What other O.E. pistons work in a Honda CB350 for a swap ?
grcamna5
Over 1,000 Posts
Hi,
I have a 72' CB350 twin & I want to ask if any of you members have ever attempted swapping in a pr. of O.E. 66-67.5mm pistons into your CB350 from another model Japanese engine from the Big four(Kaw.,Yam.,Suz.,Honda ??
PM's are welcome :)
Re: Will KZ440 pistons work in a Honda CB350 ?
I found out that they wouldn't work because of the height of the piston pin in relation to the dome on the KZ440 pistons.
Has anyone found a good 66 or 67mm O. E. piston that'll swap in to the CB350 twin from Honda or another Japanese manufacturer ? I want to keep the compression ratio right at about 10.5:1
try these http://www.ebay.com/itm/Honda-CB350-K4-Wiseco-Race-Pistons-68-to-73-65-50-mm-10-5-1-cr-Classic-Racing-/360799734997?pt=UK_Motorcycle_Parts_13&hash=item5401570cd5
the kz pistons would be a great budget item, but I think you'd be looking at building a shim for the base of the block, and then finding a longer cam chain, that would be the easiest I think, easier than machining the pistons as much as they'd require. maybe I'll make a kz/cb350 engine after the kz/cb750 is done
What is the compression height of the CB350 ? The KZ750/4 is the same as the 440
but has a much shorter dome and a 66mm bore.
I need to measure the stock CB350 pistons exactly.I Like the idea of the KZ750 piston... Have any of you tried installing a pair of them into a CB350 twin ??
The KZ650/750 and KZ400/440 compression height is .960 in. .
Top of wrist pin bore to top of piston is .665 + half the 15mm pin.
Pic is of an early 9/1 piston. The later 9.5/1 has a slightly taller dome.
Early piston uses thicker rings than the later version.
Thank You for those measurements Rex.
I think it's best for me to find a direct "bore & swap-in" piston that doesn't need any mods,if it's possible....
I want to keep the Original cylinder liners & bore out to between 66-67.5mm and limit the compression to 10.5:1
Thanks for your research help,
grcamna5 :)
Hi All,
I'm was on caferacer.net & crazypj told me I can use XR200 pistons...;Any of you gone that route ? ! ???
Have any of you tried running a pair of O.E. pistons out of any other Japanese motorcycle in your Honda CB350 twin that'd be around 66-67mm and have about 10.5:1 and be a good drop-in swap candidate ?? Stock CB350 pistons are 64mm w/ a 15mm wrist pin diameter,so I do have a few good choices... ::)
750 gpz pistons will work,outside circumference of the piston has to be machined good luck
Those are the same as the late KZ750 pistons. Taller dome and thinner rings than the
earlier piston.
grcamna5 said:
Rex,
Do you think a pair of later KZ750 pistons would work in my CB350 engine ?
You need to measure a 350 piston like I did the 750 piston. And also the dome height.
With the Sportsman 350 racing class, there are a lot of folks racing them nowadays.
If there is a cheap swap those guys likely know of it...
Hi Bozz,
I'd like to speak w/ a few Vintage Racers out there who are into the CB350;do you know of any racers ? Where's the nearest race track to Pittsburgh,Pa. where guys will be in the Sportsman 350 class ? Do I have to wait until Spring...?
Yes, I will do that Rex & list the dimensions here..,after the Holidays. ;)
bump. Still researching this,anybody have any new info on a direct swap-in piston after bore job ? Racers ? !
