What did you build this week?
I assembled this for a friend to give to her granddaughter for her birthday.
It wasn't the least bit difficult or really all that noteworthy. But I figured Desmobro would get a kick out of it ;)
After a month and a half of waiting, I finally got my fat bike frame I ordered so I was able to build it up! The wheels/hub are too large for any commercial or shop grade truing stand, so I also decided to make a truing stand for it out of some extruded aluminum and some other little pieces of aluminum that I turned down and milled. It should also work with motorcycle wheels :D
You made it for your shed didnt you.....dont lie....
Ever After High... yeah... uh huh. I think I've survived quite a few ever after highs throughout my life.
;) And this is the sign for cat...
This motorcycle table happened last weekend...
Framed up
Finished
I even designed in a dropout for rear wheel removal
I need to pick up bolts for the casters and D-rings, but otherwise it's ready for service ;)
Put together a three piece pivot axle for a FZ6 swngarm to fit a CB750K2 taking advantage of the FZ needle bearings. Not much of a project but a lot of thought went into it. this is not a good solution for a mono shock project.
Ah, do still have one of the final prototypes. There is a dowel pin that runs through the smaller piece, that clips in to the cut out on the top of the larger piece, is spring loaded.
That grill is straight Southern style. When are we having a pig roast?
Almost finished building a TZ350 motor -part of a complete rebuild/restoration.Now waiting for parts to arrive from UK and Europe and then some bits to go to the plating shop for new zinc plating.
