Author Topic: CB360's-from build to blog - 2013, MDS (Mo Dumb Shit)  (Read 343335 times)
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
Re: CB360's-from build to blog - 2013, MDS (Mo Dumb Shit)
« Reply #920 on: Jun 03, 2017, 10:32:02 »
Top notch work PJ. That is one classy machine
Offline trek97
« Reply #921 on: Jun 03, 2017, 13:51:55 »
Wow PJ you built a real sweetheart.   8)
Offline crazypj
« Reply #922 on: Jun 30, 2017, 23:32:24 »
Found some 35mm valves with 5.5mm stems (instead of 7mm)
Lighter than stock but not 100% sure it's going to work as they are also longer than stock by a few mm. May be enough adjustment in the screw to keep geometry correct?
It's a much bigger job than I originally thought, just finding a source of valve keepers and correct valve guide seals has been an ordeal (not paying $1450 each for seals  :o ) plus, I still haven't found valve spring retainers at a reasonable cost so I may have to make new ones from 4140 steel, not going to mess with Titanium or 7075 alloy
 Had to re-design guide tops for the smaller seals but not a major issue as I'm making new ones from (I think) aluminum bronze or maybe silicon bronze or even Manganese bronze  , I bought several different types several years ago.
I remember doing a lot of research on different types for valve guides. Aluminium bronze seemed best for high temp applications like exhaust valve guides but only OK for intakes.
Bought some new 5.5mm reamers. ::)
Timberwolf is the guinea-pig, already a month late (sorry TW)  ;D
Looks like I have to pull everything off Photobucket and find a real FREE SERVICE , they changed the rules 28th June  >:( :(
 Seems I would have to 'upgrade' to the +500 plan to get image linking plus 3rd party hosting.
As I'm only using 26% of 2GB (0.5gb by Photobucket reckoning) no way in the world am I paying $399.99/yr for 502.1 GB storage (even if I had the money I wouldn't do it)  >:(
« Last Edit: Jul 01, 2017, 00:16:59 by crazypj »
Best thing I ever overheard
Brian Morgan, 1982
Offline irk miller
« Reply #923 on: Jul 01, 2017, 09:03:42 »
Just upload to here.  Tim opened up the ability to upload and host images locally a year or two ago.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #924 on: Jul 01, 2017, 13:54:05 »
photos.google.com is free for images below a certain megapixel count.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline crazypj
« Reply #925 on: Jul 02, 2017, 22:18:27 »
I didn't know that, just re-loaded the 305 pics  8)
Brian Morgan, 1982
Offline ChopperCharles
    • Modified Motorcycles by Chopper Charles
« Reply #926 on: Aug 04, 2017, 02:52:19 »
Man, I wish those photobucket pictures all throughout this thread were still working. Really was looking forward to the read-through :)
Charles.
Offline crazypj
« Reply #927 on: Aug 06, 2017, 16:22:31 »
Yep, I've been in touch with Photobucket, there is a known issue when trying to download albums (basically, you can't, pretty sure it's deliberate blocking?)
I'll have to download almost 1400 pictures, one at a time sort them then try and remember what went where. That is going to take some time, probably what Photobucket is banking on. I've seen complaints where people have 4~5,000 or more pictures.
If your making money from linked pictures they are advertising stuff,  $400 is just another business expense, but, if like me they are mainly information  for other people, $400 it totally out there, just ain't happening.
« Last Edit: Aug 06, 2017, 16:24:07 by crazypj »
Brian Morgan, 1982
Offline crazypj
« Reply #928 on: Dec 12, 2017, 17:43:10 »
Been having a bit of a rough time but still plugging along. Making a piston holder to machine CB750 (SOHC) for CB500/550 591-605 conversion. As usual, overbuilt but I know from previous piston machining it eventually saves a ton of time plus no chance of distorting pistons. Can also use 'pull piece' to check all piston tops are lsame height. Couple of pics, still needs drilling, tapping and a few bolts plus a 'piston pin' to hold everything together. There will be a drawbar through lathe spindle to allow piston tops to be machined.
Brian Morgan, 1982
Offline trek97
« Reply #929 on: Dec 12, 2017, 20:41:27 »
WOW.
