steel a #6 (0.6mm) is the ideal size tip in my experience, as the "just off soot" acetylene setting and oxygen set to a neutral flame is just right.
Oxy acetylene is very versatile and you can use it for brazing, silver soldering, welding, cutting and heating. With the correct flux and goggle lenses you can even use it for aluminium welding, with very good results.
Please keep in mind that acetylene is an extremely volatile gas and care must be taken when using it. I would strongly recommend avoiding the cheap Chinese kits that are on the market.
Pete.
Pete.
