DO THE TON
Blood Sweat Tears and Grease => Projects => Bob and Chop => Topic started by: irk miller on Oct 09, 2017, 00:18:20
Title: CB750 No Plunger Hellride Freedom Machine
Post by: irk miller on Oct 09, 2017, 00:18:20
Thanks to the gracious delivery of this 70's era plunger frame from New Mexico to Alabama by Canyoncarver, I'm jumping into this chopper build with two feet. I've reached out to several forums, sorted through various catalogs and ads from the 70s, but have yet to identify the manufacturer with complete confidence.  I think it's definitely a production style frame, considering the neck.  It has two pressed in cups for a common neck tube.  The CB750 triple tree that came with the frame has a modified stem to account for the longer neck.
(https://uploads.tapatalk-cdn.com/20171009/d84898423e40c89029a3a00698dd43fe.jpg)
We're in the sketching  phase, so things can change wildly.  Ultimately, I want to avoid common cues like peanut tanks....
It took some machine work on the steering neck cups and the RM stem to make this RM front end work...
(https://uploads.tapatalk-cdn.com/20171009/4ab747e7d5fd850cd7123595a8ad1182.jpg)
Here is sits with a 1991 RM250 front end and RM wheels front and rear.  I like the dimension of the dirt bike wheels, plus they're aluminum.   If I decide to go drum on the rear wheel, I may go 70s era XL350.
(https://uploads.tapatalk-cdn.com/20171009/9a8433f4e6ebe06b919e87ab1c3082f6.jpg)
Sent from my iPhone using DO THE TON (http://r.tapatalk.com/byo?rid=89466)
Title: Re: 70s Era CB750 Plunger Hellride
Post by: Hurco550 on Oct 09, 2017, 09:57:34
 I'm in
Post by: TranceMachineVienna on Oct 09, 2017, 10:37:52
Hell yeah man.Count me in.  8)  8)  8)
Post by: SONIC. on Oct 09, 2017, 16:37:42
Work slower. You make everyone else look bad.
Jackass.
Looks cool though  ;D
Post by: trek97 on Oct 09, 2017, 17:27:58
Those forks are AWESOME on that frame.
Post by: irk miller on Oct 10, 2017, 00:33:08
Grades and comments for midterms are due tomorrow, so what do I do?  Make a mount for a headlight...
(https://uploads.tapatalk-cdn.com/20171010/302063684e1307c8666b4196eb954b37.jpg)
(https://uploads.tapatalk-cdn.com/20171010/3ae0610d264c98ef3628196d39cc0c1e.jpg)
(https://uploads.tapatalk-cdn.com/20171010/54597f1455d72c1df2775a2419208875.jpg)
Post by: trek97 on Oct 10, 2017, 00:37:00
That headlight on there is the shizzle.
Post by: 63SSRagtop on Oct 10, 2017, 01:40:19
Dig the frame, I've never seen one quite like this either.. can't tell if it's a weld on rear half or whole frame.. You are probably aware that the front end may be really spongy for the weight of the bike as the build goes on.. they are designed for much more travel than a street bike front end.. I've read that the fluid movevement can be restricted with a machined piece and/or stiffer springs.. worked on a cafe Suzuki that had 250 forks, they looked cool but damn it moved around way too much.. cool project though! Will keep tabs!
That frame looks to me like a Jammer frame, canít find any reference to one with a plunger rear, but someone at some point could have grafted in a Santee rear section..
Post by: irk miller on Oct 10, 2017, 07:47:54
Dig the frame, I've never seen one quite like this either.. can't tell if it's a weld on rear half or whole frame.. You are probably aware by that front end may be really spongy for the weight of the bike as the build goes on.. they are designed for much more travel than a street bike front end.. I've read that the fluid movevement can be restricted with a machined Peice and/or stiffer springs.. worked on a cafe Suzuki that had 250 forks, they looked cool but damn it moved around way too much.. cool project though! Will keep tabs!
Yeah, I'm definitely considering the possibility that these forks won't work. I have tried them on a heavier dual sport contraption I built, so I think there's room to make them work here.  This is one iteration, with potentially several others. They can be valved and fluid levels adjusted to effect the dampening on these to account for weight. The rake is a big factor, as well.
I've narrowed my opinion of the frame manufacturer to either Jammer or an early Santee. Though, all the Santee plunger frames seem to have a goose neck. You may be right on about the plunger being grafted on a Jammer. The tubes which mount the springs certainly suggest that possibility...
(https://uploads.tapatalk-cdn.com/20171010/bb8b6279331300dd0c986248e3a28538.jpg)
Post by: JustinLonghorn on Oct 10, 2017, 09:08:42
Choppers are dumb. And I love them.
Post by: Maritime on Oct 10, 2017, 11:21:25
Ha, I usually hate rectangle lights but it suits this bike well. Looking forward to more of course.
Post by: canyoncarver on Oct 10, 2017, 22:07:01
I barely pull in my driveway from the trip and you've already got a front end on it.  !    Sweet.
Post by: irk miller on Oct 11, 2017, 07:56:27
Had a little convo with Race Tech.  I could go as high as .52kg/mm on springs in these forks.  Stock is .36kg/mm.  We'll see how it acts with weight and go from there.  Regardless, I feel pretty good that we'll find a match with rake and trail considerations.
Post by: jag767 on Oct 12, 2017, 05:21:37
That front end looks like it has a ton of travel, do you have to limit it with a spacer or something or does it not matter? Btw it also looks fantastic on that frame.
Post by: irk miller on Oct 12, 2017, 07:49:03
  I imagine there will be enough travel to hit the frame to floor if I were to jump it, but running on the street will just waste most of what it has available. As long as Race Tech has the right springs, these forks should work well.  I have a VZ800 front end to swap in, if this setup doesn't work.
Post by: surffly on Oct 12, 2017, 09:09:25
Choppers are the best worst bikes ever!
Post by: irk miller on Oct 12, 2017, 09:43:35
Hell yeah they are!!!
Post by: irk miller on Oct 12, 2017, 09:48:37
I didn't take any glorious actions shots, but man you should've seen me getting all the Bondo off this frame.  Fuck that 70s smoothed out look.  I learned an old body shop trick with removing paint and bondo, which is to get a fan tip for a torch and go apeshit with a scraper and stiff wire brush.  It weakens the Bondo so you can scrape it off, or brush it off.  Thick areas require a few passes.  Some of it drops in flames.  Then clean up the mess on the floor with a broom.
Post by: advCo on Oct 12, 2017, 11:06:21
Sweet, I got a whole Ghia worth of Bondo to strip off. This will be useful.
Post by: Redbird on Oct 12, 2017, 12:36:46
Subscribed.
I see the bones of the Deviant Hellride in the background. Is she supplying the lump for this girl?
Post by: irk miller on Oct 12, 2017, 12:50:15
Subscribed.
That she is.  I thought about running those mags too.  We'll see how things go.  E and I are convinced that bike is cursed.  Hopefully the motor can be exercised.
Post by: 3DogNate on Oct 13, 2017, 14:34:22
Watching.... plunger frames are cool
Post by: WhyNot on Oct 13, 2017, 14:47:44
I'm watching all the other builds, might as well jump in for the ride on this one.........
Jack
Post by: irk miller on Oct 13, 2017, 15:41:03
Thanks fellas.
Got tires mounted.  I may go 18" or 17" on the rear instead.  This is 19" with a big ol flat track tire mounted.  21" up front.  I'll be looking at this setup for a while.
(http://www.dotheton.com/gallery/77150-131017133915.jpeg)
Post by: Maritime on Oct 13, 2017, 15:50:18
The big ole flat track tire makes the rear look bigger than the front which is weird or not right looking. Now maybe with a fender on the back it might look better?
Post by: irk miller on Oct 13, 2017, 15:59:09
It's 1.5" taller in the rear, which is a look not uncommon for digger style choppers.
Post by: canyoncarver on Oct 13, 2017, 16:42:39
The 21" looks great up front.  That rake is perfect.  I'd try the 17" rear.
Post by: SONIC. on Oct 13, 2017, 16:50:38
I like the big rear tire.
Reminds me of a dragster  8)
Post by: clem on Oct 13, 2017, 18:40:27
Bam! Throw some top fuel flare on that thing.
Sent from my SAMSUNG-SM-G930A using DO THE TON mobile app (http://r.tapatalk.com/byo?rid=89466)
Post by: stroker crazy on Oct 13, 2017, 19:00:07
Me too!
Once the motor, tank, seat, etc. are in place it should look just right.
Crazy
Post by: canyoncarver on Oct 13, 2017, 19:51:43
Yes!
Post by: WhyNot on Oct 14, 2017, 07:00:24
Yep, like the stance.
Post by: jag767 on Oct 14, 2017, 07:20:19
Definitely drop to an 18 rear, front looks great!
Post by: irk miller on Oct 14, 2017, 12:45:58
Lump installed.  Goddamn, it's a heavy lump.
(http://www.dotheton.com/gallery/77150-141017104414.jpeg)
Post by: Hurco550 on Oct 14, 2017, 13:36:42
I can dig it
Post by: SONIC. on Oct 14, 2017, 18:01:35
I do not like choppers.
For some reason I like this.
You have my permission to proceed.
Post by: irk miller on Oct 14, 2017, 18:59:47
Ha!  Thanks.  Brad and Ard are telling me to scrap the plunger and make it a hardtail.  I have that inclination but I kinda want to stick with the plunger, if only because there aren't many out there.
Post by: trek97 on Oct 14, 2017, 19:34:43
Oh no, you just gotta keep it as is.
Post by: Maritime on Oct 14, 2017, 19:38:19
With the lump in rear tire looks better anf I agree keep plunger frame. Anyone can have a hardtail.  Plungers are more rare and different.  And we all know you're different
Post by: Hurco550 on Oct 14, 2017, 20:04:45
 Yep, my vote (Not that it matters) is to keep the plunger. Plus, if you hate it, it will be easy enough to hard tail later
Post by: irk miller on Oct 14, 2017, 20:14:11
(https://uploads.tapatalk-cdn.com/20171014/4a4905633c8c8bb6d455347ee5a8b48a.jpg)
Post by: canyoncarver on Oct 14, 2017, 21:00:43
well, that was quick.
Post by: SONIC. on Oct 14, 2017, 21:14:29
Didn't anyone ever tell you not to give in to peer pressure?
Post by: Hurco550 on Oct 14, 2017, 22:24:06
Ha
Post by: trek97 on Oct 15, 2017, 00:39:13
They look so sad.
Can I have them?
Post by: irk miller on Oct 15, 2017, 02:15:27
(https://uploads.tapatalk-cdn.com/20171015/6d7143af75863e69a53b5544695f7785.jpg)
Post by: irk miller on Oct 15, 2017, 02:24:07
Ever since the deal with Kelly to get the frame, lots of research has happened. If it were a legit Amen or original plunger, I would've kept it a plunger no matter what. The more I dug, the more I realized someone added a plunger kit in the 70s.
As the research goes, there is only one suspension worse then a hardtail and that's a plunger. Awful ride and awful handling. Plus they destroy your drivetrain because the  suspension acts independently since there's no swing arm. Talking to some old school chopper guys, the only way to fix them is to add a torsion bar. I decided to make it a hardtail instead.
Post by: SONIC. on Oct 15, 2017, 02:29:00
Time to change the name  8)
Post by: stroker crazy on Oct 15, 2017, 05:29:53
True!
Even with a swing arm they're pretty dubious.
Crazy
Title: Re: CB750 No Plunger Hellride
Post by: trek97 on Oct 15, 2017, 07:19:50
I see your point now.
I thought it would be similar to the older BMW models.  But, after looking closer, I now realize the BMWs do have a fully active swing arm.  Along w utilizing the drive shaft tube.  Just kinda hard to see exactly whats happening there as most are painted black and that suspension is hardly noticeable.
Learn something everyday...check.
(http://www.dotheton.com/gallery/11494-151017051541.png)
Post by: clem on Oct 15, 2017, 10:49:11
Sell those things to a plumber and use the money to buy more radness for this bike.
Post by: irk miller on Oct 15, 2017, 12:12:37
Ha!  I can't keep my washing machine drain from clogging.  Maybe I can throw those fuckers down there.
Post by: Redbird on Oct 15, 2017, 12:58:35
If that's the case, I think I would've welded up the Plunger in a fixed position and ran that instead. That way it would ride like a hardtail, but look like a plunger.
Sadly (for me), the frame has lost it's "hook", and now looks like a cookie cutter hardtail.
Post by: irk miller on Oct 15, 2017, 13:56:53
Sorry to disappoint.  It was a hard decision that I went back and forth on for months.  Thanks for making it easier.  It's not a cookie cutter kit to turn it into a hard tail and it's not cookie cutter axle plates.  That's all done by me in my own design.  I figured I'd lose some fans of this build with the decision, but I gained a few inches in length to sit (which it needed) and I won't wobble and die at high speeds (which is common with plungers).  Not sure how welding up the plunger to make it into a fake plunger is better than turning it into a hardtail.  I'm not into faking things.  I might not always do it right, but I do it honestly.  Considering I've just been told that it's a waste of these USD forks on a hardtail, I'm definitely building a roster of vocal critics.  I'm sure this build will attract way more vocal critics than I have now.
Post by: irk miller on Oct 15, 2017, 14:58:01
I recycled the plunger axle plates and boxed them out. Put in torsion bars to stiffen up the frame.
(https://uploads.tapatalk-cdn.com/20171015/535b4d370b08e8e39ec61c29dd5b0a43.jpg)
(https://uploads.tapatalk-cdn.com/20171015/b59f0e5659377eae32bb0c061020feaf.jpg)
(https://uploads.tapatalk-cdn.com/20171015/f6d897b6481a37a8769b87c3c1078549.jpg)
Post by: Redbird on Oct 15, 2017, 15:41:33
I wasn't trying to bash or suggest you should do anything differently. Nor am I disappointed. I'm of the opinion that "it's your bike, do whatever makes you happy".
I'm no Bob/Chop suspension (or anything else) expert, but it seemed to me the "unusualness" of the plunger rear was the draw. Now it no longer has that.
And all I was "pondering" with making a fake plunger was to keep the unusualness of it while improving the function. Fundamentally the same premise as using a vintage headlight and/or taillight shell, but installing LED fixtures/bulbs to improve visibility/safety.
But you do you dude. Don't let me interrupt. I'll keep my uneducated musings to myself, as not to be lumped in with the rabble rousers ;) :P
Post by: Cookie on Oct 15, 2017, 16:21:47
"The Hellride Formerly Known as Plunger"?
Lol
True it loses some uniqueness without the plunger  rear end, but as you said Irk, it wasn't born that way, and the plunger that were cobbled from hardtails were even more unsafe than the handrails they started out as. Kind of like those guys who make a "hardtail" by bolting some steel rod in where the rear shocks used to be.
It may not have the same character, but it's still pretty sexy looking! My only gripe is that you seem to be able to turn out projects faster than I can read your posts about them!
And I for one like the forks. Wasteful or not, they give it character that a cookie cutter hardtail will otherwise lack.
Post by: trek97 on Oct 15, 2017, 17:32:16
Captain America's got what you need.  LOL
(http://www.dotheton.com/gallery/11494-151017153116.jpeg)
Maybe a little more this...
(http://www.dotheton.com/gallery/11494-151017153418.png)
You definitely gotta do the king/queen w sissy bar.
Post by: irk miller on Oct 15, 2017, 20:39:50
Ha! I doubt I'll do that seat. You saw that Schwinn girder front I got from Levi, right? That goes on the bike I got from you.
Post by: canyoncarver on Oct 15, 2017, 22:14:40
I like the new length and the bracing.  Do you think you'll have to run a mid-chain tensioner ?
Post by: irk miller on Oct 15, 2017, 22:20:20
Not sure.  The length really doesn't seem bad.  I'm waiting on the screws to mount the rear sprocket then I'll measure it up.  The local dealer didn't have a long 520 chain in stock, so I have to order.  I have a tensioner here just in case.
Post by: irk miller on Oct 16, 2017, 17:15:09
Nothing like getting a couple of days off for Fall Break and literally spending all day on a bracket to mount your coils #noglory
 (https://uploads.tapatalk-cdn.com/20171016/2ad29a2206eb6faa4c1efc2d538aba3c.jpg)
Post by: Maritime on Oct 16, 2017, 23:12:47
Thats a clean and tight mount. I like it and with the hardtail the rear tire looks better to me too.
Post by: irk miller on Oct 17, 2017, 01:02:32
Thanks, Mike.
A couple quick little updates...
(https://uploads.tapatalk-cdn.com/20171017/93f001ea962010fa5497dc2326e77e08.jpg)(https://uploads.tapatalk-cdn.com/20171017/c8bc2076103bfa936285c4d65aafb418.jpg)
Brakes: I have to figure out a tab for the rear stay. Something I can try to machine tomorrow.
(https://uploads.tapatalk-cdn.com/20171017/a3d9f27c5c82cb5503e18260dd779c90.jpg)
(https://uploads.tapatalk-cdn.com/20171017/bda6dc556e81d001a2602243ffd25c26.jpg)
Sprockets: I'm running a 38 tooth rear and a 14 tooth counter. The counter sprocket is an XL250 sprocket, with a machined spacer.  Honda ran a common counter shaft tooth for several bikes, which is really convenient when you want to convert a CB750 to 520 chain.
Post by: canyoncarver on Oct 17, 2017, 01:16:24
Way better pics.  I dig how you did the axle plate now I can see it.    Cool.
Post by: irk miller on Oct 17, 2017, 11:31:18
Machined a brake stay and got it mounted...
(https://uploads.tapatalk-cdn.com/20171017/4c4ca1bd4d2182eb7148f1301887dcef.jpg)
(https://uploads.tapatalk-cdn.com/20171017/0535c302e1f12ea90d8db1330c977716.jpg)
Post by: irk miller on Oct 17, 2017, 20:35:31
More brake stuff (lines will eventually be SS AN )...
(https://uploads.tapatalk-cdn.com/20171017/80313a456cababbcd34460e3d559ac4f.jpg)
(https://uploads.tapatalk-cdn.com/20171017/da49e5ee2ff4a32aa58530f094851437.jpg)
(https://uploads.tapatalk-cdn.com/20171017/78e5a62a5b653d4616539e56c7bed366.jpg)
Post by: Hurco550 on Oct 17, 2017, 21:13:28
yep. I agree with sonic. You need to slow down. your making us all look bad.
In 2 days you have gotten more done than I do in months on my projects lol
Lookin good bro
Post by: irk miller on Oct 18, 2017, 00:00:56
Started making a seat pan. I really just want to be able to sit down on it...
(https://uploads.tapatalk-cdn.com/20171018/65253d8a587fb611022b8ea7b95b24a1.jpg)
Post by: JustinLonghorn on Oct 19, 2017, 09:47:47
Fuck yeah, man!
Post by: SONIC. on Oct 19, 2017, 20:04:56
This is getting dangerously close to looking like you know what you're doing.
Once you're no longer a hack you're not welcome here anymore  ;D
(http://newtheory.com/wp-content/uploads/2015/12/yoda-you-must-unlearn.png)
Post by: irk miller on Oct 20, 2017, 02:02:05
I promise, I'm still a hack.
I've decided to go with a first gen XL350 tank, because I like the shape and I have an idea for placement of my ignition switch. I saw opportunity in the cutout for the carb.  This tank is just for mocking. A good tank is en route...
(https://uploads.tapatalk-cdn.com/20171020/5f05dfe2e86a0e8fa522d23381e24d86.jpg)
Seat pan is basically done. Waiting on the springs, then mount. Covering may be the last thing I do.
(https://uploads.tapatalk-cdn.com/20171020/070dde350d2d3abb9c832bbead61cab3.jpg)
Post by: trek97 on Oct 20, 2017, 07:35:06
(http://www.dotheton.com/gallery/11494-200816163635.png)
Post by: WhyNot on Oct 20, 2017, 10:42:18
Man Eric, that is nice, just wish I had some of your gumption to do something to the "too many" projects I have.
Post by: advCo on Oct 20, 2017, 11:06:47
Yes dude, that 350 tank is the biz.
Post by: 1fasgsxr on Oct 20, 2017, 13:19:56
I agree...I am just lazy I guess... You are killing it on this thing !!
Post by: irk miller on Oct 21, 2017, 19:34:08
Made a remote m/c and reservoir so I can run a simple cable control on the bars.  The unit will get welded underneath the tank and  a short Z50r cable will actuate the lever.
(https://uploads.tapatalk-cdn.com/20171021/6264d56bf80095c5de1a253638de8ab7.jpg)
Post by: Hurco550 on Oct 22, 2017, 00:02:31
Looks great! Just curious why you didn't use the beemer under tank mc? Thought you had a spare
Post by: irk miller on Oct 22, 2017, 01:42:52
The BMW m/c is too wide and too tall, itís built for the top of the frame, itís prone to leak, and I gave mine to Charlie at Thaw.
Post by: irk miller on Oct 22, 2017, 01:44:20
The seat is mounted and I finally got to sit on it.
(https://uploads.tapatalk-cdn.com/20171022/d80310c92675eaf160586fe37253e7c9.jpg)
(https://uploads.tapatalk-cdn.com/20171022/5f453e0cf08ece66a3478d8dd05f1c5d.jpg)
Post by: trek97 on Oct 22, 2017, 08:02:36
Well then, how'd it fit?
Post by: trek97 on Oct 22, 2017, 08:18:36
Deserving of some hipster sprinkles.
(http://www.dotheton.com/gallery/11494-221017061720.png)
Post by: irk miller on Oct 22, 2017, 12:35:47
(https://uploads.tapatalk-cdn.com/20171022/f734b20d96da951ac2602ba9272d7679.jpg)
Post by: irk miller on Oct 22, 2017, 13:41:15
Progress shot. Still waiting on the good condition tank and Iím crossing my fingers on a couple of eBay auctions for a rear fender...
(https://uploads.tapatalk-cdn.com/20171022/bf728e750267eac8ed26cbba1276b0eb.jpg)
Post by: Maritime on Oct 23, 2017, 08:28:09
This thing is really shaping up nice. I'm liking it a lot now. Excited to see the finished product.
Post by: Cookie on Oct 23, 2017, 09:11:52
This thing is coming along fantastically Eric!
If your eBay fender prospects fall through, PM Me, I might be able to help out.
Post by: irk miller on Oct 24, 2017, 02:08:45
Thanks, Cookie. I got the priority fender, so weíll see how this goes.
I took a chance on a homemade $10 oil tank on Ebay. I was pretty sure it had 750 size connections and it in fact did. The question is if 1.25 quarts is enough.
(https://uploads.tapatalk-cdn.com/20171024/650f4d16d10a2b5bb4d0e85b136da583.jpg)
Post by: jag767 on Oct 24, 2017, 08:50:37
How much would the capicity go up with an oil cooler?
Post by: cxman on Oct 24, 2017, 10:08:40
add a remote oil filter and use the long chevy filter that will boost it a quart with the lines
Post by: irk miller on Oct 25, 2017, 00:17:17
The new XL350 tank got delivered today. Itís got a few dings, but man the patina is glorious. Iíll have to think really hard about painting this tank.
(https://uploads.tapatalk-cdn.com/20171025/de03c71827d464c86f9dc0c881635688.jpg)
I also began work on a Cush drive conversion experiment. Itís an RM250 wheel, so no Cush. I could swap for DR350s, but people want silly money for them.  I still have a few details to work out, including casting the urethane innards...
(https://uploads.tapatalk-cdn.com/20171025/b0e34fcc42178d7efd3ca0cc4f3b08d3.jpg)
(https://uploads.tapatalk-cdn.com/20171025/5faf77754b5b594a7907d24dd2f16b61.jpg)
Post by: Hurco550 on Oct 25, 2017, 08:52:56
that tank is the beez kneez. Don't know how far you'll get between fill ups, but my guess is you'll be aching for a break at that point anyways
Post by: irk miller on Oct 25, 2017, 09:01:58
No more than if it had a Frisco, Peanut, Wassel, Axed, Coffin, Prism, Sportster, or Alien tank.  It's exactly the same volume.
Post by: Hurco550 on Oct 25, 2017, 09:20:12
Yeah I guess I hadn't even thought about it compared to it regular old Chopper tank
Post by: irk miller on Oct 25, 2017, 09:32:31
Which basically means... I'll be stopping a lot.  LOL
Post by: Hurco550 on Oct 25, 2017, 09:43:28
Saddlebag gas can ftw. (https://uploads.tapatalk-cdn.com/20171025/c658a94cbae49c02b1a9b251855b0ae0.jpg)
Post by: 1fasgsxr on Oct 25, 2017, 10:01:25
Yup that tank is the one and I would not paint it either.
Post by: canyoncarver on Oct 25, 2017, 12:29:01
Yeah.  My 3.5 gal tank on my chop only get me so far and I'm usually ready to stop by then anyways.
I dig that tank you got.  I vote keep the patina.
Post by: advCo on Oct 25, 2017, 12:41:24
Where's the patina? All i see is a rogue rattle can spot on the side  ???
Post by: Maritime on Oct 25, 2017, 12:51:22
That's not rattle can, that's were knees have rubbed through the red to expose the black base coat.
Post by: irk miller on Oct 25, 2017, 13:15:29
That^
Post by: Hurco550 on Oct 25, 2017, 13:29:36
alright, so now you gotta change out the seat or put high mid controls on so your knees match the rub marks lol
you cant look like a poser here
Added benefit, you can cut a hole in the seat and have a squatty potty.
(https://uploads.tapatalk-cdn.com/20171025/87ec10835462da642a0dd3797a9569af.jpg)(https://uploads.tapatalk-cdn.com/20171025/e76969395234a24e06adec51719a45ce.jpg)
Post by: irk miller on Oct 25, 2017, 13:39:23
Ha!  I'm not moving the pegs from their stock location, so it may be a bit like that.  I don't want forward controls.  Although that thing looks like the pegs are raised.
Post by: Hurco550 on Oct 25, 2017, 13:42:17
Yeah those are called high mids. I've never cared for the looks but I'm led to believe it's for turning lean clearance... since Choppers are high performance handling machines and all
Post by: canyoncarver on Oct 25, 2017, 14:09:42
"California Dyna Bros"  love those high mids.  Me, mids yes, high mids hell no.
You'll need to "shop your look" though.......     ;)
Post by: irk miller on Oct 26, 2017, 22:01:16
A little update on the front brake rig. A motor mount fit perfectly with just a little bend...
(https://uploads.tapatalk-cdn.com/20171027/650cd3748c5cb04285cc8adabc364b46.jpg)
Post by: irk miller on Oct 29, 2017, 12:19:51
I bobbed and shaved a Harley Softail rear fender.
(https://uploads.tapatalk-cdn.com/20171029/5d09866ad902c7283fe033692b5d485d.jpg)
(https://uploads.tapatalk-cdn.com/20171029/37970c291e8bf91311f3b9ea53d3b5b1.jpg)
Hereís what it looked like before for reference:
(https://uploads.tapatalk-cdn.com/20171029/afc4f46659fec20e47cd3383592e49af.png)
Post by: irk miller on Oct 29, 2017, 15:42:00
Turn signal switch
(https://uploads.tapatalk-cdn.com/20171029/8b39f115a8f1bf3cb0ef4660d9cd1fea.jpg)
Post by: trek97 on Oct 29, 2017, 18:16:13
Thats a good job on the fender metal shaping.
Post by: stroker crazy on Oct 29, 2017, 19:13:31
A major improvement!
Crazy
Post by: Maritime on Oct 29, 2017, 19:19:08
Yep great work on the fender.
Post by: irk miller on Oct 29, 2017, 23:22:34
(https://uploads.tapatalk-cdn.com/20171030/870505ff9423e37af155eb5fae457b6d.jpg)
Post by: irk miller on Nov 02, 2017, 00:49:08
The fender is officially mounted. Also running an old Harley tail light. The lens was pretty scratched, but a 1200 grit wet sand and Meguiarís 105 hand rub later and itís nice and shiny like new...
(https://uploads.tapatalk-cdn.com/20171102/84443f8348ae5043d912018308c4658f.jpg)
(https://uploads.tapatalk-cdn.com/20171102/1f7161350c6aeea46378ac8e50200dbe.jpg)
(https://uploads.tapatalk-cdn.com/20171102/248c82cb721d4aa7bb25efe9921488f0.jpg)
Post by: JustinLonghorn on Nov 02, 2017, 09:27:27
Yep.
Post by: canyoncarver on Nov 02, 2017, 12:02:26
Awesome!
Post by: irk miller on Nov 03, 2017, 00:51:03
(https://uploads.tapatalk-cdn.com/20171103/f36c154e5204d3cb75fe1fbc510e0a15.jpg)
I decided to mount the oil tank tight to the engine. Except now my stock feed line just slightly wont fit. It may not be an issue anyway if I run an oil cooler.  I may run a cooler in the bottom of the frame behind the motor.
Post by: WhyNot on Nov 03, 2017, 06:46:41
Dayyyyyyum Eric, you get that thing done, we definitely need to go out for a ride around Augusta.
I like that bike.  Good job.
Post by: canyoncarver on Nov 03, 2017, 12:05:51
I'd vote yes to the oil cooler, you live in the south and it'll add room for a bit more oil than that little tank can hold.  The oil cooler I added to my chop sure helps with summer oil temps.
Post by: Maritime on Nov 03, 2017, 13:07:02
+1 on the cooler and this thing is rad.
Post by: irk miller on Nov 03, 2017, 13:22:47
I ordered a cooler from a 2003 Eiger 400.  A shot in the wind on size, so we'll have to see when it arrives.  If it doesn't work for the chop, then it can go on my DR350 since they are fundamentally the same engine.
Post by: doc_rot on Nov 03, 2017, 19:08:25
I'm digging that 19" rear wheel
Post by: irk miller on Nov 03, 2017, 19:34:14
Thanks, Doc.  It's a different look for a chop, but I like it.  One caveat, obviously, is the lack of tire options which is why I went medium compound flat track for a fatter tire.  Avon makes an rear tire (AM7 4.00-19) that I may try next.  It's a cool looking vintage tire with more of a square patch.  The only other options I've found are a Metzler Block-C (3.5-19) , Avon MKII (3.50-19) and the Avon Roadriders (3.25-19), which are front/back tires.
Post by: Hurco550 on Nov 09, 2017, 08:48:49
are you slacking?
its been like 6 days without an update.
 Unacceptable.
Post by: irk miller on Nov 09, 2017, 08:52:03
are you slacking?
 Unacceptable.
No one wants to pay me the money they owe me  :( , so I'm broke.  I found a DR350 cush hub though, that a guy is sending me for the cost of shipping.  :D
Post by: Hurco550 on Nov 09, 2017, 08:54:03
If you need the sprocket carrier hub for it.. I've got one
Post by: irk miller on Nov 09, 2017, 08:55:32
Thanks!  He said he thinks he lost one of the rubbers.  Do you have those too?
Post by: john83 on Nov 15, 2017, 23:52:33
Damn you work quick. That's a good looking chopper you've got coming along there sir.
Post by: irk miller on Nov 16, 2017, 07:59:26
Thanks, John.  It's somewhat stalled for the moment.  I have some decisions to make and they're making movement slow.
Post by: SONIC. on Nov 16, 2017, 11:05:10
I expected this to be finishes by now.
And then cut up into something else and that would be finished too.
Slacking
Post by: irk miller on Nov 16, 2017, 11:08:43
Slacking
LOL.  eBay sellers are fucking slow to ship sometimes.  I did, however, get my DR running again last night.  It's ready for some Tennessee trails.
Post by: surffly on Nov 16, 2017, 11:17:18
Needs more finned engine covers!
I know a guy....lol
Post by: Hurco550 on Nov 16, 2017, 12:52:20
I did get my DR running again last night.  It's ready for some Tennessee trails.
DUDE YESSSSSSSSSS
Post by: irk miller on Nov 18, 2017, 02:21:31
(https://uploads.tapatalk-cdn.com/20171118/e68e57b583f32404cbcb219eb5efe50e.jpg)
I was able to get a DR350 hub from a member at ADVrider. I reached out to Buchanan to see if we can match some spokes.
Post by: clem on Nov 18, 2017, 18:08:18
How wide is that there hub?
Post by: irk miller on Nov 18, 2017, 22:26:42
6 3/4"
Post by: clem on Nov 19, 2017, 23:12:31
Pretty slim. For some odd reason I've got the envie to put a set of spoke rims on my RD. Was looking at the KLR 650 stuff but have no ideas on dimensions on those.
Post by: irk miller on Nov 21, 2017, 13:46:47
A little update:
Front brake is done.
Iím running a Z50 cable from the lever to the m/c. Then a 3an straight fitting instead of a banjo...
(https://uploads.tapatalk-cdn.com/20171121/7469735eaef42d8e597df6ab566a79fb.jpg)
(https://uploads.tapatalk-cdn.com/20171121/6ea1bf4bdc869c10859dbd981d83e637.jpg)
(https://uploads.tapatalk-cdn.com/20171121/c430c4c91040eead71177c37de317b1e.jpg)
The caliper has a banjo to 3an fitting.
(https://uploads.tapatalk-cdn.com/20171121/a8945976ec751fd1a6c661d12f8db82c.jpg)
Then the top fork guard mount is altered (tabs removed) to accommodate a brake line guide. The line runs through a machined sleeve of black acetal.
(https://uploads.tapatalk-cdn.com/20171121/9e1437a349aa515f9d42e014cfac6bfb.jpg)
(https://uploads.tapatalk-cdn.com/20171121/51bf47fd0167568fa5788b60890b34d3.jpg)
Post by: Maritime on Nov 21, 2017, 13:54:20
Slick
Post by: 1fasgsxr on Nov 21, 2017, 15:55:59
This damn thing is awesome !
Post by: trek97 on Nov 21, 2017, 21:19:05
Post by: irk miller on Nov 21, 2017, 21:31:53
Thanks, yíall.
A little Rub ní Buff makes the plastic blend like aluminum...
(https://uploads.tapatalk-cdn.com/20171122/ad9f7601a578117ea601333da701fe60.jpg)
Post by: irk miller on Nov 30, 2017, 21:35:06
Just to keep this thread a-moviní along...
Iím kind of stuck trying to get the oil cooler/tank situation sorted. First, I ordered an Eiger oil cooler, which was too long. So, I swung again and tried a Suzuki Intruder oil cooler...
(https://uploads.tapatalk-cdn.com/20171201/dd9e8327e2fab5e480aaa6e7c7059cf4.jpg)
Muuuuch better.
I also ordered some extra length of SS line to give me some extra volume...
(https://uploads.tapatalk-cdn.com/20171201/913ced80c78279ebbc199b6354227e66.jpg)
Then I separated the case fittings from the stock lines, which basically match to 10an hose...
(https://uploads.tapatalk-cdn.com/20171201/a5e1024c7fcaa8e9fcec40a6da6fe470.jpg)
Now, itís just a waiting game on some hose finishers and the fittings for the cooler. Iíll convert the banjo fittings to a setup with M12x1.0 to -10an fittings.
Note to self: donít order from China unless itís a last resort. You prefer days over weeks for delivery. Nothing stalls a build like this.
Post by: canyoncarver on Nov 30, 2017, 21:51:22
Truth.
Post by: Hurco550 on Nov 30, 2017, 23:00:36
Its funny though, I ordered rotors from China for the interceptor and they were on my door step in less than 3 days. Its a crap shoot
Post by: irk miller on Dec 05, 2017, 01:36:01
Oil stuff
---> oil tank ---> cooler ---> motor inlet ---> motor outlet ---> oil tank --->
(https://uploads.tapatalk-cdn.com/20171205/e2207c7363437b5dfefffcfa7203bc8b.jpg)
(https://uploads.tapatalk-cdn.com/20171205/76a4112e67098fb38d67ef31a8618f2f.jpg)
(https://uploads.tapatalk-cdn.com/20171205/08f34644beb828bd72ff1ffc1c4ded9b.jpg)
Post by: canyoncarver on Dec 05, 2017, 12:01:08
Looking good.  Something tells me you are itching to ride this one.
Post by: irk miller on Dec 05, 2017, 14:15:40
Big time.
Post by: trek97 on Dec 05, 2017, 19:57:11
He's just itchy cause he needs a bath.
Post by: Hurco550 on Jan 10, 2018, 12:01:14
i just got the 30 day reply notice. This is ridiculous. You have too many bmw's distracting you.
NEED.
MORE.
CHOPPAHHHHHHHHH!
Post by: irk miller on Jan 10, 2018, 12:12:43
CHOPPAHHHHHHHHH!
Hahahaha!  If people didn't turn to all dirt for Thaw, maybe I wouldn't feel so pressured to get something to ride there.  Seriously though, I'm teaching myself leather working for this mutha's seat.
Post by: Hurco550 on Jan 10, 2018, 12:22:22
heard that man. I have a few things i wanted to do on my beemer this winter, but alas all my time has been spent on the dr650.
#thawprep
Post by: irk miller on Jan 21, 2018, 19:10:36
Made a few moves on the chopper and maybe hit a snag too:
 I pulled the cover, checked compression, and a few other bits to get an idea of the life of this motor. Itís showing 160 compression across all 4 cylinders.but the motor lost power above 60mph and fouled the #4 plug. I always thought electrical, and Iím back to thinking that again.  For now, I buttoned it back up in anticipation of wiring.
Next, I installed the F2 exhaust and found that it doesnít quite clear the frame at the collector and hangs low enough to give me shit for lean clearance.  Fuck.
(https://uploads.tapatalk-cdn.com/20180121/5f85e0676a651f865f73adbfc4c77874.jpg)
I have to decide if I want to alter this exhaust with some heat to get the clearance and pull it tight to frame, or fork out the dough for another exhaust. I could probably afford another exhaust for what these can sell for.
(https://uploads.tapatalk-cdn.com/20180121/2340e1716dc33a2d2b43c499e63b2609.jpg)
Otherwise, Iím very close to wiring it up and at least hearing it run.
(https://uploads.tapatalk-cdn.com/20180121/0dcf7c634ad6a4ece11b387abeb9463b.jpg)
Also: seconds thoughts on the style of seat, so weíll hold off on covering until there are no doubts.
Post by: canyoncarver on Jan 21, 2018, 22:20:15
Man that looks good.  What kind of second ideas on the seat?  I like that one.
Post by: irk miller on Jan 21, 2018, 22:27:03
Trying to decide if I want a seat that is more boxed out underneath to hide electronics.  I have that box you sent me with the frame, but I may try to go a little more hidden.  I do like this seat, and with the Italian leather, it could be sexy. Just thinking through electric ideas and ways to hide it.
Post by: trek97 on Jan 21, 2018, 22:38:15
Dude thats looking awesome.
Post by: WhyNot on Jan 22, 2018, 06:55:09
^^^^^^What Trek said^^^^^^............................dayyyyum.
Post by: JustinLonghorn on Jan 25, 2018, 15:47:12
I dig the stance, sir. Well done. Very well done.
Post by: doc_rot on Jan 25, 2018, 19:09:23
using the dirt-bike forks for length and leading axle is genius. nice work
Post by: Rider52 on Jan 25, 2018, 19:50:26
Great job!!!!
Post by: Popeye SXM on Jan 25, 2018, 20:04:46
Hell I don't normally go for choppers, but I like your's, maybe it's usd forks. Perhaps a higher seat with the electrics underneath?? Great work
Post by: TranceMachineVienna on Jan 26, 2018, 08:38:35
Hey irk!May I ask how did you get that nice tank to fit?did you cut out something on the bottom and weld something back in like on the BMW build?
thanks
Post by: irk miller on Jan 26, 2018, 08:42:40
thanks
Because it's a chopper frame, it pretty much just fit.  The XL frame it came off of basically has the same spine.
Post by: TranceMachineVienna on Jan 26, 2018, 08:54:52
Nice thanks man!
Post by: irk miller on Apr 14, 2018, 21:00:55
Local guy was selling a HD and 72 XS tank fit cheap, so I picked them up to test out...
HD tank doesnít look bad at all...
Post by: Hurco550 on Apr 14, 2018, 21:40:47
That Harley tank does fit the bill. Still like the patina Honda one though
Post by: canyoncarver on Apr 15, 2018, 16:50:57
I like that tank on your bike alot.  Fits the lines well.  I had another thought.  I would go with a longer front end.  Crazy maybe but , another few inches, it would sit the engine slightly more vertical and help with the ground clearance with the pipes.  I like those with the leading axles you have, maybe drop triples for a different offset ?
It would also be rad.
Either way, I wanna see this one through.  I dig your chop.
Post by: irk miller on Apr 15, 2018, 19:20:31
It's possible that the forks are dropped an inch or two from the weight of the bike.  I haven't gotten Doug to set these forks up for this bike yet, since I need to have it more compete to give him the weight.  I've definitely noticed it drops under weight.
Post by: irk miller on Apr 15, 2018, 19:33:56
Something else I'm looking at, which may be too bulky, is this Paughco seat I got a good deal on...
(http://www.dotheton.com/gallery/77150-150418173221.jpeg)
Post by: cbrianroll on Apr 16, 2018, 15:01:04
Haven't been on in a while, looking awesome man! I like the other seat.
Sent from my SM-G930V using DO THE TON mobile app (http://r.tapatalk.com/byo?rid=89466)
Post by: 1fasgsxr on Apr 17, 2018, 10:21:50
I like the other one, but my butt is not gonna be sitting on it so.... ;)
Post by: Jimbonaut on Apr 20, 2018, 10:44:23
 Man I love the lines on your bike, such a cool profile.  Me I prefer the bobber-style seat pan more but yeah, my ass won't be sitting on it either   :o
Post by: irk miller on Apr 20, 2018, 10:50:43
Haha. No comfort, no worries.  I still plan to make a leather seat for it with the pan I made.  It occurred to me the other night that the Softail seat might make sense on a GL I have stored away.  We'll see.
Post by: Jimbonaut on Apr 20, 2018, 11:07:45
Ha!  No comfort, no worries - sounds like the mantra my wife and I lived by when we spent three summers living in our '78 VW camper van/mobile oven in Ibiza
Post by: irk miller on May 13, 2018, 15:09:23
A while back, I bought a CR500 front end specifically for a chopper build.  It was my original intent for this build. Then I tried out the RM front and thought is was neat and different.   Well, with a low clearance issue I decided to revisit the CR front end. Much better ride height and I think a better look...
Post by: Redbird on May 13, 2018, 18:03:06
What happened to the boxed plunger axle plates?
Post by: irk miller on May 13, 2018, 21:10:36
I swapped it out.  I'm trying to make it as boring as I can.  But seriously, they had an upswing I needed to sort out so I ended up re-doing the whole rear end altogether.
Post by: trek97 on May 13, 2018, 21:35:35
I did prefer how the Honda tank sat lower on the frame.  But thats just me.
Its looking really good this way too.
Post by: irk miller on May 14, 2018, 00:02:01
We may go back.  Lots of looking, fitting, and swapping still to come.  I like the XL tank, too.  This HD tank is a little more capacity and doesn't have the cutout meant for a carb like the XL tank.
Post by: SONIC. on May 14, 2018, 10:09:10
But....But.... now it just looks like a chopper   :-\
I know I suck. Gotta call it like I see it!
Post by: irk miller on May 14, 2018, 10:27:30
Ha!  I like choppers.   ::)
Post by: JustinLonghorn on May 14, 2018, 12:31:17
I dig this front end a lot more, Irk.
Post by: Maritime on May 14, 2018, 13:03:13
I like this front too. Tank is ok too, maybe you can paint a couple and swap them out every once and a while for a different look depending on your mood.
Post by: canyoncarver on May 16, 2018, 16:40:26
Can you remove that plastic dookie from the rear disc?
I dig the hd tank and new frontend.
Post by: irk miller on May 16, 2018, 18:30:17
Absolutely.  That will go away.  I actually have a different DR350SE hub to swap out.  I'm just motivating myself to take this wheel apart.  Right now it rolls and with all the shit I have in the garage, i like that it rolls.
Post by: irk miller on May 17, 2018, 20:41:53
Not really happy with my oil bag setup, I decided to suck it up and go with a pill. I was really hoping to be atypical, but this is really a sweet little doodad...
Post by: TranceMachineVienna on May 18, 2018, 04:08:38
I love the pill!
Post by: canyoncarver on May 18, 2018, 11:51:23
Will it be a Red Pill or Blue Pill?
Post by: irk miller on May 20, 2018, 00:44:45
Took the rear wheel apart to swap hubs only to discover a crack. I heard a pop when taking the tire off. Couldíve been then. Couldíve been before. Itís a used RM250 rim, so I expect it had a hard life. Fine excuse to buy a new rim...
Post by: MiniatureNinja on May 20, 2018, 13:06:13
probably the only downside to aluminium - bummer!
Post by: Sonreir on May 21, 2018, 11:14:53
I've got a spare 21" aluminum wheel if you want it.
Post by: irk miller on May 21, 2018, 11:27:17
Much thanks!  I went ahead and ordered a new hoop.  I like the idea of having a fresh hoop.
Post by: Sonreir on May 21, 2018, 11:34:51
(https://emojipedia-us.s3.amazonaws.com/thumbs/120/emoji-one/104/thumbs-up-sign_1f44d.png)
Post by: irk miller on May 24, 2018, 23:56:09
Got the new rear rim laced to the cush hub. Now Iím trying to motivate myself to mount a tire.
Post by: Maritime on May 25, 2018, 08:26:40
Nice. I just picked up the motorcycle mount stand from HF for 25% off and no tax, haven't tried it yet but it's supposed to work well. It will at least put the tire at waste height so I won't have to kneel on the floor LOL. Also grabbed the balance/truing stand to go with it.
Post by: irk miller on May 25, 2018, 09:02:55
I didn't go with the HF truing stand because it's not tall enough for 21" wheels.  This one I got through Amazon, iirc.
Post by: Maritime on May 25, 2018, 09:21:11
Cool. I didn't think of that but since it was 25% off of 30.00 I grabbed it. Better than an old axle and jack stands I used to use.  That hoop looks great, what kind of tyre are you putting on it?
Post by: irk miller on May 25, 2018, 11:21:03
Putting the same Shinko flat track tire that was on it before.
(https://www.cyclegear.com/_a/product_images/0214/8930/shinko_tires267268_flat_track_tires_750x750.jpg)
Post by: Maritime on May 25, 2018, 11:46:07
Cool. I like those
Post by: irk miller on May 29, 2018, 18:02:32
Spending a little time catching back up from the ground I lost changing the hub and oil tank.  I machined the spacers to get the rear wheels sorted.  The sprocket and rotor are en route, so there may be adjustments still to come.  One thing I'm figuring out, the DR350 and the RM shared a lot of parts.  The DR350SE and the RM do not.
(http://www.dotheton.com/gallery/77150-290518155237-38231706.jpeg)
I also plumbed the oil tank.  It took going from 1/4" npt at the tank to 10AN in the lines and the motor.  I drilled out the adapter fitting coming from the 1/4" npt elbow at the tank to keep the flow from the motor consistent.  There is very little options out there for a 1/4" npt to 10AN adapters.  These ones came straight from China (the fitting coming from the stainless steel elbows at the tank and connecting to the 10AN elbows for the ss lines)
(http://www.dotheton.com/gallery/77150-290518155239-3825860.jpeg)
(http://www.dotheton.com/gallery/77150-290518155241-38261183.jpeg)
Post by: irk miller on May 29, 2018, 22:21:10
Got the seat back to mounted, as well.  I tried to neaten up the spring mounts by machining and threading some delrin bushings.
(http://www.dotheton.com/gallery/77150-290518201220-3832901.jpeg)
(http://www.dotheton.com/gallery/77150-290518201222-38331275.jpeg)
The bushing in the first pic slides into the spring and mounts the spring to the seat.  Then, the bottom of the spring slides onto the bushings threaded onto the frame.  This allows the seat to hinge up.
(http://www.dotheton.com/gallery/77150-290518201224-38341958.jpeg)
(http://www.dotheton.com/gallery/77150-290518201225-3835519.jpeg)
(http://www.dotheton.com/gallery/77150-290518201229-38372129.jpeg)
Post by: Sonreir on May 30, 2018, 11:10:41
Nice.
Post by: JustinLonghorn on May 30, 2018, 11:34:55
Looking proper, sir.
Post by: irk miller on May 30, 2018, 12:55:11
Thanks, homies. Almost back to where it was before changes. Just need to sort the rear fender and weíre caught back up.
Post by: SONIC. on May 30, 2018, 13:00:49
I like the seat mounts.
And I'll begrudgingly admit that I like the bike too. Even though it's a chopper. Just don't tell anyone I said so.
Post by: canyoncarver on May 30, 2018, 13:12:22
Love it.  Seat, tank, forks, oilbag.....all head towards chopper glory!
Post by: irk miller on Jun 10, 2018, 21:55:15
Machined a bung to thread a low profile cap screw to work as a brake stay.  Not the best pic, but hopefully you get the idea...
(http://www.dotheton.com/gallery/77150-100618194954-3887661.jpeg)
Aaaaand like a tennis match...
(http://www.dotheton.com/gallery/77150-100618194953-38862133.jpeg)
Post by: JustinLonghorn on Jun 11, 2018, 06:59:36
Andre Agassi and the XL tank... Game-Set-Match.
Post by: Maritime on Jun 11, 2018, 09:35:24
Yep, that's the match for sure.
Post by: SONIC. on Jun 11, 2018, 09:37:41
I love that it's too long for the stand
Looking good man!
Post by: irk miller on Jun 11, 2018, 09:58:18
Ha!  I thought about building another one, but fuck it.  This shows how much longer the chop is to a 360.  LOL
Post by: Jimbonaut on Jun 11, 2018, 11:08:15
That looks absolutely killer man, nicely done.  I would do things considered highly immoral to flightless poultry for a chance to fling a leg over it.
Post by: Brodie on Jun 11, 2018, 19:13:40
Xl tank looks better on there anyway.
Post by: irk miller on Jun 11, 2018, 19:19:20
You, sir, are right.  I was worried the XL tank was too small for the pig of a motor the 750's are.  Not the case.  It fits the profile much better.
Post by: Maritime on Jun 11, 2018, 20:22:59
What about widening it so from the top it covets more of the motor but frome the side stays the same?
Post by: irk miller on Jun 12, 2018, 00:00:34
Redid the rear fender struts...
(http://www.dotheton.com/gallery/77150-110618212546-38881682.jpeg)
(http://www.dotheton.com/gallery/77150-110618212548-3889271.jpeg)
(http://www.dotheton.com/gallery/77150-110618212551-38911180.jpeg)
Post by: irk miller on Jun 14, 2018, 21:41:58
I decided to get a better seat hinge.  It's still not the top dollar hinge, but it should suit my needs.  One thing, though, I didn't like about it is the hinge pin was a basic nut and bolt.  Nothing fancy, and certainly nothing nice looking.  So instead, I upgraded it a bit by machining a delrin hinge pin.
(http://www.dotheton.com/gallery/77150-140618192924-3898302.jpeg)
Sometimes it's a bunch of effort for the simplest things.
(http://www.dotheton.com/gallery/77150-140618192925-39001561.jpeg)
(http://www.dotheton.com/gallery/77150-140618192927-39011886.jpeg)
The pin stays stationary, while the hinge rotates around it and it will hold in an upright position, which will make working under the seat easy.
(http://www.dotheton.com/gallery/77150-140618192928-3902205.jpeg)
Post by: Pete12 on Jun 15, 2018, 11:23:54
Ain't that the truth - the last 5% of a project takes ten times longer than it took to do the original 95%...
Post by: irk miller on Jun 16, 2018, 11:07:55
I decided to forgo the Softail tail light for one I machined myself. This bike is officially de-Harleyíd...
(http://www.dotheton.com/gallery/77150-160618091747-39042365.jpeg)
Post by: Maritime on Jun 18, 2018, 08:36:17
Nice
Post by: irk miller on Jun 21, 2018, 02:37:45
After digging around, I realized the oil inlet has to be gravity fed.  The pump does not pull oil from the reservoir.  So, add another bung to the bottom and now we have it right...
(http://www.dotheton.com/gallery/77150-210618002948.jpeg)
Post by: canyoncarver on Jun 21, 2018, 12:22:53
Getting oil to the engine.....seems important.
Post by: irk miller on Jun 25, 2018, 21:51:29
In searching for a small victory in motorcycles and life, in general, I found one with the rear brake. I ordered the wrong length line and the wrong thread pitch fittings the first time. Now itís right...
Post by: JustinLonghorn on Jun 26, 2018, 07:49:22
(https://media.giphy.com/media/CkKg32KdKyMve/giphy.gif)
Post by: canyoncarver on Jun 26, 2018, 13:23:15
Go!
Post by: irk miller on Jun 26, 2018, 13:47:14
Where to cut the tail pipe... or not.
Post by: Sonreir on Jun 26, 2018, 14:05:43
Need another bend in it so it can stick straight up. lol
Post by: irk miller on Jun 26, 2018, 14:08:02
Haha.  Yeah, like a 30į bend at the axle.
Post by: Sonreir on Jun 26, 2018, 14:09:35
Or a 90į when compared against the hard tail.
Post by: irk miller on Jun 26, 2018, 14:27:27
Pipe measures 25į, so a 45į puts it at 70į to level.  I think that will work.
Post by: canyoncarver on Jun 26, 2018, 15:06:28
I like fishtails personally.  If you stick that pipe straight up, don't forget your tractor pipe flapper.  ;)
Post by: irk miller on Jun 26, 2018, 15:08:11
Hahaha!
Post by: irk miller on Jun 26, 2018, 22:38:09
Went with my original plan (at least for now) of cutting  the pipe just behind the axle and machining an end cap to fit.
Post by: Brodie on Jun 26, 2018, 22:49:11
Shmick
Post by: trek97 on Jun 26, 2018, 23:30:12
Its so bad ass bro.  But are you gonna have to pull the exhaust to get the wheel off?
Post by: irk miller on Jun 26, 2018, 23:40:05
Yes and no.  The one bolt to the exhaust bracket could be removed and the pipe pushed up slightly for better access.  The axle, when pushed furthest back, should clear the pipe with the bracket bolt still mounted.
Post by: trek97 on Jun 27, 2018, 06:46:14
NICE!  Just enough is all you need.   8)
Post by: Hurco550 on Jun 28, 2018, 14:40:17
Reminds me of the often used quote in the machining field...
"Clearance is clearance" no matter how little there is lol
Post by: irk miller on Jun 28, 2018, 14:44:53
Ha!  When we were designing the art school for Temple, we're in a meeting choosing equipment.  The fork lift would be shared, so I needed approvals from all departments.  The Sculpture professor argued with me about the unit I recommended because there was only 1" of clearance from the highest point of the fork lift to the smallest door it would need to go through.  I had a hell of a time convincing her that even 1/4" clearance works because fork lifts don't grow.  And when their tires wear, they actually get shorter.  Blew their minds.
Post by: Hurco550 on Jun 28, 2018, 14:55:21
Sounds like educational bureaucracy at its finest. I can't count the times in our trade school that a decision was made for a purchase by the least qualified individual to make said decision, due only to their position in management. Then later on, we are asked why "we never use xxxx piece of equipment?"
On the forklift thing, the last place I worked, we had a lift that the mast wouldn't fit though one doorway by about 1.5"... until the new guy straight up Larry enticer sent it full speed while not paying attention. It now fits, if only in the same spot, just to the left of center iirc lol
Post by: irk miller on Jun 28, 2018, 19:37:06
Still making changes, I converted the exhaust to slash cut...
(http://www.dotheton.com/gallery/77150-280618173412-39831216.jpeg)
(http://www.dotheton.com/gallery/77150-280618173413-3984611.jpeg)
(http://www.dotheton.com/gallery/77150-280618173414-3985751.jpeg)
(http://www.dotheton.com/gallery/77150-280618173416-39861776.jpeg)
Post by: JustinLonghorn on Jun 28, 2018, 21:31:49
Proper.
Post by: irk miller on Jun 29, 2018, 01:42:59
I stripped the rest of the paint off the fender, ran the factory flat spot through the English wheel to match the fender profile and now Iím filling holes. When itís done, only the round and oval hole above the square will remain.
Post by: irk miller on Jun 29, 2018, 13:55:02
Needs a little filler, but goodínuff.
Post by: trek97 on Jun 29, 2018, 14:33:02
Yes sir.
Post by: irk miller on Jun 29, 2018, 17:45:19
Might not seem like much, but I added an inch to the fender struts and moved their angle to match the down tube in front of the seat. This changes the fenderís orientation so that it matches the wheel shape much more neatly. It makes for some nice  filigree.
Post by: JustinLonghorn on Jun 29, 2018, 18:44:10
Much much better. I am a fan of matching the angle of either the downtube or the front forks.
Post by: Pete12 on Jun 29, 2018, 19:26:39
That looks a lot better, guard fits the wheel nicely now.
Post by: Maritime on Jun 29, 2018, 21:05:27
Yep
 Better for sure. You and your fancy filigree ;D
Post by: irk miller on Jun 29, 2018, 23:23:48
Final post about the exhaust to finish up the tail pipe on the inlet...
(http://www.dotheton.com/gallery/77150-290618211749-398749.jpeg)
(http://www.dotheton.com/gallery/77150-290618211752-3989300.jpeg)
(http://www.dotheton.com/gallery/77150-290618211755-39912362.jpeg)
Post by: trek97 on Jun 30, 2018, 05:50:23
Well now, that'll put the pinch to it.
Post by: 3DogNate on Jul 02, 2018, 21:28:15
Sweet child of mine... that looks cool. keep cuttin' and weldin'
Post by: Maritime on Jul 04, 2018, 10:48:07
Slick
Post by: irk miller on Jul 12, 2018, 18:10:12
I took some time off from working on the Mid-Ohio haul to make the chain tensioner.  I machined the drum and welded an old gear shift lever to it and a cap screw to the shift lever.  I machined a bronze bushing to insert into the drum, then on the backside I machined a delrin bushing to fill around the bronze.
In all but the last pic, the arm is basically straight.  In the completed unit, I bent an "S" into the lever which centers the skateboard wheel over the pivot and moves it clear of the frame.
In this pic are all the components minus the spacer to go behind the skateboard wheel that centers it to the chain.
(http://www.dotheton.com/gallery/77150-120718152111-40371124.jpeg)
This is the backside of the tensioner, where the delrin surrounds the bronze.
(http://www.dotheton.com/gallery/77150-120718151555-40352167.jpeg)
Here's the unit put together with the spring from a kickstart mechanism.  One thing that changes on the spring from what you see in the pic, I spread the first coil out to help put more tension on the spring and to help it spring back a little better.  That may not have been necessary, but it doesn't hurt either.
(http://www.dotheton.com/gallery/77150-120718153940-404077.jpeg)
Another view of the arm and pivot.  Notice the drum isn't machined square, but instead has a curve to it.  This helps the spring move toward the arm and keeps it from binding in front of the mechanism.  It also gives it more throw, as the way the spring works the ID shrinks when the tensioner actuates.  I didn't want the spring too loose, but too tight kept it from swinging very far and it would bind.
(http://www.dotheton.com/gallery/77150-120718153941-4041849.jpeg)
This is the pic of the completed tensioner.  The arm is bent, which moves the wheel back toward the center of the bike.  The arm is also shorter than in the previous pics.
(http://www.dotheton.com/gallery/77150-120718155254-40421304.jpeg)
(http://www.dotheton.com/gallery/77150-120718155255-40432394.jpeg)
Post by: advCo on Jul 12, 2018, 18:22:07
Slick as shit man. Nice.  8)
Post by: Maritime on Jul 12, 2018, 18:29:06
Yep. Thats awesome
Post by: irk miller on Jul 12, 2018, 20:14:52
I haven't taken any pics from this side.
(http://www.dotheton.com/gallery/77150-120718181313.jpeg)
Post by: WhyNot on Jul 13, 2018, 06:39:58
Man, that is slick.
Looks like you'll have this on the road b4 I get my lazy azz out and fix my carbs, and get mine running again.
Nice work Eric.
Post by: Pete12 on Jul 13, 2018, 10:52:12
Hey Irk, nice bike for sure, but what's the black coupe behind it?
Post by: Brodie on Jul 13, 2018, 11:04:00
Wall art.
Post by: irk miller on Jul 13, 2018, 11:11:25
Wall art.
Haha.  For now it is, Brodie.  Except it's more the wall than the art.
It's a 1970 Plymouth Roadrunner.
Post by: advCo on Jul 13, 2018, 11:24:08
A 21' long shelf? I have one of those but its a few feet shorter.  ;D
Post by: canyoncarver on Jul 13, 2018, 12:11:28
The chain tensioner is slick.  I dig that it even uses the cool Peralta wheel.   I hope this bike makes it to Barber.
Post by: irk miller on Jul 13, 2018, 12:19:28
Thanks, homie.  I have every intention of bringing this to Barber.
Post by: Pete12 on Jul 15, 2018, 07:29:03
Sweet, when are you starting on that :D
Post by: irk miller on Jul 15, 2018, 10:36:51
Haha.  2033, or next summer. My brother and I both have one from my dad.  His was the one dad drove in high school.  Mine is one he traded for a flatbed of creosote fencing lumber in 1981.  Not having a garage and my mother sick of a bunch of cars, boats and campers littering the property got my bro and I an early inheritance. It sat under a black walnut tree untouched for 30 years so, needless to say, it needs a lot of work.
Post by: Pete12 on Jul 15, 2018, 19:45:19
Great story, and whether it's next summer or 2033, I'm looking forward to it. Always been a Mopar fan, unfortunately we didn't get any of those in Australia,
Apologies for the thread hijack..
Post by: irk miller on Jul 23, 2018, 18:52:56
Got my new vin plate from Switzerland.
Post by: canyoncarver on Jul 23, 2018, 19:40:07
That's what we're talking about!  Got to have those papers.
Post by: cbrianroll on Jul 24, 2018, 01:03:36
I've never made a tensioner....chain wont wander on the wheel since there's no grooves?
Post by: irk miller on Jul 24, 2018, 01:30:22
It needs to be wide enough to keep it on the wheel, and the wheel will develop a groove that keeps the chain inline.  Some guys on the Hondachopper forum say a tensioner is noisy or no good.  We'll see.  One guy used a sprocket tensioner and claims it makes the chain wear faster. He went to a static tensioner with an adjustment. The other guy decided to go without a tensioner at all.  So, neither was like mine.  The spring doesn't have a crazy rate.  In fact it's not much at all.  The wheel is really to keep the chain from slapping around, much like an idler pulley on a car.  They don't exert a whole lot of force on the belt, and neither will this tensioner.
Post by: MiniatureNinja on Jul 24, 2018, 15:07:14
How did you come by that vin tag?
Post by: irk miller on Jul 24, 2018, 16:20:25
http://www.khneisser.ch/
I have a registered and titled frame.  I'm just transferring the numbers to this chopper.
Post by: MiniatureNinja on Jul 25, 2018, 01:14:03
no that's just good information I have a registed and titled bike but the tag is really messed up
Post by: irk miller on Jul 30, 2018, 20:05:30
I made a stainless battery box, so I can make an attempt to install my Shorai LiFePo, wiring and electronics under the tank and in the tunnel.
(http://www.dotheton.com/gallery/77150-300718180112-41822267.jpeg)
(http://www.dotheton.com/gallery/77150-300718180114-4184317.jpeg)
Post by: Maritime on Jul 31, 2018, 08:22:40
Slick, that's hides in there well.
Post by: JustinLonghorn on Jul 31, 2018, 10:28:41
Dig it!
Post by: irk miller on Aug 01, 2018, 00:15:12
Been telling myself all summer that I want to try to learn to hand stitch leather. I'm not one to practice on scraps or random shit.  I just jump in with two feet.  I figure, If i fuck it up, I'll just do it again.  So, my first attempt at a hand stitched leather seat...
(http://www.dotheton.com/gallery/77150-310718220604-41891185.jpeg)
(http://www.dotheton.com/gallery/77150-310718220603-41861236.jpeg)
It's an Italian leather my mentor, friend, former boss, and graduate advisor, Nick Kripal, gave me 7 years ago.  He passed away last year from pancreatic cancer, so I knew it was time to do something proper with this skin.
Post by: Hurco550 on Aug 01, 2018, 01:22:56
If that's your first try, I'm really looking forward to seeing your next one. Looks great man!!
Awesome homage to your mentor. You could buy any seat out there and still not have one with that much value.
Post by: Sonreir on Aug 01, 2018, 11:56:41
Sharp.
Post by: irk miller on Aug 01, 2018, 12:57:10
Thanks, yíall. I sanded and burnished the edges, which I shouldía done before the previous pics. It cleans it up a lot. Also, rubbed it in mink oil to help make it waterproof.
Next item I lucked out with is a Henry Abe breadbox air filter. It had rust on the face which polished out decently enough. Cost me $45 shipped from a dude on Hondachopper.com.
Post by: canyoncarver on Aug 01, 2018, 13:14:41
That's a neat airbox.  Nice score.  Love the seat man.
Post by: advCo on Aug 01, 2018, 13:21:51
Sweet shiny bits! Great job on the seat. I've been wanting to try leatherworking.
Post by: 1fasgsxr on Aug 01, 2018, 13:25:15
This thing is just all kinds of kick ass awesomeness!
Post by: JustinLonghorn on Aug 01, 2018, 13:43:50
So, uh, ya done yet?
Post by: irk miller on Aug 01, 2018, 13:48:26
Quick little progress shot for perspective. Looks like Iím wiring and paint away from complete. Iíll wire it, ride it, sort out kinks, disassemble, then paint. Also sending the field coil to rebuild. It didnít check out before. Iíll check again first, but I think itís bad.
Sent from my iPhone using DO THE TON (http://r.tapatalk.com/byo?rid=89466)
Post by: Jimbonaut on Aug 01, 2018, 13:48:39
Hand-stiched leather seat, breadbox air filter...this bike just gets cooler and cooler
Post by: Jimbonaut on Aug 01, 2018, 13:54:36
Last thing you need is any input Irk, you've got this all taken care of.  But I wonder how that seat would look backed up about 4", or kick up the rear of the seat a bit
Post by: irk miller on Aug 01, 2018, 14:35:36
This is why I like to post progress shots, to see how everything looks as a composition.  I hadn't thought of leveling the seat.  It's worth a gander.  Placement front to back is relative to ride position.  I have 1.25" to the fender and about an inch to move forward towards the tank.  I'm a shorty at 5'6", so the seat's current spot puts me at a good relaxed posture.
Title: CB750 No Plunger Hellride
Post by: Jimbonaut on Aug 01, 2018, 19:47:18
Oh yeah, for sure. Gotta make sure you reach those pedals. Reckon bumping up the back of that saddle would really define it, could even make it comfier too
Edited to add - Of course it could totally bugger up the profile completely. In which case disregard everything I was never here I never said nothing
Post by: irk miller on Aug 04, 2018, 02:09:20
Since this is going to be kick only, I'm deleting the starter and using the starter tray for an electronics tray.  What isn't under the tank, or in the headlight bucket, will be here.
Since the starter tray lid mounted to the actual starter, I need another way to attach it, so one screw will thread into the starter delete plug.
(http://www.dotheton.com/gallery/77150-040818000114-41931454.jpeg)
(http://www.dotheton.com/gallery/77150-040818000119-42082067.jpeg)
(http://www.dotheton.com/gallery/77150-040818000118-42071168.jpeg)
(http://www.dotheton.com/gallery/77150-040818000120-42092001.jpeg)
Post by: stroker crazy on Aug 04, 2018, 06:15:30
Neat!
Crazy
Post by: WhyNot on Aug 04, 2018, 08:05:08
good job
Post by: trek97 on Aug 04, 2018, 14:02:51
a good place to hide your stash in there
Post by: irk miller on Aug 07, 2018, 23:42:00
Instead of a big reservoir...
Post by: Hurco550 on Aug 07, 2018, 23:44:05
#itsaracebikenow
Post by: doc_rot on Aug 14, 2018, 21:57:19
I watched my boss lock up his rear wheel because of a tube setup like that. If the brake fluid gets hot and expands, there is no where for it to go other than to pressurize the system and push the caliper piston out which makes it drag which makes it hotter so you get a positive feedback loop, until lock. Or as the pad wears the pistons retract too far because more fluid cant be pulled into the system because of the vacuum.  Thats why the caps of reservoirs have those funky rubber inserts to expand and contract with the system.
Post by: irk miller on Aug 14, 2018, 22:19:16
Hmm.  I wonder if I can come up with enough of a loop or extra space or something else.  I could go 3X, 5x or 10x on length maybe.  I'm mainly trying to avoid hanging a huge reservoir somewhere on the frame.   One option I considered is hanging the reservoir somewhere under the seat where it's visible, but not in such a profound space.  Having the M/C is a lot of visual clutter, since it seems like most vintage choppers run a drum.
Post by: stroker crazy on Aug 14, 2018, 22:54:47
Maybe you could use a section of flexible rubber tubing ...
Crazy
Post by: irk miller on Aug 15, 2018, 00:10:40
This is the other setup I was referring to. I could always go with a more fashionable reservoir, and one thatís smaller.
Post by: doc_rot on Aug 15, 2018, 01:41:49
What about a cable actuated Master cylinder? then you would have more options for placement.
Post by: doc_rot on Aug 15, 2018, 01:48:43
or how about a Master cylinder with an incorporated reservoir?,  you could probably repurpose what you have into something like this. and mount it low on your frame to clean the "triangle" thing up.
https://www.performancemachine.com/motorcycle-hand-and-foot-controls/rear-master-cylinders.aspx
Post by: Pete12 on Aug 15, 2018, 08:52:50
I'm using a WR250 rear unit, really easy to get, will that work for you?
https://i.imgur.com/CEgvDX5.jpg
Post by: irk miller on Aug 15, 2018, 10:24:38
I think something similar will.  I looked at one from an RM, but ended up going with another similar unit.
(https://images-na.ssl-images-amazon.com/images/I/41sL5USZK4L.jpg)
Post by: canyoncarver on Aug 15, 2018, 12:59:43
That reservoir up under the seat is burning my eyeballs.
Post by: irk miller on Aug 15, 2018, 14:29:27
(https://media.tenor.com/images/9e85ad394bb64a632bf3fdefef94b4ab/tenor.gif)
Post by: clem on Aug 15, 2018, 22:47:53
So what the details on that particular master?
Post by: irk miller on Aug 15, 2018, 23:19:27
You mean the one I ordered?  It's a cheap Chinese experiment, I figure.  Integrated reservoir.
https://www.amazon.com/gp/product/B00G5OUZ50/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Nissin makes an RM250 rear m/c that has a little bit bigger of a reservoir if this one isn't good enough.
(https://www.oemdirtbikeparts.com/v/vspfiles/photos/rmz250-rm-z450-rear-cyl-brake-2.jpg)
Post by: Pete12 on Aug 16, 2018, 04:37:54
Haha, $13.40, that shouldn't break the bank.
Post by: irk miller on Aug 20, 2018, 11:20:02
Mostly wired.
Post by: Brodie on Aug 20, 2018, 11:28:21
Looks uncomfortable.
Post by: irk miller on Aug 20, 2018, 12:00:20
If by uncomfortable you mean torture, it's definitely uncomfortable.
Post by: JustinLonghorn on Aug 20, 2018, 13:17:33
Did you use those waterproof built in solder connectors?
Post by: irk miller on Aug 20, 2018, 14:07:58
Not yet.  I haven't needed them.  I want to try to make a 2 into 1 link with them.
Post by: irk miller on Aug 22, 2018, 00:39:50
All wired up. Weíre taking the freshman class to Tybee Island over the next three days, so Iíll have to wait until Friday or Saturday to fire it up.
Shupe, I used those splices. Theyíre awesome.
Post by: irk miller on Aug 25, 2018, 22:09:26
Well, there are some necessary tweaks, but I can officially call it a runner...
https://youtu.be/8A9EI-tdhX8
I have a couple glitches in the wiring, namely the running light isn't coming on until you tap the rear brake.  I made a circuit that runs the running light through a resistor and the brake light through a wye that bypasses the resistor.  I also figured out why this motor has had electrical issues for the last three years.  That issue is me.  After frying my brand new Shorai lithium battery (ouch!), I figured out that I didn't understand the inner workings of the alternator and field coil.  I had been wiring the exciter as a power source, thereby grounding out my system.  Eddie hooked me up with a Rick's 8 wire reg/rec a few Barbers ago.  I was trying to run 5 wire reg/recs and wiring them wrong.  Now that I figured out the Rick's, it's all good.  Just waiting on the replacement Shorai to take it on a ride.  This run was on the bottle and with a spare battery on the ground. Oh, and the carbs were pissing fuel.  But, it runs.  It runs.
Post by: SquidHunter on Aug 25, 2018, 22:17:41
I do love a Cb750 chopper. Thatís looking good. Great job
Post by: john83 on Aug 25, 2018, 23:43:56
Super cool man. The R/R explains a lot. I recall watching you swap a stator at Ephraims a couple years ago but it not fixing much/anything.
Post by: irk miller on Aug 26, 2018, 00:20:05
This is pretty much it before paint.  I'm tossing around the possibility of not painting the frame, so it will be just the rear fender that gets paint.
(https://lh3.googleusercontent.com/EGDRVLAy2njiRcMBzZj75ZbNyhIG0Y2er2XpUX_Nm-Ch-x-ska5Rrq1EwPKGpowtx98PsKqHfaQCFPu54M9X2lRz5g1DISLjU88rR9gB8WYAFnGq5ABNK7CCp57CrOGPjwbZhievJ2ORFV8q8dM_RAyfZ0w3lqxMVEcaBE8A0K9SSxu78MppCnUYcpebqPYGv3lIXu_0HtYtQKUumDduaOflvBkKHUcjAEGE07Fh6DjscfgBllxYZdyVG2mgdzJ3KryYpoPmQS6Rgvuv4VtfSgDkN3XRAw9mGmYtmBR782F0hUohzaaV5SHx8lVSjWeHIoIDRKQgQjHE7RgJORFgKUifusCuEnoE5EB_s5temv6nBu7MiKXgkcDftFsEvrsKuoQ_NtGzdnFtpMUUH6ywKqmbYXovM2DMM5G235c1wRQ-X2AVn7BgDZn2-mZN2vHDoRPfUuVa7TfvI-ez_tz0SYNF8nT_akiLbIu081zJJnVHW9q7gHWZjBK4Jy8XLYRFIpKgZIBRz5NtZixJ0XMC_nwmJ4BmPSqLoYbbT2e5zLLuP8yYmjXV1vPaRNF3VuYsUuZmtakChDAYysxlSp_AgjrXDBNYk6zwmEey3LT3E7AgXUK-lvB7QZ9MoUU6Qyxen6NzjSxL51Sj0r8UX3399I_jTbR-g1gd_FzaczxlC62AID_XP75hA0k6=w1102-h826-no)
(https://lh3.googleusercontent.com/IS1JgO5GvGm2GfYUIPybrH-5C7yIQRgX5eQ3XptYVRfdxBs9IbhiD_pnQ3HXtJX6c02LhviKa3Zg2GGWtn-WIL_1iFG7NWpWtTdj5iGTLb4g5ZsBofQPEip2GlzivpMMn9FbDsvJiSDWUIwsQp_2KZBGZhuns_16bFVw5I2AqlMnPnzZ8iKeeQM1jL8q9Ec2v0dEY506uYALhcxq6QNDA5R-Vbx5BS4Quxji7e15bHEkAqmRMKgN7pr5-RmTmThp8t88VwNeTYe6BGrgkzfsbmT6h68f1pMOwOUS_nK4xLE7Z3RW0pDluffxJA4tDLE6g-SuXoh9JFr-TTR5XSaDB_sZiRSYM3zilXieYhOcvKgKQ6cq9Y3Dvdwrq955vqTGovvU-FcKwtP_0QenCCixIotabD-6IlMAz1FbL39rxU_eT3t69SNrWDXoVqISiotO3B2VzO6Ts34sOF1JA2oOZxVbpw6TK34D5Xae2xoizTVjYCHzgZldXH_u_x2WAVPMxKFKgUujpGcOQfIpXGYb_nCcpO0J02XpINvsE1r1bPDAqNAkdBcrIuVn3PDuKGY5uN1prGOyHBav059FaWFPYNJ6JM4wpi9tLJ-HhcU7xv_gjuUc-bRvsohkQvYBfop8NMJ_tcFy_AA1LyrIWhEVad3ekyoQDLSmICeMofAoj7ajGhi6Y19u1KeT=w1102-h826-no)
(https://lh3.googleusercontent.com/zDeFCeKIs7WTUGxSTbfysWupkIROR6t_-k0Dvgqnlwps9kyVsaGjjY3rmxd27FLvxRIFR30Xubqvnp78B5hetCttJzTqsSJ-42f4AXZaXycVr2uGxBq91SEufZyp7uIE0DM79vFpX5tY-Iu95c92dNv5MeW4xW_5OEtafgB4Jw6MrpeWTr7tiZ58IyxgWefXGwawG4r2mpzscYvWhx-46tSSY3-XPf6VdW0onjqjf-scL42VafJIikhsnUkhIp0Ob5R54aYck2zyVJM7NUi7hoGDt_EUECZmeLuYGr5YNWGPArjdtbbhc8fEcATBydTUjnQQgvhO2miXLg3FVqqLnKiIAOMUv28Pip3YkZZ3jlj3P5Qvgvo7_axpjW48PfCJJz6G_BA-6bhWUTKPKtWqsqtc67MhrGMY6cHPoE9OYrKbEzLiaE8zXw2w1WAemFkcObGTAA15JvYaPClw6wuH5t1dWRAGfwMx8rsrTgsZtch79HKMEFjNzvmv3hpKiKgdtGqGIn27maeHzhlUdE7Pka4Ux9482AD5Fko5oraZsktkRhYpYACfNLi1xxCr0HDb9v179vYuPwVMyl3LN2cpes3NxblWuzE6lky_R_sTUqLPnuyyqDnUI8vH86JGp1gYbibK1zsR82LoW0RDgLpipYs7-FDG0BMaMJHekcSRDdBnJrm-JBRe5wVn=w1102-h826-no)
Title: Re: CB750 No Plunger Hellride
Post by: Rider52 on Aug 26, 2018, 02:42:32
Looks good! I think I would leave it like it is now.
Post by: john83 on Aug 26, 2018, 08:20:09
Could always ride it through the fall and paint it over the winter.
Post by: Pete12 on Aug 26, 2018, 08:26:17
Sweet.
Red, black and white rear guard would look good.
Post by: trek97 on Aug 26, 2018, 09:13:18
You could use "Cast Blast" to paint the frame.  It gives the look of fresh clean cast iron.
Or
Marbles Engine might be cool and give the appearance of fresh, bright aluminum.
Or
I always wondered how raw steel would age if sprayed w transparent adhesion promoter then 2k clear topcoat???
Post by: irk miller on Aug 26, 2018, 11:46:17
Or
Or
First two suggestion still include painting it. ;) LOL.  It's actually patina'd pretty nicely from the New Mexico desert air where Kelly got it from.  I just need to get the hardtail to match.  I have some tricks to do it.  But, why I'm considering not painting it is because the patina is really good.  Plus, the wear marks on the tank set up nicely for the frame as it is.  The rear of the tank where the original seat was has no paint.  The paint has completely worn through.
Post by: john83 on Aug 26, 2018, 18:37:04
Any baffles or muffler in that exhaust at all? It sounded pretty good.
Post by: irk miller on Aug 26, 2018, 18:52:36
Yep.  It's all homemade, but it's in there.
Post by: NoRiders on Aug 26, 2018, 19:10:48
Sweet.
I'd second that idea....made to match the patina'd tank
Post by: irk miller on Aug 26, 2018, 21:36:40
I just rebuilt these forks.  I didn't take any pics, since it's so hard to visualize all the cussing and slinging of fork oil all over the shop.  Funny thing, no internet searches reveal any information on rebuilding the forks for a 1985 CR500.  I had to figure it out myself.  They have some bushings which will throw you for a loop and the typical age stuff.  All in all, it was a blast.  A real blast.
Post by: john83 on Aug 26, 2018, 23:41:18
Homemade muffler is badass.
Post by: pidjones on Aug 28, 2018, 07:25:55
About 80% of the rat rods (and there are hundreds around here) in this area are done that way. Just says to me that they care more about performance than appearance, and that's cool with me as long as the power train is not stock. We will see in a few years how they age.
Post by: Jimbonaut on Aug 28, 2018, 10:15:35
I've done two tanks now like this (minus the adhesion promoter) with different results.  Seems like moisture is retained in the steel - the more you can drive that moisture out by heating the tank before the 2K, the less rust will appear under the clear.  At least that's what I've found.  Fair bit of rust now on the one tank I cleared in humid conditions, none on the tank I cleared after heating it.
Mind you, the rust that does appear is weird.  Never seen rust like it - it looks like hairs.  Peculiar.
Chopper's looking killer man.
Post by: irk miller on Aug 28, 2018, 11:49:59
Thanks, Jim.  The structure of the rusting probably has mostly to do with the surface of the steel- sanding marks, etc.  The water fits into those marks and becomes rust later.  If you treat the metal with a solution of phosphoric acid such as OSPHO before your clear coat, I bet that doesn't happen.
Post by: Hurco550 on Aug 28, 2018, 13:19:02
This post is not in response to anything posted here, but I feel that it needs to be said..
From all of us who enjoy a tastefully done chopper... I just wanted to say...
Thanks for using those handlebars and not a giant set of ape hangers!!!! ;)
Post by: irk miller on Aug 28, 2018, 13:49:31
My man.
Post by: canyoncarver on Aug 28, 2018, 13:54:31
The low bars do look better.  Just sayin, I started with drag bars and forward controls on my chop.  I'm doing 12" apes now because they are way more comfortable for my chassis.
Post by: irk miller on Aug 28, 2018, 14:00:56
The low bars are really comfortable for me and this bike.  If 12" apes were more comfortable, I would most certainly run them. That said, I think the look of these low bars makes sense with this bike too.  I was hoping to keep it somewhat out of the box, hence the dirt bike wheels and forks.
Post by: canyoncarver on Aug 28, 2018, 14:05:57
Your bars fit the bike really well plus yours has mid-controls for your feet which is nice.  Mids really change the riding position, it's why I'm doing mids on the FXR.   More aggressive, less laid-back.
Post by: Hurco550 on Aug 28, 2018, 14:31:39
yeah, even smaller apes look good on some choppers, im just talking the big ol stupid ones.
All of this is just in my opinion anyways... that and 65 cents will get you a senior cup o joe at Mc Donalds.
Post by: WhyNot on Aug 28, 2018, 14:41:17
I keep forgetting to ask for the senior discount there and everywhere's else for that matter.
Eric, bike looks awesome, and as I said earlier, you got that thing going and mine still sits with efed up carbs.
Post by: NoRiders on Aug 28, 2018, 15:25:09
Forgive the...errm..personal question, but what's your inside leg measurement?
I ask because will you fit - legs seat to pegs when riding?
Post by: irk miller on Aug 28, 2018, 19:01:07
It would be really dumb of me to say itís comfortable without sitting on it, or to get this far into a build without knowing it fits. I usually try on my shoes at the store, not when I get home.
Post by: Jimbonaut on Aug 28, 2018, 19:33:40
Own it.  You look like my mate Norm.  How did it look/feel with the back of the seat raised a few inches?
Post by: irk miller on Aug 28, 2018, 20:35:25
Norm is a good looking dude.  Ha.  That previous post wasn't supposed to come off so smart assed.  At least not in a condescending way.  More like a talking shit with my pals way.  I'm not sure what you mean by the raising the seat part, Jim.  I'm really happy where the seat is now.  I did move it forward and back.  It's currently higher now by an inch or two from where is was in an earlier rendition.
Post by: Jimbonaut on Aug 28, 2018, 20:54:32
Ha!  Yeah I get that a lot.  Things that make sense in my head make absolutely none at all by the time they're vocalized.  Just ask my wife.  Mate your ride looks the bollocks, I don't mean to interfere at all.  I was wondering how the seat would look kicked up at the back, like this -
(https://i.imgur.com/y9aJ8zA.jpg)
Post by: canyoncarver on Aug 28, 2018, 22:39:24
(https://media.giphy.com/media/qngVhP9OWogKY/giphy.gif)
Post by: pidjones on Aug 29, 2018, 07:01:46
I had a TR6-C trumpet chopper hard tail, K&Q seat , springer. Had almost the exact same seating position and I did fine on it, hardly ever used the highway pegs. 32" inseam. Course, I was in my 20s then. Your setup looks comfy to me.
Post by: irk miller on Aug 29, 2018, 07:34:53
Yeah, I'm a short guy.  30" inseam pants, but more likely a 28" or 29".  I'm only 5'6".
Post by: NoRiders on Aug 29, 2018, 08:14:13
Cool.....the reason I asked is it looked very short between seat n pegs, being as they're not forward pegs. I'm noticing on my build as I've reduced the seat foam thickness a slight over bend in my knees that cause pin n needles at more than 30 mins in the saddle. Carry on....:)
Post by: irk miller on Aug 29, 2018, 08:25:04
Yeah, my pin and needles issue is in my arms.  I have a crooked back from years of abuse, which creates amplified issues in the hands and joints.  So the location of my hands is of a particular importance for me.  I considered the forward controls for my feet, but for whatever reason, I'm not comfortable in that position.
Post by: irk miller on Aug 29, 2018, 20:40:15
First ride, so I made a stupid video.  LOL  :o
https://youtu.be/3t0IFdjirfM
Post by: Maritime on Aug 29, 2018, 21:03:21
Riding position looks pretty good. Whole bike is rad. Good job my man.
Post by: JustinLonghorn on Aug 29, 2018, 21:55:23
I can definitely dig it, my man.
Post by: CrabsAndCylinders on Aug 30, 2018, 03:05:53
Nice job, my man.
Post by: TranceMachineVienna on Aug 30, 2018, 04:54:46
Huge respect.....amazing ride!
Post by: pidjones on Aug 30, 2018, 06:22:36
Nice stupid video. Now get our and enjoy that thing for many s-miles! (And wear more gear!)
Post by: WhyNot on Aug 30, 2018, 06:51:35
Nice Eric...........
What more can I say................that is badass.......!!!!!!!
Post by: advCo on Aug 30, 2018, 09:40:04
Hell to the yes.  8)
Post by: Hurco550 on Aug 30, 2018, 09:56:29
The video named "No Plunger"...
I can see it now, a dad, taking care of his 9 children while the mother is away.
Little Billy had a chipotle burrito earlier that day, which inevitably over worked the abilities of the commode.
There's "water" everywhere.
The father, much to his dismay, realizes that there is not a plunger anywhere to be found...
In a panic, he goes to the trusty internet and franticly types in "NO PLUNGER" to find out what to do in this sticky situation.
What he finds is your video of this freedom machine, and for a moment is taken-a-back from this 9 to 5 job and doo-doo flooded house.
He sees himself, in the wind, leaving it all behind...
Snap, back to reality...
"water" everywhere
Little Billy and his siblings are playing a dangerous game of "gravy train" slip and slide down the stairs
The air is getting thick in the house, and the day has taken a real turn for the worse.
But in the midst of all of that, dad got 30 seconds of his life back, at 21, free and alive.
YOU DID THAT ERIC!
that alone makes this build worth it.
Post by: irk miller on Aug 30, 2018, 10:03:42
Haha!  We need to add that into this movie!
Post by: JustinLonghorn on Aug 30, 2018, 11:49:59
Gravy Train, that was my nickname in  High School.
Post by: Hurco550 on Aug 30, 2018, 13:55:05
Justin Longhorn was my nickname in high school.
Title: Re: CB750 No Plunger Hellride Freedom Machine
Post by: WhyNot on Aug 30, 2018, 14:34:02
ha ha
Post by: irk miller on Sep 02, 2018, 14:46:27
Another update.  I've been putting some miles on it to sort out the kinks.  Right not, it's acting lean, so this bread box may be the culprit and a re-jet may be in order.  I still have a few turns on the mix, though.    For the first time, I have this thing properly charging.  Yay.  The chain is hitting the rear fender just a bit and every now and then.  This is why I haven't painted it.  So, I'll cut it out just a little bit more.
If you look closely to the right side of the image, you can see the groove forming from the chain wear...
(http://www.dotheton.com/gallery/77150-020918122746-42982163.jpeg)
Fuse box and power buss are located under the starter cover here, and the reg/rec mount.  The reg/rec sort of floats off the tranny, so hopefully it stays cool enough.
(http://www.dotheton.com/gallery/77150-020918122747-42992404.jpeg)
(http://www.dotheton.com/gallery/77150-020918122752-43021695.jpeg)
(http://www.dotheton.com/gallery/77150-020918123138.jpeg)
Front brake reservoir goes here, at least for now.
(http://www.dotheton.com/gallery/77150-020918122749-43002224.jpeg)
I also took a sort of bulky and cheesy license plate dealio, took the light/frame/plate mount off of it and stole the bracket.  Machined a cup/bushing so I can mount it above the axle instead of through the axle as it was intended...
(http://www.dotheton.com/gallery/77150-020918122744-42972121.jpeg)
Post by: Sonreir on Sep 04, 2018, 10:18:02
I like the locations for the electrics. Very clean.
Post by: irk miller on Sep 04, 2018, 10:37:17
Question for you.  This LiFePO4 read 14.6v or 14.8v after a long ride this weekend.  Should I be concerned?  I haven't retested to see if the voltage dropped after sitting awhile.
Post by: Sonreir on Sep 04, 2018, 10:49:46
14.6V is fine, but I would start being a little concerned if it goes past that (even by a tenth). 14.8V is the absolute safe maximum. I usually advise the 14.6V number because the 14.8V means every cell in the battery is at the full max value.
You might be able to bring the charging voltage down a little by routing the black wire from the R/R to be as close to the ignition switch as possible, with as few connections as possible.
Post by: irk miller on Sep 24, 2018, 23:06:03
I finally got some paint on the rear fender, and wrestling with the idea of clear coating the tank.  I'm not against, though I don't think it's all that necessary either.  At least with the fresh paint and deep clear on the fender, there is an obvious difference.
(http://www.dotheton.com/gallery/77150-240918205934-4426151.jpeg)
(http://www.dotheton.com/gallery/77150-240918205936-44271537.jpeg)
I also put in 25psi of air into the front forks.  They needed stiffened up.  We'll see if air pressure does the trick or some shimming will happen next.
Post by: Brodie on Sep 25, 2018, 04:35:16
Fender looks the part. Good effort.
Post by: Hurco550 on Sep 25, 2018, 10:18:33
just outta curiosity, how much pressure do they run in those forks when they are on the cr? I just ask because 25 sounds like a lot, and I had been reading that most bikes of that vintage usually run way lower p.s.i.
also, fender looks great. my vote is to clear the tank :)
Post by: irk miller on Sep 25, 2018, 10:25:13
FSM for the GL says 14 - 21psi.  25 psi is not a crazy amount.  Pressure for most of the dirt bikes, like the 200r is 12 - 14 psi max.  I'm not jumping huge berms or launching off of cliffs, so I'm pretty confident they can handle more pressure.  Plus, the rake softens the ride considerably too.  This isn't exactly a factory application of these forks. ;)
Post by: Hurco550 on Sep 25, 2018, 10:30:14
FSM for the GL says 14 - 21psi.  25 psi is not a crazy amount.  Pressure for most of the dirt bikes, like the 200r is 12 - 14 psi.  I'm not jumping huge berms or launching off of cliffs, so I'm pretty confident they can handle more pressure.  Plus, the rake softens the ride considerably too.  This isn't exactly a factory application of these forks. ;)
that makes sense. I know under compression the psi raises a good bit, and also a good point on jumping curbs. (though a video of you jumping curbs on a hard tail chop in shorts and a tee shirt would make you way more cooler...) lol
Post by: irk miller on Sep 25, 2018, 10:35:46
I am half tempted to see if it will jump, but then I remember who welded the hardtail on.  LOL.  In the end, I may get Dave Doug to work this front end with springs and shims.  Funny thing, when looking up the numbers for these forks, there are guys that say the valves are just to remove air, and there are guys that say they wouldn't have the valves if they aren't supposed to have air.  Some say 0psi and some say 7 - 8psi and some say as much as 12psi.  I defaulted to GL1100 numbers, since it's a pig heavy chopper.
Post by: JustinLonghorn on Sep 25, 2018, 10:38:29
Yep. Clear the tank.
Post by: Hurco550 on Sep 25, 2018, 10:40:41
haha, I mean it is like "half dirtbike".. Ive seen roland sands jump Harleys with way less dirbike pedigree. The only thing I worry about with to high of psi is blowing out fork seals, which as you've shared isn't a fun job to replace on these forks. They may well be fine, not saying im right lol I was just more curious.
Post by: irk miller on Sep 25, 2018, 11:02:54
I'm not sure on the possibility of blowing out fork seals in the sense of having to replace them.  I can see it being possible that they blow out of their seat, but since they are basically wipers, dirt/grit is the bigger enemy for causing leaks.  That's why those Seal Mates work, because they clean out the dirt and grit from between the seal and the tube.  As long as the rubber is good, I've been able to stop leakage on several forks.
Post by: Brodie on Sep 25, 2018, 12:02:52
Just for reference the XV1100 is something like 4-6 psi if I remember right.
Post by: irk miller on Sep 25, 2018, 13:18:03
I am officially paranoid.  LOL
Post by: Hurco550 on Sep 25, 2018, 13:28:59
My work here is done.... lol
(https://uploads.tapatalk-cdn.com/20180925/bbe1f7d6fe45e73d3c51c78b313bf99b.gif)
Post by: irk miller on Sep 25, 2018, 20:20:34
I have resisted to urge to restore this tank.  It has a few dents and dings, chips and rust, and now a thick layer of clear.  Yay.
(http://www.dotheton.com/gallery/77150-250918181522-4430183.jpeg)
(http://www.dotheton.com/gallery/77150-250918181521-4428879.jpeg)
(http://www.dotheton.com/gallery/77150-250918181524-4431234.jpeg)
Post by: Brodie on Sep 25, 2018, 21:11:23
Rad. Just need black fork legs to match now.
Post by: irk miller on Sep 25, 2018, 21:25:23
Speaking of fork legs, I dropped the pressure to 15psi.
Post by: canyoncarver on Sep 25, 2018, 21:26:31
ALL THE CHOPPER GLORY !!!
Post by: Hurco550 on Sep 25, 2018, 23:50:17
I would personally run AT LEAST 25 p.s.i.
But that's just me ;)
Post by: JustinLonghorn on Sep 26, 2018, 10:06:17
That tank looks the business now, man. Fucking righteous.
Post by: Maritime on Sep 26, 2018, 10:08:44
Yep, I LIKE IT!
Post by: pidjones on Sep 26, 2018, 10:41:54
Because of different seal and plunger areas, different forks have different maximums. My KZ750H forks max at 36 psi (250 kPa). I've seen others list 15 psi as max. Even with 36 as max, 15 is very reasonable considering the angle that these forks are at. I'd think softer would be easier on the tubes, allowing the forks to compress more instead of bending. You've put so much effort into this ride, it only makes sense for it to be safe and comfortable for you to ride the fool out of it!
Post by: irk miller on Sep 27, 2018, 23:45:23
Iím working on building up the patina to match the new hardtail to the original front half of the frame...
Post by: trek97 on Sep 28, 2018, 06:50:08
What the hell is that?  Is it rust?  Im sure you've already done all your homework on this "browning" process.  FWIW...
If it is REAL rust.  It will be very fragile at first. If it turns a copper color you will need to add more humidity.
The "copper" colored coating will prevent the acid from doing its "rusting" job.  And will have to be sanded back to bright and re-done.
You can buff the new rust using soft old denim.  BTW - buffing rust is called "carding". Or even steel wool.
Carding, between acid coats, will give the rust a mice smooth, darker, semi-gloss type finish.  (probably what you want)  If you dont buff it will get rougher as you build it up.
Carding all that by hand will be a big job.  Maybe wrap a drill buffing wheel w denim.  working at a slower speed.
But you will need to remove a lot of stuff from the frame to get it all nice and even.
You can stop the browning process w water and baking soda mix once you reach your desired goal.
Which you're probably there now.
Post by: irk miller on Sep 28, 2018, 07:44:30
Yes, I already know.  And I'm not yet finished. As I stated "Iím working on building up the patina." I've been doing this kind of stuff for 25 years.  Thanks for the rant, anyway.
Post by: trek97 on Sep 28, 2018, 08:11:39
haha no rant.  simply info.   :D
I was just surprised to see it.  thats all.  and yeah I knew you'd know.
Post by: irk miller on Sep 28, 2018, 08:16:13
It's pretty clearly a rant.  It's always a rant.  I'll be happy to mail you a copy of my resume, if it helps.  My portfolio is available online.  There are many ways to do this this and several processes.  The front half of the frame is already rusted naturally, so (as I stated before) I'm just making the back section match.  I don't want it "even".
Post by: trek97 on Sep 28, 2018, 08:56:03
I promise not a rant.  I smiling to myself when I wrote that.
A combo of surprised and impressed.  Yeah I went back and looked at the front of the frame.
Its pretty cool your going for the match.  It will be a neat finish.
Im betting fine steel wool will better achieve the uneven "worn" appearance, letting some bright shine through.
Really dude its super cool.
I prefer the browning of rifle barrels as opposed to more modern blueing.  An art thats fading fast.
Post by: irk miller on Sep 28, 2018, 09:53:49
I totally agree.  Same as I much prefer wood stocks ( I assume you do, too) to the plastics they're using nowadays.
On similar note, I'm also trying to patina the seat.  Partly because I dripped brake fluid on it (yes, I'm an idiot), and partly because the color tone was too consistent and light and didn't seem to match the ride.
Post by: trek97 on Sep 28, 2018, 14:15:36
I donít care for the color of the oiled hide I bought.  Used it on the stool I made.  Let me do some experiments on it.  I got stripper and also gonna try some alcohol.
To strip current tan finish off and re-dye dark brown.   Iíll send pics tonight.
Post by: irk miller on Sep 28, 2018, 15:09:58
Bleach or acetone will remove the dye in leather.  You then can add color back in with wood stains, or shoe polish.  I cut the shoe polish/stains with saddle soap or leather conditioner and rub it in.  Coffee grounds make a great dye for leather and if you want more of an oxblood tone then boil red onions or beets.  If you can soak the leather, then rusting some steel wool in a solution of vinegar (search: vinegaroon dye) to make a great black dye.  By trying, it's not a question of knowing.  It's a process of effort.
Post by: trek97 on Sep 28, 2018, 17:13:54
Coffee grounds might be awesome for a mottled look.  I will give it a shot and see how that goes.
Thank bud
Post by: canyoncarver on Sep 28, 2018, 18:40:15
The frames natural patina was that of sitting in the desert outside Belen, NM.  And I might have peed on it.  Maybe.
Post by: irk miller on Sep 28, 2018, 23:42:44
I would be terribly disappointed if you didn't.
Post by: Maritime on Sep 29, 2018, 09:54:14
Pee makes the best patina.
Post by: trek97 on Sep 29, 2018, 10:22:46
Pee-tina
Post by: irk miller on Oct 01, 2018, 01:53:35
I finally got the front forks sorted by taking all the air out (yes, 0 psi) and swapping the 2.25" shim that came in these forks for a 5" shim I made from PVC pipe.  Yes, these now have a 5" long shim.  LOL.  I was getting way to much sag in the front end before the swap, but now I get zero.  The ride is a little on the stiff side, so maybe I cut it down a bit, but I thought it rode pretty well.  It also got me much better clearance for my pipes, which help my right turn lean.
The other bit of work this weekend involved converting the seat more to black and more patina on the frame.  This black in the seat is achieved by mixing a 3:1 solution of vinegar and hydrogen peroxide and dropping a wad of steel wool in the solution.  Then, with sandpaper and steel wool, I buff the leather and follow up by soaking a rag in the solution and wiping down the seat.  A rub down of leather conditioner follows that and I'll finish with some mink oil.  I don't want it solid black, but just darkened up and the look of some wear.
(http://www.dotheton.com/gallery/77150-300918234353-4459486.jpeg)
(http://www.dotheton.com/gallery/77150-300918234355-446191.jpeg)
(http://www.dotheton.com/gallery/77150-300918234357-4462794.jpeg)
Post by: WhyNot on Oct 01, 2018, 07:17:57
dayyyum Eric, she looks purdy.
Wish I could get my 750 running good enough to go for a ride with you.
Course Saturday sucked, but yesterday was a good day to do some riding.
Post by: irk miller on Oct 01, 2018, 07:47:13
Yesterday we road the first DGR in Augusta.  Not a big ride, but about 25 good riders.
Post by: trek97 on Oct 01, 2018, 08:38:50
That is the coolest chopper Ive ever seen.  Bud, you've nailed it.
Post by: irk miller on Oct 01, 2018, 09:48:51
Thanks, bud. Means a lot.
Post by: Maritime on Oct 01, 2018, 10:34:44
Love it Irk, really came together well. I'm not a huge chopper lover but I really like how this one turned out.
Post by: WhyNot on Oct 01, 2018, 10:43:15
Really.....was that ride advertised?
I would have have gone on that, even with the spitting and sputtering this thing does.
Post by: irk miller on Oct 01, 2018, 11:13:50
Not sure it was advertised, per se.  I usually do the Greenville ride, since it's down the road from my mom.  But when I looked up the rides, I saw there was an Augusta ride.  A few guys there said the coordinator was finding people downtown when their bikes were parked and passing out info.  It will happen again next year, so I'll message you.
Post by: irk miller on Oct 01, 2018, 11:14:59
Much thanks, Mike.  If this is what it takes to push you towards chopper love, than I have accomplished something good in my life.  LOL
Post by: pidjones on Oct 01, 2018, 16:03:05
My first bike was a 650 Triumph Trophy (TR6C) with bolt-on Corbin Gentry hardtail, K&Q seat, 12" over springer, peanut tank, pull-back butterfly handlebars, etc. I loved it and rode it quite a bit (but, I was at sea 50% of the time). Even with Lucas electrics, it never completely let me down (although I spent several hours next to the road with the gas-powered soldering iron I carried on a couple occasions). Its downfall was handling in traffic. It just responded too slow to feel safe around Charleston, SC drivers that seemed to have all sailers on motorcycles targeted. You have done yours tastfully without going too far on any of it, and it looks like the frame geometry is fairly conservative. It should grow to be a  solid part of you.
Post by: irk miller on Oct 01, 2018, 19:13:31
I do like it a lot.  Certainly something to get used to.  Since I shimmed the forks, it is significantly improved.  They were way too soft and had almost 2 inches of sag, which is ridiculous.
So, when were you in Charleston?  I was there 89 - 94.  I was on the USS Semmes, DDG18, a Machinist Mate, MM3.
Post by: pidjones on Oct 01, 2018, 21:24:30
72 on the Orion AS18, then 74-79 on Von Steuben SSBN 632. I had a house out 17 South in Ponderosa subdivision. MM1 nuc.
(https://uploads.tapatalk-cdn.com/20181002/798b942e5256bee6ae8c713cdf4c29ab.jpg)
Post by: 1fasgsxr on Oct 02, 2018, 13:19:38
^^^  That choppa is awesome !! ^^^  So is yours Irk
Post by: irk miller on Oct 04, 2018, 08:34:55
Well, I finally sorted my issues with the PD carbs. I threw them aside and ordered a kit from Murray. Holy shit does this thing run beautifully now. I had to flip the intakes to fit this chopper frame, and I made my own filters from two layers of aluminum screen with Uni filter media sandwiched in-between.
Post by: cxman on Oct 04, 2018, 08:56:47
drive safe have fun
wish they fit the way they do on a stock frame
dont forget clutch springs
Nice brake switch spring
Post by: trek97 on Oct 04, 2018, 11:24:55
BOOMSHAKALAKA
Post by: JustinLonghorn on Oct 04, 2018, 11:48:29
Awww yisssssss
Post by: canyoncarver on Oct 04, 2018, 14:05:40
Lol.
Post by: irk miller on Oct 04, 2018, 14:22:22
Hey, it works. Iím on the lookout for one that fits. LOL
Post by: cxman on Oct 04, 2018, 16:13:35
your mom would have a good chuckle lol
Where are the burnout pics?
its a hard tail it should do a good smoke show now
Title: CB750 No Plunger Hellride Freedom Machine
Post by: irk miller on Oct 13, 2018, 17:52:17
Making some tweaks to the carb kit to get fitment with this frame. I couldnít get enough clearance either inbound or outbound to get an air cleaner on the carbs, so I put the flange side down on the intakes to a belt sander and ground an angle to each side, then followed up with oil and sandpaper on a surface plate. The K&N style filters still donít fit, so weíll make our own. The plan is to add a Uni element under the screen, but I have to secure it to keep it from getting sucked into the carb.
Post by: Brodie on Oct 13, 2018, 19:30:16
Why not sandwich the element between two screens. Looks good man.
Post by: irk miller on Oct 13, 2018, 19:41:32
That's probably what I'll do.  It's what I did to ride it around last weekend.
Post by: TranceMachineVienna on Oct 15, 2018, 06:21:30
nice ally tig welding :-)
Post by: cxman on Oct 15, 2018, 08:54:52
i love field adjustments glad it worked
Post by: irk miller on Oct 16, 2018, 19:30:38
Well, itís time to go crazy with the details. I donít get to do this very often...
Etched my logo into the oil bag cap with a Celtic knot ring.
Post by: trek97 on Oct 16, 2018, 19:33:52
Just how in the F did you do that?
Post by: canyoncarver on Oct 16, 2018, 20:44:24
That is beautiful.
Post by: irk miller on Oct 16, 2018, 22:36:22
It's etched aluminum.
That is beautiful.
Thanks, my man.
Post by: irk miller on Oct 17, 2018, 21:44:19
Got some Biltwell grips to replace the Granturismo grips. I like these much betta. Also messing around with using springs to organize the wires. I may have to shorten the throttle so I can get it to run with the brake and clutch.
Post by: Brodie on Oct 17, 2018, 21:46:27
They are my favourite style of grip. Actually shaped to fit your hand when it is closed.
Springs look good.
Post by: irk miller on Oct 18, 2018, 00:45:19
More details...
Post by: Popeye SXM on Oct 18, 2018, 01:01:54
I love the etched aluminum, great detailing
Post by: JustinLonghorn on Oct 18, 2018, 07:43:19
Printed Circuit Board etching solution?
keep up the great work, man. I absolutely love this chop.
Post by: irk miller on Oct 18, 2018, 07:49:04
Circuit board etching solution is ferric chloride.  I do use that on copper etching plates in printmaking.  This is a saline etch: copper sulfate and salt.
Post by: JustinLonghorn on Oct 18, 2018, 08:02:06
Righteous. Thanks for the info.
Post by: Maritime on Oct 18, 2018, 09:53:38
Love the oik cap, and those grips suit the bike well too.
Post by: advCo on Oct 18, 2018, 10:44:07
I need to look into this etching.
You still using the vinyl stencils for the designs?
Post by: Maritime on Oct 18, 2018, 10:44:15
You use cut vinyl to cover the area you don't want to etch right?
Post by: Hurco550 on Oct 18, 2018, 11:31:06
vinyl right?
Post by: Sonreir on Oct 18, 2018, 11:32:26
I would probably use some vinyl for the masking.
Post by: irk miller on Oct 18, 2018, 11:38:43
Hahaha.  You guys are hilarious.   ::)
Vinyl, gum arabic, shellac, Sharpie marker, tusche, china markers, crayons, spray paint, etc are all used as a resist. For a perfect, crisp, vector type image, like on the cap and the logo on the end of the clutch lever, vinyl was used.
Post by: Hurco550 on Oct 18, 2018, 12:41:05
For a perfect, crisp, vector type image, like on the cap and the logo on the end of the clutch lever, crayons were used.
It looks ok, but I suggest vinyl next time.
Post by: irk miller on Oct 18, 2018, 23:56:52
Another change to the air filters...
Post by: cxman on Oct 19, 2018, 08:08:52
nice you going to add filter media?
Post by: irk miller on Oct 19, 2018, 08:10:08
The pic doesn't show it, but there is filter media in there.  It's about an inch inside the tube, behind the screen.
Post by: cxman on Oct 19, 2018, 11:49:31
awesome
Post by: Luugo86 on Oct 19, 2018, 15:22:17
I like those man
Post by: irk miller on Oct 20, 2018, 01:01:13
Much thanks, Luugo.
A couple small details Iíll test out tomorrow:
I swapped out the 14t countershaft sprocket for a 16t. I still want it to pull, but I also hope it cruises at 60 in a better rpm.
I swapped out the carbon core plug wires for some MSD Superconductor spiral core wire at 40 ohms/ft.
Post by: irk miller on Oct 21, 2018, 21:18:56
Trying to get some beauty shots to submit to shows and whatnot:
(http://www.dotheton.com/gallery/77150-211018190943-4583323.jpeg)
(http://www.dotheton.com/gallery/77150-211018190945-45841004.jpeg)
(http://www.dotheton.com/gallery/77150-211018190948-45851032.jpeg)
(http://www.dotheton.com/gallery/77150-211018190956-4588489.jpeg)
(http://www.dotheton.com/gallery/77150-211018190959-45892186.jpeg)
Post by: Luugo86 on Oct 21, 2018, 21:38:24
That machine has a great stance man...  Did you make the seat? And what is that rear fender from?   Also, would love to hear how she sounds if u got some vids
Post by: irk miller on Oct 21, 2018, 22:30:17
Thanks, man. Rear fender is a Softail fender cut down and shaved. I formed the seat base and hand sewed the leather myself. Hereís a vid:
https://youtu.be/lP-gg0hQF2Q
Post by: MiniatureNinja on Oct 22, 2018, 01:55:12
I wanna know about that muffler, is that something you made? it's amazing and pretty much fits the design and style of what I want for my bike
Post by: irk miller on Oct 22, 2018, 07:52:49
I made it.  I'm pretty sure I made a post with the baffle and machined end cap earlier in the thread.  The muffler is two pieces of pipe, one pre-bent, bought from Columbia River (mandrel-bends.com).
Post by: irk miller on Oct 23, 2018, 03:20:11
I made a gas cap...
Post by: Brodie on Oct 23, 2018, 05:01:32
So rad.
Post by: Maritime on Oct 23, 2018, 08:30:15
That us beautiful. I love it.
Post by: TranceMachineVienna on Oct 23, 2018, 12:29:09
Amazing!
Thereīs some gaelic missing. Maybe somewhere "Eat dust mother****" but in gaelic :-)
I still remember when I landed on the dublin airport when I was in school and was suprised by this strange language...Ireland is an amazing country!
Post by: Sonreir on Oct 23, 2018, 12:31:32
Did you use vinyl for the masking?
Post by: Hurco550 on Oct 23, 2018, 12:41:17
Did you use crayon for the masking?
Post by: irk miller on Oct 23, 2018, 12:54:29
Haha.  I had to scroll up to make sure the last few pages weren't missing and we went back to those other posts.
Yes
No, but I did use Sharpie. I'll never use Sharpie again.  It etches better when you lightly brush off the surface, which also cleans off the Sharpie.  So, I had to chase back in the angled edge on the lathe to clean it up.  I may actually start over again to get it better.
Post by: Jimbonaut on Oct 23, 2018, 14:13:59
Beautiful work Irk for furk's surk
Post by: irk miller on Oct 27, 2018, 02:36:10
May not seem like much, but I massaged the frame with an inset under the peg so I can get the collector up a bit. In doing so, I gained an inch of clearance. Itís going to make a big difference in right lean...
Post by: pidjones on Oct 27, 2018, 10:38:15
One inch gives a hell of a lot more lean angle. If you ever need it.
Post by: Maritime on Oct 27, 2018, 17:33:01
Little details make a good bike great.
Post by: john83 on Oct 27, 2018, 23:07:52
Lean angles are kind of important.
Post by: WhyNot on Oct 28, 2018, 10:19:47
Nice.....!!
I lost some lean angle on my 750 with the exhaust I put on.
Post by: irk miller on Nov 03, 2018, 22:03:44
Alright folks, so here's the bizness.  As you know, right before Barber, I installed this Murray's Carbs kit.  I was over the PD carbs, and Murray has always promised me I will love this kit.  He was kind enough to quick ship them so I could have them for the weekend.  At that very moment, I started going through insulator hell, and insulator hell continued until this week.  There are some crappy aftermarket insulator kits on the market and the 77/78 stock insulators are not the easiest to come by.  So, when I was at Barber, I bought the K0-K6 insulators to see if I could make them work.  I then bought some 77/78 insulators from a guy on Hondachopper.com and another set from Ebay.  Neither were leak free.  I kept thinking the carbs were lean at the top end and not quite right in-between.  Lots of conversations with Murray, and lots of going through my motor for me.  Went through cam timing, valves, ignition timing, sprayed boots, etc. Nothing revealed itself until a few days ago when the #1 carb started going significantly lean.  As the same intake feeds #1 and #2, but #2 wasn't lean, I knew there was something going on with the insulator.  So, on a whim, I pulled the k7/k8 insulators and installed the K0 - K6 insulators.  This is my review:
Holy Shit!  This, my friends, is a drag bike with no engine modifications whatsoever.  It pulls like a freight train.  I have no times yet, but I can tell you it tops 80mph between the light at Furys Ferry Rd and Warren Rd on Washington Rd in Augusta.  Google Maps says that's between .1 and .2 miles. It's right at 1/8 mile.  There's was more left in the throttle, I just didn't want to die.
(http://www.dotheton.com/gallery/77150-031118195617.png)
Regardless of scientific data, this is an oh shit, white knuckle carb kit.  One which requires good grips and a sticky seat.  I'm running a 16T front sprocket, so I expected more bottom end, but I didn't have high hopes for the top end.  To give it a go, I got onto I-20 and sifted into traffic.  I picked my moment then, from a 75mph cruising speed, I hit WOT and again about lost my shit.  It pulled as hard at the top end as it did at the bottom.  If there's any skepticism whether or not running two carbs works, I promise you they work amazingly well.  I'll be reaching out for Dyno time to get really concrete numbers.  I know for one, it's made me hungry to go 836cc.
To recap, this is a Murray's Carbs kit running on a 77 motor with pre-77 insulators.  As posted before, I installed the intakes backwards and plained the face of the intakes at an angle to give the carbs a little more outbound placement for this frame.  If the frame was stock, they would fit with no modification.  Then, I rotated the insulators to level the Mikunis at 15į.
(http://www.dotheton.com/gallery/77150-031118103406-46231523.jpeg)
(http://www.dotheton.com/gallery/77150-031118103407-4624368.jpeg)
(http://www.dotheton.com/gallery/77150-031118103409-46252414.jpeg)
Post by: cxman on Nov 03, 2018, 22:30:09
i can feel the shit eating grin
wait till you get the clutch in and grabbing
wheelie time
Post by: trek97 on Nov 03, 2018, 22:57:59
Awesome news bro.  So glad you won the battle!!!
Post by: canyoncarver on Nov 04, 2018, 13:41:11
And all is right with the world again!
Post by: cxman on Nov 04, 2018, 16:59:16
look out  i heard he looking for people to race
Post by: cxman on Nov 04, 2018, 17:23:27
hey eric
do it again
i will go get it if you want
https://www.facebook.com/marketplace/item/238468926838320
Post by: hooligan998 on Nov 05, 2018, 00:54:56
Awesome!
Post by: WhyNot on Nov 05, 2018, 17:33:46
Cool......maybe I'll get my 750 dialed in and we can ride some weekend.
Good job Eric.
Post by: irk miller on Nov 07, 2018, 18:43:35
Might not win me any cool points, but I installed a Tarozzi fork brace to slow my roll...
Post by: Maritime on Nov 07, 2018, 18:54:29
Smart move. Id do the same
Post by: pidjones on Nov 07, 2018, 18:59:27
Plus, it gives a place to mount a temporary fender should you need go ride in (or after) the rain. It may have been early 70's, but I still vividly remember the front tire on my Triumph chopper pumping water from the road UP my nose!
Post by: stroker crazy on Nov 07, 2018, 19:11:56
Might not win me any cool points ...
It's still cool. now it's smart as well!
Crazy
Post by: canyoncarver on Nov 07, 2018, 20:22:25
Me likey.
Post by: john83 on Nov 07, 2018, 21:31:35
Glad to hear you finally got it running good! How can a fork brace not be cool?
Post by: Kanticoy on Nov 07, 2018, 22:21:06
Isnít it about time to chop it in half and start all over again? Thatís generally how Irk builds go...
Post by: irk miller on Nov 07, 2018, 23:38:15
Give me about a month.  LOL
Post by: irk miller on Jan 02, 2019, 21:56:51
I redid the seat in oiled leather. Much better grip and feel than the slick Italian leather...
Post by: canyoncarver on Jan 02, 2019, 22:47:57
Really really nice work.  I definitely dig the new cover.  Texture is important too.
Is it beard "oiled leather"?
Post by: JustinLonghorn on Jan 03, 2019, 07:11:47
Very very nice, man.
Post by: Jimbonaut on Jan 03, 2019, 10:01:21
That's really good-looking work man, really clean.  Colour and finish on that leather looks great with the bike too.
Post by: 1fasgsxr on Jan 03, 2019, 10:09:35
that seat looks amazing man.
Post by: Sonreir on Jan 03, 2019, 11:26:07
Did you do the sewing on that one?
Post by: irk miller on Jan 03, 2019, 11:35:18
Yessir.
Post by: Sonreir on Jan 03, 2019, 11:37:49
Damn. Looks great. Time to quit the day job.
Post by: irk miller on Jan 03, 2019, 14:11:33
Thanks!  I'm trying.  Hopefully, I'll be done teaching within the next 2 or 3 years.
Post by: Maritime on Jan 03, 2019, 19:29:36
Nice work
Post by: Popeye SXM on Jan 03, 2019, 21:52:12
+ 1 quality
Have you painted the panty dropper yet?
Post by: irk miller on Jan 03, 2019, 21:59:49
+ 1 quality
Many thanks to you and everyone else.  I'm definitely much better with my hands than a machine when it comes to stitching.
I put the panty dropper back in line while I re-image my R100/7.  When I'm ready to paint the BMW, I plan to paint the panty dropper, too.  The plan is to paint my DR370 at the same time.  Hoping it will be easier and more efficient for the way I'm set up to do a few at the same time.  My other CB750 chopper may fit into this group as well.  Regardless, I have a Mid-Ohio deadline in July to bring a few of these for sale.
Post by: bradj on Jan 04, 2019, 14:32:04
Our spot is gonna be a used bike lot
Post by: Hurco550 on Jan 04, 2019, 15:58:34
seems like that's whats been selling. complete ridable bikes.
Post by: irk miller on Jan 04, 2019, 16:12:38
Yep.  Seems like we had to work our asses off to sell parts, but the bikes practically sell themselves.
Post by: irk miller on Jan 04, 2019, 22:25:17
Yay.
Post by: canyoncarver on Jan 04, 2019, 23:27:20
Clean.
Post by: cxman on Jan 05, 2019, 07:25:49
pass the hondabond
Post by: WhyNot on Jan 05, 2019, 10:55:32
Nice, I'm gonna do that to a couple of my engines.
Post by: irk miller on Apr 30, 2019, 09:13:27
My first ever trophy.  Outstanding Japanese Custom at this year's Meltdown Vintage Motorcycle Show in Hendersonville, NC.
(https://scontent-atl3-1.xx.fbcdn.net/v/t1.0-9/58667593_10218913215690699_5219587722338893824_n.jpg?_nc_cat=109&_nc_ht=scontent-atl3-1.xx&oh=dbf7bc386c7b8cfe70c1eb5c9e6b2d57&oe=5D63FE51)
Post by: Jimbonaut on Apr 30, 2019, 09:22:50
Congratulations man, thatís gotta feel good
Post by: cxman on Apr 30, 2019, 11:05:10
awesome eric congrats
Post by: JustinLonghorn on Apr 30, 2019, 13:21:09
Well deserved my man. Next beer is on me.
Post by: WhyNot on Apr 30, 2019, 13:32:19
Congrats Eric.......cool.
Post by: canyoncarver on Apr 30, 2019, 13:49:45
I really dig it.  Congrats man!
Post by: pidjones on May 01, 2019, 00:52:59
Bravo!
Post by: TranceMachineVienna on May 03, 2019, 03:15:01
Bravo!Well deserved!
Post by: irk miller on Jul 06, 2019, 18:30:41
(https://uploads.tapatalk-cdn.com/20190706/3c097898a2e0a537c76118dca36dbbb5.jpg)
#mudlife
Post by: cxman on Jul 06, 2019, 20:59:26
you go mud bogging?
Post by: ridesolo on Jul 06, 2019, 22:29:30
you go mud bogging?
If it ain't muddy it ain't Mid-Ohio!
