DO THE TON
DO THE TON Sponsors => Cognito Moto => Topic started by: SpeedBump on Nov 19, 2013, 16:02:44
Title: Cognito Moto Design GSX-R fork conversions
Post by: SpeedBump on Nov 19, 2013, 16:02:44
Cognito Moto's mission is to make difficult things easier for our fellow garage builders. Check out some of our current designs.
We are alway open to suggestions and new ideas, so don't hesitate to post about something you'd like to see.
Thanks,
Devin
This hub is a 100% bolt-on solution for laced wheels on GSX-R forks. Re-uses stock GSXR bearings, seals and spacers.
http://cognitomoto.com/collections/gsxr-conversion-parts/products/gsx-r-hub-bolt-on-conversion-laced-wheel
(http://img.tapatalk.com/d/13/11/20/enetumun.jpg)
Billet aluminum GSX-R top tree to replace the ugly oem GSX-R top tree. 100% bolt-on.
http://cognitomoto.com/collections/gsxr-conversion-parts/products/gsx-r-billet-top-tree-for-fork-conversion
(http://img.tapatalk.com/d/13/11/20/sygunugy.jpg)
We also have designed up these retro nuts to match.
http://cognitomoto.com/collections/gsxr-conversion-parts/products/retro-nut-for-gsxr-conversion
(http://img.tapatalk.com/d/13/11/20/geqemybu.jpg)
This stem makes it a lot easier to put that GSXR Fork on your CB750 frame. Simply press out your existing GSX-R stem and replace it with this one. Now you can bolt your GSXR fork right up.
http://cognitomoto.com/collections/gsxr-conversion-parts/products/copy-of-copy-of-copy-of-gsx-r-fork-on-cb750-frame-conversion-stem
(http://img.tapatalk.com/d/13/11/20/yzyqy5am.jpg)
This is a retro top tree for your GSX-R conversion.
http://cognitomoto.com/collections/gsxr-conversion-parts/products/retro-triple-top-tree-for-gsxr-conversion
(http://img.tapatalk.com/d/13/11/20/tu3ugy7u.jpg)
(http://img.tapatalk.com/d/13/11/20/upydytav.jpg)
www.CognitoMoto.com
Title: Re: Cognito Moto Design GSX-R fork conversions
Post by: SONIC. on Nov 19, 2013, 16:06:05
You guys make some really nice stuff.
Post by: SpeedBump on Nov 19, 2013, 22:35:41
Thanks!
www.CognitoMoto.com
Post by: mAd mOrdigan on Dec 14, 2013, 05:55:24
i dont remember seeing this stuff a few months back but its definitely got me interested in a gsxr front end for my 750. is there specific year fork or model needed? 600/750/1000?
Post by: SpeedBump on Dec 14, 2013, 10:04:51
You can mix and match all kinds of stuff to make it work but the easiest is the 2005-2010 gsxr600 and gsxr1000 forks. The gsxr1000 forks work as well but my top tree doesn't work because of the offset.
www.CognitoMoto.com
Post by: Floegstad on Dec 14, 2013, 10:18:54
Shout if you are haveing a "free shipping campaign" pre x-mas  ;D
Post by: mAd mOrdigan on Dec 14, 2013, 17:36:10
which year gsxr750 forks work with stem and triple clamp? I'm gona keep an eye out on craigslist.
also, does the lace hub have a way to use the stock speedo unit?
this stuff is really awesome
Post by: teddpage on Dec 14, 2013, 17:53:52
According to their website, 2005-2012 GSX-R 600, 750 and 1000.
Usually you will have to get crafty to fit a speedo drive...either go aftermarket and mount a sensor on a wheel, or a GPS type unit.
Post by: SpeedBump on Dec 16, 2013, 09:50:37
Like teddpage said, you will need an electric speedo. Legendary has gps speedos that seem pretty cool.
www.CognitoMoto.com
Post by: SpeedBump on Dec 17, 2013, 17:10:12
Got it hooked up for you. http://bit.ly/1bOs1A9
www.CognitoMoto.com
Post by: HollywoodMX on Dec 21, 2013, 01:26:05
Wow, real nice custom parts, I'm impressed.
Post by: skyler on Dec 21, 2013, 14:12:36
Impressive parts.  I must scrape up some $.  Only need one kidney, right?!
Post by: K0Kid on Dec 28, 2013, 20:52:57
What specifically makes the GSXR front end more desireable over the stk Honda?. I understand Honda is old tech, some of you have studied the differneces and nuances but please enlighten me.
Post by: Floegstad on Dec 29, 2013, 07:40:09
www.CognitoMoto.com
Unfortenately not overseas...........
Post by: SpeedBump on Dec 29, 2013, 12:59:35
The short answer is that the GSXR forks are more responsive, lighter and have better brakes. I'm sure there are plenty of arguments to be made but it's really personal preference.
www.CognitoMoto.com
Post by: SpeedBump on Dec 29, 2013, 13:00:05
PM me and we can work something out.
www.CognitoMoto.com
Post by: IRN_FST on Jan 06, 2014, 18:45:06
Why the 05 Forks and not the 04?
To my knowledge the 04 and 05 forks are when they switched over to the inverted style fork.  Is there a difference in the bottom clamp? or are the 04 forks indeed ok..?
Also, with regards to the hub, what specific 17' Harley rim?  and what length spokes?  Ive been looking up rim options lately and my head is absolutely spinning. :(
any insight is appreciated, the spoked wheel segment is totally new to me.
Thanks!
Post by: SpeedBump on Jan 07, 2014, 03:13:31
Thanks!
They will work spacing wise but the rotor diameter is smaller on the 04-05 gsxr.
I use the 17" rims on my builds simply because I like to use modern sport bike tires. Stock cb rims can be used. For spokes and lacing I use buchananspoke. They do a great job and I highly recommend them.
Hope this helps and don't hesitate to contact me with any questions.
Devin
Sent from my iPad using Tapatalk HD
Post by: SpeedBump on Jan 07, 2014, 15:58:41
Fresh of the lathe. (http://img.tapatalk.com/d/14/01/08/ave5umab.jpg)
www.CognitoMoto.com
Post by: IRN_FST on Jan 07, 2014, 18:29:17
ok good to know!  I just got my 04 front end ordered after a few months of BS. I was sweating there of a second.
Put one of those aside for me!  8)  So awesome.
I just spent a small fortune on parts so my order from you is next! lol
Post by: SpeedBump on Jan 14, 2014, 14:12:16
GSX-R conversion Hubs are now back in stock! 36 and 40 hole versions available.
(http://img.tapatalk.com/d/14/01/15/eha2ygu4.jpg)
www.CognitoMoto.com
Post by: john z on Feb 07, 2014, 12:36:35
will this set up work on a 1981 cb 650?
Post by: SpeedBump on Feb 07, 2014, 12:38:18
The hub and everything will work fine. I'm not sure of the neck length on the cb650 but I'm pretty sure it's the same as the 750. I'm waiting to hear back from a fellow that purchased the stem to fit a cb650. If you want to take some measurements I can check for you.
www.CognitoMoto.com
Post by: john z on Feb 07, 2014, 20:01:58
Tree and forks are still on bike, but i got 7.50 for neck, 2.38 on top bearing cap.
Thanks for the help
Post by: DreadRock on Feb 07, 2014, 22:02:27
Really can't use anything ( Yamaha guy ) but Dam you guys do nice work ! Jumped on your site and if you ever do Yam parts let us know please ! Again nice work ..
Post by: SpeedBump on Feb 08, 2014, 00:37:16
I want to get some XS650 parts going
www.CognitoMoto.com
Post by: SpeedBump on Feb 08, 2014, 00:39:53
Thanks for the help
7.5" is the same as the CB750. Should work perfectly. If for some reason it doesn't we always accept returns.
www.CognitoMoto.com
Post by: ekb20b on Feb 18, 2014, 02:30:30
www.CognitoMoto.com
would you happen to know whats the biggest size tire a cb350 can run on the stock wheels? the reason i'm asking is i want the front wide enough to make the GSXR front end not look funny with a skinny front tire.
Post by: Ryanlowry on Mar 09, 2014, 21:20:10
Pardon the super bad cell phone photo but I got my front end mounted up today! SPRING HERE I COME!
Post by: SpeedBump on Mar 10, 2014, 12:35:51
Not sure since I've never done that setup. However, I don't think it would look funny.
www.CognitoMoto.com
Post by: SpeedBump on Mar 10, 2014, 12:36:42
Looking good man. Keep it coming.
www.CognitoMoto.com
Post by: Ryanlowry on Apr 08, 2014, 04:16:21
THANK YOU COGNITO FOR ALL OF YOUR GUIDANCE !!!
(https://scontent-a-ord.xx.fbcdn.net/hphotos-ash3/t1.0-9/10169288_10152035263956977_5006104220148532602_n.jpg)
Post by: SpeedBump on Apr 08, 2014, 09:34:00
Looks awesome man!
www.CognitoMoto.com
Post by: Tcb750 on Jan 25, 2018, 22:09:45
Hey guys. Was wondering if a 2009 gsxr750 front end would fit on a 77 CB750.
Iím sure all balls will have to supply me with bearings by wondering if anyone has the knowledge of the fitability of this custom.
Thanks in advance!
