You hammered the pistons out of there and probably have ridges larger than Walter Cronkite's jowls, and you're not going to bore to at least the next size up?
Consult a professional. I don't know if that's advisable.
I plan on doing that. I was going to bore it out but honestly by the looks of it there is no problem. I spent quite a bit of time honeing the cylinder.
No sure if sarcasm or not. Damn you Red, now I am second guessing myself, again, is that third guessing? Dammit...
Ohh yeah and the shift shaft came in this arvo. It is bent, I could see that in the pictures before I bought it but compared to the other one it is perfect. I will take a picture side by side before I put the "new" one in.
Thanks mate, I am still undecided on the colour of the head, it looks great raw but, like Redbird, I am a sucker for redheads as well. So I am thinking a dark metallic red should do the trick.
As for the tank and seat I am thinking a gun metal grey. The frame should hopefully be around the same red as the head.
Ha, I need a new head if I hit the 1000 mark. I have been tossing up buying the 844 kit from wiseco but I think the extra grand required is well out of budget. I have a friend who is after my SR and I would rather have this bike running before I spend "un-needed" cash on it. One upgrade I have been looking into is dual front rotors, the B model did not come with them. There is a bloke over on the GSR that has a kit for dual CBR600 rotors with Twin Pot front calipers. That will be on the to do list straight after I have the bike on the road, I know that the stock breaks will not be enough.
Ok so a quick update, I have been working my arse off of late, and as a gift to myself I bought a Dyna S and Dyna Coils from Dime City Cycle, and yes I did use the discount lol.
I started to put the engine back together yesterday when one of the bushings on the kick start shaft fell down inside the cases, to which I decided it was time to go fishing.
I am off into the garage again now to either put the engine back together or cut up the frame, have not decided yet.
Alright I have the gearbox back together now and I am moving on to getting the side cases and everything else on, after that I will weigh up my options for the size of the bore lol.
I will be ordering quite a few things once I get my tax money back, and yeah I know I am slack, but it is done now lol. On the list is a new stator and rec/reg.
Also needed is new clutch plates and springs, timing chain because I am an idiot and forgot to order it.... and depending if I can use the cylinders at the current size, 1 new piston. If I have to go up I will have to get new rings and pistons.
I will also be ordering a new seat from Roc City soon so that I can get the frame length sorted and start chopping away at it. The TR1 tank will be going in to work to get it to fit, I don't want to go wrecking a perfectly good tank..
Thanks Rich. Hmm pictures. Here is the new tank I mentioned earlier.
As for coming along I am at the stage of getting the cylinders sorted. I have been doing quite a lot of research this arvo and have come to the conclusion that .5mm OS pistons will be the best bang for buck.
I need to get the cylinders bored to remove the rust around where the cylinder was stuck, the engineering shop recommended getting a 1mm bore to make sure it was fine, they said I should be right with a half though. After searching the web for hours trying to find 1mm oversize pistons and rings I found that they are around the same price as the 844kit that wiseco offers.
So my current plan is to try and get the 1mm oversize for cheaper as I have already made a low offer on a set of pistons. If I cannot get those then I will be grabbing a set of .5mm OS and going from there.
As this will be cheaper than getting the 844 I will be able to get the engine sorted soon and put back together so that I can move on to the frame.
Ohh yeah, and a set of Tarozzi rearsets from Fast From The Past are looking quite nice right now.
