Alright, so im running a custom brake setup on the RD project, and ive been trying to research how to select the correct master cylinder setup but I really havent found anything on here or the Googles. Hoping an expert can help clear the muddy waters for everyone.
My case, running a single 2 piston FZR1000 caliper
I have found the follow information
Piston diameter to master cylinder size http://www.vintagebrake.com/mastercylinder.htm
Very generically lumped master sizes http://rg500delta.com/RG500_chassis_files/master%20cyl%20bore%20sizes.pdf
So, step 1, measure the diameter of the pistons. Having multiple, and the two being of different size, how do you go about doing this?
Step 2, figure out the ratio you need. This guys talks about 2 piston opposed calipers and single piston calipers. I think he means 27:1 if you are running duel disk, and 14:1 if you are running single disk. Can anyone confirm?
Step 3, find a master cylinder. You can use the link above, to get general on used masters, but they are lumped into three categories so its give or take.
