DO THE TON
Blood Sweat Tears and Grease => Projects => Specials => Topic started by: Sonreir on Jul 31, 2019, 11:22:54
Title: Yamaha XS850 - Kickflip
Post by: Sonreir on Jul 31, 2019, 11:22:54
So I picked up this XS850 over the weekend. Titled and running for $500, but it won't charge.
The plan is to make it roadworthy and sell it and hopefully make a few bucks on the deal.
Current issues (in rough order of importance):
1.) Bike won't charge. Visual inspection shows the regulator/rectifier is hooked up incorrectly (common problem on custom XS builds) so I'm hoping this is a simple fix.
2.) No gauges and no handlebar controls.
3.) Front brake is squishy. Hopefully it just needs to be bled.
4.) The bike's aesthetics are not great, in my mind. But is buying a new headlight for $50 going to get me $100 more on the market? $100 for a new seat get me $150 more on the selling price? Not sure...
Title: Re: Yamaha XS850 - Kickflip
Post by: Sonreir on Jul 31, 2019, 11:24:35
Here's the dashboard...
It has a USB charger and switches for the lights, high beam, turn signals, and something else. Kill switch, maybe?
I'm thinking all the switches will go and get replaced by the usual warning lights. Handlebar controls will go onto the bike to ensure proper functionality. Gauge mounted flush in the headlight housing?
Post by: canyoncarver on Jul 31, 2019, 11:27:55
Good plan.  That weirdness dash/headlight will make it harder to flip.
Post by: JustinLonghorn on Jul 31, 2019, 11:47:23
Man that paint is all kinds of weird.
If you are trying to flip it, definitely put the handlebar controls back on it.
Post by: Maritime on Jul 31, 2019, 12:04:58
Signing up. the paint has to go. but it shouldn't take much to make it a good flip.
Post by: Sonreir on Aug 05, 2019, 14:55:51
Waiting for parts to roll in, so I started on the wiring and put some controls in place. I'm a little bit peeved with the right side because the cable stay in the throttle was too wide in diameter to fit inside any of the controls I had laying around. This leaves a bit of a gap, but it's probably not the end of the world.
Post by: irk miller on Aug 05, 2019, 15:28:25
Iím pretty sure I can still do a decent kickflip.
Post by: SONIC. on Aug 05, 2019, 16:06:27
Vid or I don't believe you  ;D
Post by: Sonreir on Aug 05, 2019, 20:24:23
I never could do a kick flip. I can't even bunny hop.
Post by: Sonreir on Aug 06, 2019, 15:41:30
One of the things I noticed when I picked the bike up was that the center pod filter was missing from the carbs. PO told me that they "fall off all the time". So I removed them and also saw that these are the style that block up the inlets for the diaphragm. So a some quick utility knife work and some glue and hopefully this qualifies as an improvement.
Post by: teazer on Aug 06, 2019, 17:37:17
10 out of 10 for trying, but those filters will always be somewhat restrictive.  You might want to see if you could get a set of UNI filters at a reasonable price or, dare I say it, a stock OEM airbox.  That will come down to cost and availability, but might be a more complete solution.
At least you should have improved things a bit.
Post by: cxman on Aug 06, 2019, 18:52:53
crap is crap glued together or not
Post by: Sonreir on Aug 12, 2019, 12:04:09
New headlight and GPS speedo installed.
Not super stoked about the seat gap, but I'm debating as to whether or not it'll make me my money back if I attempt to correct it with a new seat.
Post by: SONIC. on Aug 12, 2019, 12:12:45
Can you just move the tank back?
Post by: Sonreir on Aug 12, 2019, 12:31:20
I'd need to fab up some new mounts for both the front and rear and that leaves me in the same boat: I'm just not sure the changes will result in a net positive when it's time to sell.
Post by: Sonreir on Aug 12, 2019, 12:32:00
I'm toying with the idea of cutting down the length of the hoop in the back so as to move the seat forward. I need to make sure I have all the clearances through.
Post by: teazer on Aug 12, 2019, 12:48:00
That is already looking much better.  I'm tempted to say find a new, longer tank but if you don't have one in inventory already it just adds cost.
So, maybe it's time to let it go.  It's a great basis for someone to "make their own".
Post by: irk miller on Aug 12, 2019, 13:02:17
Move the seat forward to the tank, angle the hoop up and run a fender that mounts to the hoop a la 70s vintage dirt bike.
Post by: SONIC. on Aug 12, 2019, 13:02:54
True, but time is free :D
It's not but when it's playing with a bike it's at least fun to be paid very little.
I think the gap will really hurt the resale value.
If you can just chop the hoop and move it forward that may be easier.
Post by: Maritime on Aug 12, 2019, 13:19:54
I like Irk's Idea. It would be the easiest likely and look good too.
Post by: ridesolo on Aug 12, 2019, 15:07:11
^ Yup, what he (and Eric) said.  That could work really well for ya.
Post by: pidjones on Aug 12, 2019, 15:53:05
Could you just put a (maybe upholstered) filler in the gap?
Post by: Sonreir on Aug 12, 2019, 16:22:55
I like the idea, but I'm not sure how to go about bending the hoop up at an angle in the back. Another consideration is that the integrated tail light is actually slotted into the hoop, so if we bend too much I'm concerned it will no longer be visible.
Post by: irk miller on Aug 12, 2019, 17:01:54
If you have a torch, bending the hoop is super easy.
Post by: Sonreir on Aug 12, 2019, 17:40:32
Blow torch is about the best I've got.
Post by: Sonreir on Aug 13, 2019, 10:42:45
I think that's a bit better.
I ended up using a reciprocating saw to chop 2" out of the hoop and then I welded it back up again. I also included a small cross brace from 16 gauge steel which serves as the mount for the seat.
The wiring is also complete and everything seems functional. Time to add some gas and see if the charging issue is fixed.
I quick bath in S100 and then hosed off for some glamour shots. lol
Post by: Jimbonaut on Aug 13, 2019, 11:28:24
Nice clean up, looks much much better
Post by: Maritime on Aug 13, 2019, 11:40:28
Needs a rear fender though.
Post by: canyoncarver on Aug 13, 2019, 11:59:22
Nice job man, way better!
Post by: Sonreir on Aug 13, 2019, 12:03:06
I remove the rear fender when I was working on the seat hoop. I think that adds $50 to the sale price?
Post by: Maritime on Aug 13, 2019, 13:30:29
Ha yep, to the right hipster. I didn't mean the crappy plastic one that was on it. Something after the seat, I hate the look of the stubby seat with tire way out past it.  that being said the hoop move was the right thing to do.
Post by: Sonreir on Aug 13, 2019, 14:09:13
Thanks, gents.
Post by: teazer on Aug 13, 2019, 14:48:23
As a friend of mine used to say - "much more better"
Post by: Maritime on Aug 13, 2019, 15:08:09
Something like this:
